Question about Canon PIXMA MP600 all-In-One InkJet Printer
Printer will not print, error code 5010 is
Printer will not print, error code 5010 is displayed on screen, I have tried unpluging & plugging the printer back in & still get the same results
    President:
  • 2,306 Answers
5010 is a scanner error, either worn out scan lamp or sensors. Canon only replaces the entire scan assembly, if you like I can get part number and price.
Posted on Jun 23, 2009
  • Brenda Kidd
    Brenda Kidd Nov 18, 2013
    Can anybody tell me how much the entire scan assembly would cost>
How to clear error code 5010 on canon pixma mp460 all in one printer
Check the manual that came with it for the answer to the codes.
Jul 20, 2014 | Canon PIXMA MP460 All-In-One InkJet...
Error code 5010 green & orange lights flashing printer will not operate
Error 5010 is a scanner error, either not warming up properly, or lamp or sensor error. Either way, the scanner will need to be replaced. I can check for you and get a part number and price if you like.
Jun 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon mp600 pixma; it just started doing this when I tried to print; now I can't seem to be able to do anything with it. I assumed it was due to one of the ink cartridges being out and so I replaced...
"Issue: ERROR LCD: Error Code 5010
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press and hold the button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the button again.
3. Wait until the device has completed its cycling process before submitting another job request."
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 20, 2011 | Canon PIXMA MP600 all-In-One InkJet...
When I turn the machine on I get an error message on the screen. It says Error code 5010. Nothing works from there. Can you tell me what this means and how I can solve this problem?
Error [5010] may appear after the printer is powered on or when attempting to make a copy or scan. This can happen if an IC on main board of the printer is either malfunctioning or has corrupt data in it.
To confirm if this is due to corrupt data, try clearing the memory by resetting it.
1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
2. Wait approximately ten seconds and then press the <ON/OFF> button again. (or plug back in)
Then see if you still get same error.
Apr 10, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Canon pixma MP600, error code 5010, what does it mean ? Can not turn the printer on for any other purpose, no scanning, copying or printing.
There are a few things you can try:
  1. Power reset; press and hold the Power button until it the machine starts a diagnostic mode; if this doesn't turn on the machine, unplug it for 10 minutes and upon plugging it back in, see if the error reset itself
  2. Unplug all USB devices (including the printer) and reboot the computer. Once the computer has rebooted, plug in the printer, allow it to install (it should install automatically) and see if the error is corrected. Sometimes there can be a temporary conflict and the only way to solve it is to remove all other USB devices (this can work for external hard drives too).
The overall issue with error code#5010 is a scanner malfuntion. If the problem returns, check the ribbon cable as it runs from your scanner to the main logic board. If all is secure and you still have the problem, the printer may need a new logic board.
Nov 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon pixma mx700 error code 5010
5010 is a scanner error from the scanner on top. Canon has no parts for these and you can only replace the entire top of your machine. If you can get it apart, you might clean and lube, but it's not made to be opened.
Jul 03, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Re: Error Code 5010
Call Canon technical support.
Dial 1-866-261-9362, Monday - Friday 10:00 a.m. - 10:00 p.m. ET (excluding holidays).
See also a previous related question here! (a scanner issue)
http://www.fixya.com/support/t1232529-error_code_5010_cannon_mp460_printer
Sep 02, 2017 | Canon PIXMA MP460 All-In-One InkJet...
Re: Error Code 5010
it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Mar 07, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
3,749 people viewed this question
old marine
old marine
