Question about Frigidaire 131758600 Washer Washing Machine Timer, Works on Kenmore GE Gibson Kelvinator Tappan White Westinghouse Washers and Dryers, Replaces 131758600A 131758600B 131758600C 131758600D 96679 PT6322749 PS418697 AP2107583
Why machine tumbles without drying and indicating E68?
  • Frigidaire
    Frigidaire May 17, 2014
    Good Morning Friend, I understand that your Frigidaire dryer is tumbling without drying, as well as showing you an E68 error code. I will be more than happy to assist you. If I could please have your model number, this way I can better assist you in resolving the possible troubles with your appliance. You will be able to find this number either on the back of your appliances door, or around the edges where the door meets your dryer. Looking forward to hearing from you. WP
  • Frigidaire Master
  • 5,323 Answers
Not sure bout the code however need to check heating element with a multi meter and check thermostats also, also are u getting a full 240 at the terminal?
Posted on Dec 20, 2014
How do i tumble dry only on a lg hover wash machine
Washing machines don't have tumble dry. That would be a dryer. The best you can do with a washer is spin cycle.
Nov 08, 2014 | LG F1481TD5 1400 Spin 8kg Load Washing...
The dryer is shutting off and showing an E68 error code.
Welcome to FixYa.
The E68 is indicating a push button is stuck, refer to this chart below for explanation and potential remedy.
Let me know how you make out or if anything is not clear and I'll help in whatever manner I can going forward. Good luck.
Regards,
Macmarkus :)
Feb 27, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
How do you remove the water pump on an indesit idc75 condenser drier?
This easy to use white Indemnity condenser dryer will make a welcome addition to any kitchen. The 10 minute cool tumble and reverse tumble option will help keep creases in your fabric to a minimum. Energy efficiency ratings & performance: Energy efficiency rating: C. Maximum drying capacity 7kg. Condenser dryer features: 160 minute timer. Including 10 minute cool tumble. 2 dryness levels. Manual control. Reverse tumble option. Reservoir full indicator. Fluff filter. Size H85, W59.5, D58.5cm. Drying programmes Freshen up cycle. Manufacturer's 5 year parts and 1 year labour guarantee. Technical specifications: Energy consumption: 4.48kWh per cycle based on dry cotton cycle. Energy consumption: 336kWh per year based on dry cotton cycle.
please comment on my post or vote for the solution.
Dec 21, 2010 | Indesit Dryers
Dryer will not stop running
Your machine may have a feature called wrinkle guard or wrinkle shield, which basically keeps tumbling the clothes without heat to prevent wrinkles from setting in. Turn that feature off and see if that does the trick.
May 15, 2010 | Frigidaire Electric Dryer
The programme goes through the motions of a tumble dry but the clothes are not drying
Washer Dryers have a built in seperate heating element with a blower fan to dry the clothes. Your problem could be a simple thermostat/overload reset or there could be more sinister problems. This would be hard to decipher without looking at the machine itself.
Jun 16, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Error code E4A on my frigidaire affinity dryer
This is a board communication problem, you need to replace the control board. If you send me the model # I can tell you what the part number and price would be.
Mike Anderson
Anderson Appliance Repair
(865)945-3808
Dec 02, 2008 | Frigidaire Dryers
Not drying
the steam gets condensed back to water and pumped away so sometimes draining problems cause poor drying. is the machine plumbed in according to handbook?
also your dryer filter may be blocked but this is not accesable without the dryer box being stripped down.
Nov 05, 2008 | Hotpoint Aquarius WD640 Front Load...
Rolling into balls
There is nothing you can do about this. the disadvantage of sheets and blankets.
May 07, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Error Code
E68 error code, according the manufacturers operations manual found at this link: ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134431300esa.pdf
Says the the button used to start the machine has either malfunctioned or is "STUCK" in the start postion. Read this link I found and see if it helps. Best of luck to you.
Mar 18, 2008 | Frigidaire GLEQ2152ES Electric Dryer
E20 error when starting tumble dry cycle
E20 on your machine means some sort of Drain problem. If it actually goes through the Spin cycle o.k. then there is most likely some water still not drained out at the time of the tumble dry. Check the drain to make sure it isn't clogged. also the drain hose.
Feb 29, 2008 | Washing Machines
Frigidaire 131758600 Washer Washing Machine Timer, Works on Kenmore GE Gibson Kelvinator Tappan White Westinghouse Washers and Dryers, Replaces 131758600A 131758600B 131758600C 131758600D 96679 PT6322749 PS418697 AP2107583 Logo
66 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
