I have a masport gas wood look alike already in house, no idea what model, has worked fine for 3 years power is on but not getting to control board?
Masport gas free standing flued fire place worked last night, power not getting to control board to turn on manually or by remote?
snakehead
  • 1074 Answers
SOURCE: tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Posted on Apr 04, 2007
SOURCE: masport rota-hoe
Aloha
You can try this site, what Part do you need, you might have to Crainger, or a lawn mower repair shop, try this site right below.
MASPORT 5HP ROTAHOE - OutdoorKing.com.au Forum
Happy Holidays
Bobby
Posted on Dec 10, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: Goodman GMP075-3 ignition problem
OK, if the furnace is not lighting for even a few seconds, you have either a bad gas valve, bad wire, bad control module or no gas. The pressure switch is not the issue. Check all wires to the gas valve and look for 24 volts across them when the ignitor glows and you hear the click. Then test for 24 volts to ground. It could be a bad ground wire.
Posted on Oct 21, 2008
SOURCE: Need Instructions to use Fireplace Gas Logs
There should be a set of metal cards attached inside the fireplace.
First you should read everything there.
I know you have to first light the pilot light.
And then there should be a wall switch.
The problem I have currently is that it won't stay lit when the artificial logs are there.
Posted on Nov 23, 2008
  • 6 Answers
bad board,i have had several board failures on goodman
Posted on Dec 31, 2008
Circuit board fried. anyone have company phone number for parts?
No idea, you do not state the manufacturer or model number etc.
Jul 10, 2017 | Televison & Video
Received a Woods Indoor Wireless Remote 3 pack Outlet as a gift but unfortunately it does not work. Where do I inquire to get a replacement. Cannot return to store since I have no receipt
I have several remote 3-packs for testing, and I like remote-control lamps.
1 in 3 receivers arrive defective or goes bad quickly. Others seem to work fine for a year or two.
http://waterheatertimer.org/Woods-timers-and-manuals.html#13568
This product is manufactured by CCI (Coleman Cable)
Contact CCI at following link:
http://www.colemancable.com/contactus.aspx
Other things to consider:
These particular receivers are for Incandescent bulbs up to 1000 Watts.
Also, electronic timers and gizmos are susceptible to line interference.
Use circuit analyzer from Home Center and plug into same receptacle to see if circuit is clean.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 06, 2011 | Woods Wire Products Woods Power Caddy
I have a 10-year old Carrier Gas pack Model #48GS024060301. Turned on the heat for the first time this season and the unit did not turn on. I was able to turn on the house circulation fan and since it...
If the induction motor ain't going I would look for a blown 3 amp (purple) fuse on the control board. If that was good I would check if any of the roll out switches were tripped. If a rollout switch was tripped check or air restrictions somewhere.
Oct 17, 2010 | Heating & Cooling
Hi, I have a KitchenAidDishwasher (Model KUDP01FL). It's worked well for a few years. Yesterday, when we went to turn it on, none of the lights on the buttons were on. WE can't turn it on at all. The...
Kill the power to the unit. Pull the control panel down to access the control board located on the right hand side of the panel. There will be 2 wires coming in to a white plastic clip on fuse located on the side of the control board. It will have a plastic pliable shield over it. Pull the 2 wires and check for continuity across this fuse. If no continuity then go to parts house with model number of unit and ask for thermal fuse for your unit. Replace this fuse following the instructions included in the kit and use all the parts included in the kit.
Apr 11, 2009 | Dishwashers
Dec 18, 2008 | Goodman GDS80904BNA Open Flame Heater
Gemmy light show lollipops not working right
The gemmy light shows are amazing when working correctly. BUT that may be for one season only. I bought the white trio set of Christmas trees after one season the trees turned brown, tried to get in touch gemmy. Two days later my reply was I improperly stored my trees. All the other set of trees I've seen turn brown after one season. As far as I know gemmy quit making the white trees. Long story short they did't warranty my trees, as for the lollipops 4 or 5 light systems aren't interchangeable, I tried to replace the led in my 5 light system with a led from a 4 light system the led worked but wouldn't sync. When trying to make repairs you must use parts from alike sets of the same year models, alike models from different years don't work. Also when changing led circuit boards solder the wires the way you take them off or you'll short the board out. If you have bad sets of lights you can make repairs if they are alike.
Nov 18, 2008 | Sport & Outdoor - Others
Replace Control Board?
control board sounds like alikly source, been known to have problems with their display boards as well though.does your unit have a display board on the front maybe 2in.x 3in. square inlay? or is ti just kinda all part of the push button leds
Feb 22, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
