Question about Kenmore Refrigerators
Ice buildup bottom of freezer
I have a kenmore elite trio refrigerator Model 75524 (made by LG). Everything works fine except I get water build up which turns to ice in bottom of bottom freezer. I thought it was caused by water to ice maker or water dispenser on outside of door, but I turned all water to refrigerator OFF three weeks ago and still have the ice build-up problem. Any suggestions of what is causing this problem. Freezer temperature (and refrigerator) is OK.
  • 3 Answers
SOURCE: refrigerator condensation
I have a Kenmore Coldspot Model 70262990. When I get wet shelves (water, not just condensation), I was able to trace my source to the cold air vent from the freezer. In my case, the water melts from the evaporator and collects in the rear lower section of the freezer. It is "supposed" to go down the drain tube. However I had the drain hole freeze over. Then additional water from the defrost cycle would accumulate in the freezer floor (under the plastic floor) and eventually find its way down the cold air vent between the freezer and refrigerator section. You'll need to unplug the unit, take the plastic floor out of the freezer, remove the evaporator panel to access the defrost drain, melt the frozen water (hair drier works nice), and remove all the water (towel/sponge & bucket). Make sure the drain is not frozen and not blocked. Then put it back together and plug it in.
Does anyone know how to stop the drain tube from freezing over?
Good luck.
Posted on Apr 26, 2008
larryyb
  • 291 Answers
SOURCE: Ice maker in a Kenmore Elite Side by side refrigerator
check the head of the icemaker and see if the gear is broken on the module
Posted on Nov 26, 2008
  • 247 Answers
SOURCE: kenmore refrigerator ice/water in door not working
welcome-
what type of kenmore do you have (brand and model number)? this way it is easier to find infomation for you.
thanks and happy holidays
Tom
Posted on Dec 19, 2008
SOURCE: Kenmore Elite Trio Model 795.7757960 - Error Code 'IF'
possible sollution...sears replaced a board last week as a recall for "energy rating" problem I now have that same code I am trying to find out which board they replaced; will submit asap
Posted on Mar 24, 2009
  • 36 Answers
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Posted on Jul 24, 2009
How do I take KENMORE ELITE TRIO 596.75533400 out of demo mode?
Try pressing ultra ice and home while the refrigerator door is opened,or ultra ice and the refrigerator pad with the freezer opened. Hold for five seconds. Hope that works.
Jun 12, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
The door on the bottom of my freezer will not pull open. Ice has been building up in the bottom for some time. We were away for 1 week and now it will not open. I have shut off the freezer for more than...
If it is ice holding the door closed, you might use a hair dryer and a putty knife. Heat the blade of the putty knife with the dryer and work your way around the seal. If that doesn't work, then you probably have an ice buildup on the rails and will have to defrost the unit - Hope the freezer isn't full of food! You can hurry the defrost up some by using the hair dryer blowing down the fan exhaust hole.
When you finally get everything open, you should check the condition of the door seals, make sure the evaporator fan is operating (if circulated the cold air up and also remose the humidity from the freezer).
Aug 06, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Kenmore elite fridge. Bottom freezer ice builds
You have a bad defrost system on this unit, that's why you're freezing up. Call us with the model number and we'll get the correct part out to you right away. We hope to hear back from you soon.
Oct 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge is hot, freezer is working properly
The temp control damper solenoid is frozen closed - or the solenoid itself is failed.
CLICK HERE
for the part
#13 in THIS DIAGRAM
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Adjusta cube ice maker spilling water
check at the back of refrigerator were water line comes in see if there have eany hole or check your freezer may be it (ajar)
Apr 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water leaking into freezer
It may be the defrost thermostat. This thermostat turns on a heater in the freezer a couple of times a day and melts the ice in the freezer which should go into a tube that leads to a pan underneath the refrigerator, where it sits and evaporates from the heat of the compressor. It could also be the timer which tells the refrigeator to turn off a couple of times a day and tells the defrost thermostat to turn on.
Mar 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite trio 596.76539500 control panel says OFF.
On a Kenmore Trio 78729 made by LG, open left door and push the Ultra Ice and Refrigerator button simultaneously for 5 seconds. The display will change from 0 OFF to temperature settings.
Dec 10, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Elite trio
Hello bigmikeegator
Welcome!
You said, you have the Kenmore Elite Trio Bottom Freezer. You moved your refrigerator to a new home and removed the bottom freezer door, but can not seem to figure out exactly how to put it back on correctly.
It's too much for me to tell you myself.
This is easier!
Page 9 shows you how to remove and reinstall doors.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523115.pdf
Thank you,
Huuum,
Please remember to leave a rating!
Oct 06, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
107 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
