Question about Garmin eTrex GPS Receiver
How to set up tracks - Garmin eTrex GPS Receiver
Why is my 2nd recording track picking up the first recording track. I want to record another instrument, but the new track picks up the other tracks.
I don't know if this will help, but the Magix software I use create their own set of files. You can see these in the folders it will create for your project. I would specify another folder - create one - for each project or recording, that might solve the problem.
Jan 07, 2015 | Magix Music Maker 2014
Why is the locomotive sparking while going on the track
The train gets it's power from the track. the spark, as long as it is small, is normal. it just means the wheels left the track for a second
Nov 10, 2011 | Lionel The Polar Express Train Set
Garmin etrex ledgend c: When track log is turned on, "breadcrumbs" mark the path I've traveled. I don't save the track but the breadcrumbs remain on the unit's map....forever.
Hello
Check both your track and map settings. Make sure that "show track on map" is not selected in your map settings, and in your track settings try erasing all previous tracks.
Hope this helps!
Dec 09, 2010 | Garmin eTrex Vista Cx GPS Receiver
My jvc has developed a tracking problem when viewing tapes recorded on other recorders. I cant seem to correct the problem. It shows old tapes without a problem
VCR tracking has to be set up right, but even then many machines have problems with tracking other vcr's tapes. Generally a good quality commercial tape should track well. If it doesn't then either there's a fault with the tracking on your machine or the tracking is not set up right. Most tracking problems are caused by dirt, or wear on the heads or surfaces. Give your VCR a good clean up, every surface the tape comes into contact with, using Servisol Video 40. If that doesn't solve it you might have to look into the cost of replacing heads, maybe the control/audio head first. Or you should look at having the tracking set up by a proffessional (at a JVC service center). However if the tracking was off, after resetting any tapes the machine has done, may now have problems tracking, whilst other machines tapes and commercial will track normal.
Jun 28, 2010 | JVC HR-S6970 S-VHS VCR
How can i activate new ring tones and text alert tones on my sony ericsson satio phone ? also when trying to download apps it sayd redownload and when i do it shows an error !!! any help would be so...
you can set a ring tone in play view!
hope this helps please remember to take the time and give me a good rating if you appreciated my help.
Managing tracks in play view
You can manage your tracks in many ways when playing them. You can, for example,
delete a track, send a track, set a track as your ringtone or add a track to a playlist.
The following icons may appear in the touchbar when a track is playing:
Exit the play view and go back to the previous level
Go to the music library
Adjust the volume
View more commands
Delete the current track
Send the current track
Set the current track as your ringtone
Add the current track to a playlist
View track information
Minimise the music player
To delete a track
1 When the music player is open, tap > .
2 Select an option.
To send a track
2 Select a sending method.
To set
also can be done in personal settings:
Personal settings
You can personalise your phone by changing the standby screen, profile or themes.
Profiles
You can change settings such as the ring volume and vibrating alert to suit different
locations. You can create new profiles or change preset profiles.
To change the profile
1 Select Menu > Settings > Personal > Profiles.
2 Tap a profile and select Activate.
3 Select Back.
You can also press and then select a profile.
To edit a profile
2 Tap a profile and select Personalise.
3 Change the settings and select Back.
To create a new profile
2 Select Options > Create new.
3 Enter the settings and select Back.
Mar 26, 2010 | Sony Ericsson Satio Cell Phone
Where can I purchase more track for this toy train set? CAT Iron Diesel Train Set found at ToysRUs, Meijer, Target.... The track included makes a small oval, would like to have more track so the train...
CAT Iron Diesel Train Set's price decreased by 56% from $44.99 to $19.99 at Amazon.com. CAT Iron Diesel Train set. Easy assembly just push track together. Create multiple layouts. Requires 2 AA Batteries not included
Sale Price: $19.99, Vendor: Amazon.com Full Details
Sale Price: $19.99, Vendor: Amazon.com and/or Amazon.com Merchants
Dec 29, 2009 | Toy State CAT Iron Diesel Train Set
I have a JVC HR-J610U VHS VCR cannot set tracking
On the VCR its self hold in the + and - buttons to set the tracking manually.
Mar 15, 2009 | JVC Televison & Video
Triton Le
when you are setting your midi track on the mpc are you changing to 2A-Device02 for the 2nd track? 3A-Device02 would be the 3rd track and so on. Let me know if that helps. you should make a new track for each instrument you record from the triton to the mpc, helps when dumping.
Feb 18, 2009 | Korg Legacy Collection
Tracking button on remote for a citizen dvd / vcr player model 557dvc
it should have auto tracking , but if you need to , then manual tracking settings will be arrows up / down , but your user manual should tell you how they set that up to work for manual , but sometimes even when you manualy set the tracking the auto tracking will take over again
electech
Oct 31, 2008 | Televison & Video
Garmin eTrex GPS Receiver Logo
14 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
