Question about Power Acoustik P-8AMX 600W 8 2 Way Portable PA System w/ Removable 8 Channel Mixer & Mic Each
Is this product true stereo? Does it contain 2 amplifiers???
Audiobahn a1502dp amp only one channel is working. I need both to bridge it and get its full 1ohm potential. Where can I get this fixed? Preferably near kc
Audiobahn A1502DP True Digital Series 2-Channel Amplifier
www.sonicelectronix.com > ... > Car Amplifiers > Class-D Amplifiers
Rating: 4.5 - ‎4 reviews
Audiobahn A1502DP • True Digital Series 2-Channel Amplifier 1 ohm stereo stable 2 ohms bridged • True Digital Circuitry • Dual Cooling Fans • HP/LP ...
new amp, only one channel working?? help! [Archive ...
www.caraudioforum.com > ... > Car Audio: Installation Help
Apr 24, 2006 - 16 posts - ‎5 authors
the next step would be to try reversing the rca cables on the amp. ... unplug one wire, the one sub that is working, gets quieter, although it is still working. as ... It'saudiobahn, of course this could happen straight from the factory.Missing: a1502dp
[PDF]True Digital Full-Range Series - Audiobahn
audiobahn.com/.../Amplifiers/A752DP-A1502DP-A2502DP-A1004DP-...
A752DP/A1502DP/A2502DP ... Audiobahn was established in 1997 with one long-term goal in mind, ... Great products and proper installation are only a small piece of the puzzle when it ... from the smallest terminal, to power wires up to 0 gauge, and 4channel RCA cables. .... exceed the total value of fuses in the amp. 1 1 .
one channel not working [Solved] - Speakers - Audio
Jan 15, 2016 | AudioBahn Car Audio & Video
The remote does not communicate with the amplifier
[PDF]The Bose® Lifestyle® SA-2 and SA-3 Stereo Amplifier
https://worldwide.bose.com/.../en/owg_en_sa2_sa3.PDF Bose CorporationWARNING: To reduce the risk of fire or electrical shock, do not expose the product to.... ence to radio communications. ... Note: Unauthorized modification of the receiver or radio remote control .... Thank you for purchasing a Lifestyle® SA-2 or SA-3 stereoamplifier. ... Left and right channel line inputs for a local audio device.
[PDF]Owner's guide - Bose
worldwide.bose.com/axa/assets/pdf/owner.../og_sa1.pdf
Bose CorporationJan 4, 2002 - WARNING: To reduce the risk of fire or electric shock, do not expose the.... may cause harmful interference to radio communications. ... Connecting theLifestyle® stereo amplifier to a Model 5 music center . ..... Lifestyle® SA-1 stereoamplifier rear panel ... Setting up the RC-20 remote control for Zone 2.
[PDF]BOSE® Link AL8
Dec 29, 2015 | Bose Lifestyle SA-2 2-Channel Amplifier
Where can I get a manual or user's guide for this?
Sony eSupport - Manuals & Specs - Select a Model
https://esupport.sony.com/US/p/select-system.pl?...
Sony CorporationBe among the first to get the latest Sony news in your inbox. ... A/V Receivers; Blu-ray Disc™ Home Theater Systems; Blu-ray Disc™ Players ... Car Receivers & Tuners; Car Speakers & Subwoofers; Car Stereo Amplifiers; Car ... If you prefer a paper hard copy of a manual, you can purchase it from the True Manuals web site.
Free Pioneer Car Stereo System User Manuals - Car Audio ...
caraudio.manualsonline.com > ... > Car Audio and Video Pioneer
Products 1 - 50 of 304 - Pioneer DVD RDS AV Receiver User Manual ... Pioneer CarCD MP3 Player Instructions Guide ... Pioneer CD Player User's Guide.
Dec 22, 2015 | Car Audio & Video
St-s211 no stereo
first read the instructions they contain some amazing information. I can not help you because I have no idea of what you want to know.
