Question about Altec Lansing Ada880 Ada 880 Subwoofer Speaker Syst - Excellent Condition
Popping The speakers make a random popping sound after being on for a while. What needs to be replaced?
Dlp hl t 5075s pops vol reduces ,comes back to normal volume pops randomly ,picture fine . sound is garbled weird sound . shut down for a few minutes then ok for awhile ??
Sounds like its audio output section circuit has the fault. Contact any service technician to troubleshoot. Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Sep 10, 2014 | Televison & Video
Amp pops randomly and gets worse with my remote bass knob hooked up any ideas ?
When you say that the amp "pops" are you referring to the sound that is coming out of the speakers?
This is most likely the speakers "bottoming out", i.e. moving as much as they can, and then slapping against the back of the speaker frame. Adding the remote bass knob (presumably increasing the signal to the amplifier) would make the problem a bit worse, which explains why the popping increases after you add the bass knob.
You can try decreasing the gain on your amplifier and running the system at a moderate volume. If there's no popping occurring, you can be reasonably sure that the subs/speakers are just being over-driven.
Mar 03, 2011 | Rockford Fosgate Power 1501BD Car Audio...
Have a random popping sound coming from car speakers. Sometimes its just from the front right door speaker sometimes its from all the speakers, pops range in loudness levels, the loudest pop comes from the...
Is it after market radio? Check connections from radio to speakers and at the speaker(s) Door slamming knocks wiring loose. Also bad antenna lead can do it also since most radios get ground from antenna.
Feb 25, 2011 | 2001 Honda Accord
Popping sound at random times out of my AV Reciever/Surround sound system when video is playing.
Clean and tighten all connections. Get a can of spray tuner and contact cleaner from Radio Shack to clean the volume and tone controls if you have access to the body of those controls. Some disassembly required. If this doesn't help, suspect a bad variable resistor in the amplifier circuit.
May 29, 2009 | Sony STR-V444ES Receiver
Popping noise from speakers
sounds like the digital input and the component input are casing inteference , try removing the component video and see what happens
May 23, 2009 | Sony STR-DE695 Receiver
Sony STR-SE501 makes popping sound/cuts off
just repaired my se 501 poor solder conections on blue rleays by speaker jacks,also blown center speaker seems there are 2 in it one blew and so did cpacitor running now just hooked up one in center speaker sonds great also stay at 8 ohms setting
Mar 17, 2009 | Sony Audio Players & Recorders
Speaker Issues
likely that the output coupling capacitors are going or the amplifier chip is.
normally the popping sound will be from one speaker but the mixer may share the sound.
best to turn it off and use external speakers hooked up to your equipment. or start troubleshooting the circuit. turn on mute and see if that stops the issue,
or connect ext speakers to the aux out and see if they pop too. if so then the issue is with the amp not the outputs.
be certain that all is grounded well and remove any spike protection ac strips.
Feb 25, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Open Questions:
Altec Lansing Ada880 Ada 880 Subwoofer Speaker Syst - Excellent Condition Logo
32 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
