Question about GPX KCCD6316DT Shelf System
Will unpluging the radio undo everything that is programmed?
How to turn clone mode on a kenwood tk3402u-k radio that appears to be locked
You need the programming software and the PC programming cable. It is all in the software. You cannot undo the locked feature without the software.
May 25, 2017 | Kenwood Radio Communications
No sound from radio after i change the battery
try using a scan tool to reset the cpu program in the ECM
removing a battery corrupts that program
it controls everything you mentioned including the immobilizer
as for the radio ,you will need a code to enter as it is the radio anti theft system that has operated when the battery was remove d
Sep 06, 2015 | 2012 Chevrolet Malibu
Dash lights only work when pressing brake
Undo what you have done as you have wired into the CPU system and it is sending the program haywire.. Seek help from professional radio installers as it is not a matter of just wiring in any where
Feb 22, 2014 | 2001 Dodge Ram Pickup 1500
My scanner not pickin up
Hi Terry,
You forgot to post the Make & Model of your radio scanner, as they're not all the same.
I'll use generic terms for your (unknown) radio scanner.
Have you programmed any frequencies into your scanner? If not, there's the reason for no reception.
You are required to program frequencies into your radio scanner, before it will receive anything.
If you have programmed your favourite frequencies, did you check to see if they are applicable to your area/location?, If so, then after programming, did you press the L/O key? If so you have locked out your frequency(s) from scan mode. To undo this you will need to press the Mon/Hold key during scan made, this will stop the scanner from scanning, and you can now go through each programmed channel and press L/O key so that L/O icion on the display is out, once you've completed this task, you should be able to scan and when a transmission is received, the unit will stop scanning during the transmission.
I hope that I have assisted you.
Regards,
Peter
Mar 10, 2013 | Radio Communications
Had to do system restore, now it says to undo changes, cannot enable broadcom radiio on acer wireless laptop
Connect to the internet by connecting a Ethernet Cable to the Laptop and the Wireless Access Point/router. Open the Device Manager, Network Adapters, Click on the wireless adapter, is it enabled? yes or no? Yes, update driver. reboot laptop. Is your Wireless Access Point securied? unplug the wireless access point , wait for 30 seconds or so, plug in, wait for selftest, reboot laptop. You didn't supply the Laptop Make, Model or the OS you are using?
Jan 15, 2013 | Computers & Internet
Bosch 500 series error E13 can't get to the front pump
make sure the machine is unplugged,, turn water hose off and undo it from the machine.. then undo the waste pipe now pull machine out and lay a cushion on the floor at the back of the machine.. lay the machine on the cushion (so its on its back) undo one screw bottom end near pump on plimpth and push plimpth to the right and once off you will see 3 screws around the pump,, undo them and pump should fall down,, now you have the pump in your hands it should unscrew,, take out all the **** from the pump,, once you have cleared everything you should put everything back together.
Oct 19, 2012 | Bosch Nexxt 500 Plus WFMC5301UC
How to replace the radio on a 2004 harley davidson electra glide
Remove the outer fairing. Unplug the wiring harness from the back of the radio. Undo the 2 screws on each side of the radio. Pull it out.
Jun 13, 2012 | 2004 Harley Davidson FLHTCUI Electra Glide...
How do you reset the weather radio completely and whipe out everything you've programmed in?
I don't know if this would be called resetting, but if you want to start over while programming, press the "Menu" button repeatedly until it "backs out" of programming mode. If no keys are pressed for one minute, the radio will exit the menu. There really is no way of resetting the weather radio, even if you unplug it and take out the batteries.
May 21, 2010 | Midland WR-100 Weather/RDS Radio
After reading programming Radio Died
Unfortunately you have a corrupted code plug. The radio will need to be serviced to clear the corruption. Or if you have a clean copy of the original programming, you can try reprogramming it. (Note: Do not use the version you had saved which led to the corruption.)
Aug 24, 2008 | Motorola For MT1000 MTX800 MTX90010v...
Panasonic Home Theater won' play sound from TV
plug evey thing back how it was befor u unpluged the components to consolidate wall outputs.
May 11, 2008 | Panasonic Home Theater System System
GPX KCCD6316DT Shelf System Logo
Top GPX Audio Players & Recorders Experts
Sandy Moore
Sandy Moore
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
