Question about Fujitsu ScanSnap Manager
Light flashing will not scan scansnap 500 - Fujitsu ScanSnap Manager
2 Suggested Answers
  • 6 Answers
SOURCE: My Fujitsu ScanSnap S510 only flashes 5 blue lights
I got off the phone with Fujitsu and i was told you need to make sure that the ScanSnap Icon is in the system tray without a Red Line cross through it, so if it is not in your system tray start the snap scan program, if it's disabled re-enable it and you should be good.
Posted on Jul 13, 2009
Won't scan light blinks 5 times
check to make sure the ScanSnap Manager is running.
Nov 04, 2013 | Fujitsu ScanSnap Manager
Scansnap hardware error 0x00048004
I had this exact same problem. Turned out that I was using the wrong power adapter. Enough power to turn on the scanner lights and connect to the computer, but not enough to actually perform a scan. As soon as I realized I was using the wrong power cord, I switched it up and voila!
Jan 23, 2013 | Fujitsu ScanSnap Manager
Blue light flashing on ScanSnap S510
The blue flashing like generally means that the scanner is doing a scanning operation.
Nov 29, 2011 | Fujitsu ScanSnap Manager
Everytime i try to scan any document using my Fujitsu ScanSnap S510, the blue light on the front-right side of the device blinks 3 or 4 times and nothing else happens (the document, therefore, is NOT...
I had a similar problem. All I did was unplug the USB cable from the scanner and reattach it. Sometimes I would have to close scansnap (blue "S" icon in the sys tray at the bottom right), and then power on the scanner.
Nov 28, 2011 | Fujitsu ScanSnap S510
My ScanSnap has worked flawlessly for years. I just tried to scan and got the following message: undefined error occurred.(0xffffdcf7) Won't scan. Tried to reboot - no luck. Let me know...
The same thing happened to me. In a nutshell, you have to install new drivers. Have you recently upgraded your system to SnowLeopard or Lion? I did, and that's what went wrong.
To do:
1. Make sure you have the latest ScanSnap manager: http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/mac.html
Install that.
2. Get the Lion update: http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/mac-mg22.html
Install that.
3. Open the new ScanSnap Manager (v 2.2). Delete the old one from your dock, so you don't get confused.
4. Scan away.
Aug 06, 2011 | Fujitsu ScanSnap S510
My scanner keeps flashing and not pulling the paper through, I cannot seem to figure out why it will not scan. It does this quite often, what is the problem that is causing this? Scansnap S1500
Go to msconfig or if you have a registry cleaner, go to the startup menu. Disable and ssmgr (scansnap manager in pfu). Reboot. Open the ScanSnap 1500 and then start the ScanSnap manager. The scanner is now ready to scan.
Jan 26, 2011 | Fujitsu ScanSnap Manager
My Scan Snap won't scan. The Scan light just blinks and nothing happens.
My Scansnap was being used through a USB powered hub.
This worked....Shutdown EVERYTHING and unplug computer from your powerstrip for 10 seconds (or just turn off your powerstrip for 10 seconds) It resets the BUS power. This solved why almost all of my USB devices stopped working or were behaving badly.
Jun 01, 2010 | Fujitsu ScanSnap Manager
Scanner will not pull the paper all the way through & scan. Scanner says not valid folder to save image is selected . Set the save folder for the scanned image data. I don't know what to do
Try to scan by using the quick menu as I described below:
Check for the ScanSnap Manager icon on the taskbar.
5d5f1b3.jpg Right click the mouse button over that ScanSnap Manager icon.
Select “Scan Button Settings” from the Right-Click Menu.
2344c41.jpg Select the “Use Quick Menu” check box (it must be checked).
Load the document in the ScanSnap which you want to scan.
Pres the “scan” button on the ScanSnap.
Click the “Scan to folder” icon in the quick menu when scanning is completed.
The “Scan to Folder” dialog box appears.
Check the scanned image in the “Scan to Folder” dialog box.
By clicking save buton, save the scanned data in a specified folder which you select chancing the filename as you want.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Apr 09, 2010 | Fujitsu ScanSnap Manager
May 26, 2009 | Fujitsu ScanSnap Manager
Computers & Internet Logo
259 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
