Question about GPX TD2420AB 24 in. LCD HDTV/DVD Combo
Set will when poewred stay on for 3seconds and turn itself off.
I have a whirlpool gold dishwasher. The controls locked light is on and I can not get it to shut off. I can not run the dishwasher
In reading the manual, it shows the following:
To turn on Lock, press and hold Control Lock for at least
3seconds.
To turn off Lock, press and hold Control Lock for at least
3seconds.
Jun 07, 2015 | Whirlpool Dishwashers
06 plate traffic, no brake lights, & service indicator & abs light staying on, bulbs ok, but no power at holders, suspect brake switch but can not find it.
The brake switch is mounted on a bracket by the brake pedal under the dash. The switch button touches the brake pedal arm. This is what turns them on and off. There could be two switches there. The brake is the one with two wires going to it. the other would be for the TCC cutoff.
Jan 03, 2015 | Cars & Trucks
Have lg monitor flatron e2260 . Have had for about 3 weeks. Starting today, the monitor goes black and states "d-sub power saving mode". The tower stays on. Thx
1. Check the connections and make sure they are still tight. If the monitor isn't getting data signal it can go into power saving mode. Since it was working I would check this first.
2. Look in control panel under POWER OPTIONS and make sure it's not set to turn off after so long.
3. Also check the settings for your screensaver under display settings. That too could put it into poewr saver mode.
It could be a setting on the monitor itself that somehow got changed. Check out the settings to see if anything has changed.
Apr 21, 2011 | LG Computers & Internet
My inducer comes on for 3seconds then shuts back off could there be something wrong with the pressure switch?
It begins its power-on cycle normally. First the updraft blower turns on for a bit, then the HSI glows bright orange, then the gas turns on and the flames ignite fully and the big blower turns on.
About 3 seconds after the gas ignites, it shuts off. That is the gas shuts off, the blower continues for about a minute then it shuts off. This cycle will repeat a few times, then usually after the second or third time everything stays on and works normally
Oct 30, 2010 | Kitchen Appliances - Others
Xbox360 has no poewr and wont turn on but the poewr cable is going in to the 360 and the power pack has a orange light
Sounds like you motherboard has failed. Return or exchange if you still have warranty. Good Luck.
Nov 24, 2009 | Microsoft Xbox 360 Console
50ux58b had lost poewr, red light went out never
Common problem with this model of Hitachi. Get a repair kit from TvRepairKits.com . Its a problem with a fuse and a capacitor that cause the issue I am told.
Nov 08, 2009 | Hitachi 50UX58B 50" Rear Projection...
Monitor goes dead after after switch on after 3seconds
CCFL backlight may be busted.. also ccfl inverter may need repair or replacement too..
Mar 09, 2009 | GNR 19M1 19" LCD Monitor
Insignia lcdtv32 poewr on but no picture
You need to check the 12 or 24v source coming from the power supply to the inverter board, that's the board usually to the left and rather tall. Get your meter set, then turn the set on and see what happens, if the voltage comes up and then shuts down, you'll need to pull the plug for the inverter and measure the voltage again. If it stays up you have a bad converter board, if not then it's in the power supply, that's good old fashion trouble shooting from there on.
Feb 26, 2009 | Televison & Video
I have trouble with my
Pls what brand and model of the car stereo?
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 03, 2008 | 1998 Volkswagen Beetle
GPX TD2420AB 24 in. LCD HDTV/DVD Combo Logo
20 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