Jun 11, 2014 | Sony TA-FE370 2-Channel Amplifier
How do you set the clock
These are generic instructions for a JVC car stereo:
1. 1. Hold "SEL" button
2. 2. Select CLOCK H or CLOCK M with the fast forward button or fast backward button.
3. 3. Adjust item with wheel
4. 4. Finish by clicking on "SEL" button
5.
Manual can be downloaded at:
http://support.jvc.com/consumer/product.jsp?categoryId=CATG0004&archive=true
May 05, 2011 | JVC AM FM CD DET FACE CAR STEREO
Connecting a car stereo to an amplifier
you have to connect your 4 speakers to 4 speakers output direct to your car stereo no need of amplifier to 4 speaker but speakers should be small not like a woofer, and you have to connect your sub woofer by using amplifier don't connect direct. connect the output of your car stereo (using 2 RCA) to the 2 RCA inputs of amplifier. If u connect your 4 speakers to your amplifier then your car stereo does not support Left Right channel.
You can also connect your laptop or iPod direct to your amplifier.
Good Luck
enjoy music
Nov 24, 2009 | Kenwood Car Audio & Video
KAC-9104D output terminals
This feature allows the amp to be paired to any stereo. The input may be in stereo but the amp then changes it back into mono using sound from both sides. Hope this answers your question.
Jul 23, 2009 | Kenwood KAC-9104D Car Audio Amplifier
My powered subwoofer has RCA inputs for four jacks. (two front, two rear) My CD head also has four RCA outputs (2 front and 2 rear). Is there some advantage to connecting all of these with patch cables, or...
the advantage is every time you split a pre-amp signal, the voltage, too, divides in half. Your signal (music) is going down the river at 2 volts say, and when it gets to the amplifier, it is split into 4 streams. The signal will be distorted and the amplifier will not work as efficiently. Use the Front AND rear RCAs so your amplifier uses the best possible signal - for the best possible results!
Also, if you are using 4 RCAs you get true stereo FL FR RR RL Instead of L and R
Dec 30, 2008 | Jl Audio 500/1 Car Audio Amplifier
Amp a2801q
Audiobahn A2801Q
Product Description:
Class A/B MOSFET Circuitry
200 watts x 2 @ 4 ohms stereo
280 watts x 2 @ 2 ohms stereo
560 watts x 1 @ 4 ohms mono
Volt Meter With Blue Illumination
PWM MOSFET Power Supply
Double Sided Glass Epoxy Circuit Board
THD: 0.02%
S/N Ratio: >100dB
Frequency Response: 10Hz - 40KHz (+/- 1dB)
Variable 18dB Hi-pass Crossover: 90Hz - 750Hz
Variable 18dB Low-pass Crossover: 30Hz To 120Hz
Bass boost @ 45Hz: 0/18dB
Subsonic Filter: 20Hz to 50Hz
RCA Throughput Connections
3-way Protection Circuitry: Thermal, Short Circuit and Overload
Cooling Fan
Cobalt Blue Illumination
High gloss Chrome Plated Finish
Nickel Plated Block Terminals
Dimensions: 2"(H) x 12.75"(W) x 15.5(D)
1-year warranty
Jan 02, 2008 | AudioBahn A2801Q Car Audio Amplifier
Hooking up speakers to amp
YES ! This is usually ok, the speaker cabinet should contain a high pass filter or crossover on the tweeter to decouple it from the low frequency signals. My Linn Index speakers are wired like this.
Sep 07, 2007 | Audio Players & Recorders
Power Acoustik P-8AMX 600W 8 2 Way Portable PA System w/ Removable 8 Channel Mixer & Mic Each Logo
73 people viewed this question
Top Power Acoustik Audio Players & Recorders Experts
Ryan Lutton
Ryan Lutton
 Grubhead
Grubhead
richard foulk
Are you a Power Acoustik Audio Player and Recorder Expert? Answer questions, earn points and help others
