Question about Dell Computers & Internet
Memory compare error March B test in Dell Inspiron 15R
feelfemi009
  • 277 Answers
SOURCE: Memory write/read & address line failures on Dell Inspiron 1525
you may need to format that memory because it may be corupted.
Posted on Jul 17, 2009
cabanagj43
  • 225 Answers
SOURCE: I ran diagnostics on my Dell Inspiron 1525.
1. reseat the ram
2. at the buttom part of the laptop you will see a window covered which will allow you to remove and have the ram be reseated.
3. take out 1 ram firs then run test then run again the test using the other slot. please test each ram on each slot. check if the faulty if the ram or either of the rams of one of the slots. if both ram passed on one of the slots means that ram is ok and slot is not, so then replace the motherboard. if one ram errors on a slot which the ram passed then that ram might be faulty and needs replacement.
Posted on Oct 15, 2009
  • 401 Answers
SOURCE: Dell Inspiron E1705 Error code 5300:0119
CHANGE MEMORY
Posted on Mar 28, 2010
  • 88 Answers
SOURCE: Is Dell Inspiron 15R 32 bit or 64 bit? Can anyone
Start-my computer- right click on the my computer icon and click properties, it will tell you there.
Posted on Sep 03, 2010
mondimondz
  • 78 Answers
SOURCE: how to install windows xp on dell core i5 inspiron
First, be sure you have your genuine copy of Windows XP -if not, you can contact Dell and ask them a copy of it
1)insert the XP disc on the drive then turn off the computer 2)Turn on again the computer and once you press the power button, keep on tapping on F12 3)You should be seeing the Boot Options. Select CD/DVD and keep on tapping on ENTER once you see the message: "press any key to boot from CD/DVD" 4)if you have done it succesfully, you should see a loading bar that says, Setup is loading files. 5)wait for it to load and Just follow the steps on this link:
http://www.blackviper.com/Articles/OS/InstallXPPro/installxppro1.htm
Posted on Apr 05, 2011
Why does my Dell Dimension E310 w/XP Home Media. Locks up shortly after booting?
It's a memory faulty -- not a hard drive error. Move the DIMM to the other socket (or swap it with the other one if there are two). Re-test. If the error follows the DIMM, the module is bad - replace it with a new one. If the memory occurs with the other module in DIMMA, it's the socket that's bad and you'll need to replace the system board.
Aug 05, 2014 | Dell Computers & Internet
I was changing the power connector for my dell inspiron n5110 but one part came out c7001 now I don't know the location
It's the bluetooth card goes by the speaker cable on the front of the motherboard see images on this page http://www.insidemylaptop.com/disassemble-dell-inspiron-n5110-inspiron-15r-laptop/
Apr 08, 2014 | Dell Computers & Internet
Dell E1505 memory test march LR failed error code 2000 0123
try removing 1 memory stick at a time and see if it boots. hope this helps
Apr 05, 2013 | Dell Inspiron Computers & Internet
While running diagnostics am getting an error code 2000- 0111 in my inspiron 15R laptop
If you receive an error during PSA Diagnostics, look below for the associating error code. If the Error
Error Code
Error Message
Link to Possible Fix
PSA 1000-0111
PSA+ 2000-0111
(Name of Exception) exception occurred at selector XXh offset XXh.
Contact Dell
Jan 04, 2011 | Dell Inspiron 1525 Notebook
I had a Dell Inspiron 15R M5010 with 2.1Ghz and 3GB RAM; when I turn it on, the display is black and after a while I heard 4 beeps, according to the manual is for RAM read/write failure; how can it be fix?
Yes, that's correct, you must replace the RAM memory module; is very easy just get a small screwdriver and open the small compartment on the backof the laptop, there is no need to open the entire cap. Also you can test each module to find out which one is failing
Nov 28, 2010 | Dell Inspiron 1525 Notebook
Dell Inspiron 531 gets me crazy..
hello, sounds like memory issue, I would say if you have more than one stick of memory in it remove one at a time and try it again.
also while you are at it reset BIOS by remove battery from motherboard and/or switching jumper setting.
hope it helps.
regards
Amar Sondhi
Dec 05, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
Computers & Internet Logo
48 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
