Question about Nespresso Coffee Makers & Espresso Machines
Brand new Nespresso Inissia M105 doesn't heat the water.
Hi everyone! I just bought a Nespresso Inissia (the Magimix M105 model), did the first use step (just make coffee without using a coffee pod three times), and then started making coffees. The first three coffees were fine, so I know I'm not screwing up : press either of the buttons, wait for them to stop blinking so that the machine heats the water (25 seconds), then when they stop blinking, press the button corresponding to the amount of coffee you want. It worked for three coffees. And then, still on the very day I bought the machine, it just stopped. When I press the button, the buttons start blinking, and keep on blinking. Forever. I got the machine just there, it's been blinking for 20 minutes + (the time I went to nespresso.com, magimix.com, checking if there was an active nespresso subreddit, and so on.) Let me just tell it to make a coffee... [...] ...it's not cold enough for me to call it "cold", but it's definitely not warm. After 20+ minutes of "heating" instead of the 25 seconds promised. So I don't know what to do. Nespresso.com tells me that I have to make sure that my cups are pre-heated (1- really?, 2- I don't see how it will help, you can't make coffee with cold water), magimix.com tells me to descale it (really? It's brand new, so you mean to tell me I have to descale my machine every three coffees made?), and the obscure user manual is obscure as f*ck (just a bunch of icons that are incomprehensible at best). Any help would be appreciated.
Noggin
  • 944 Answers
SOURCE: Krups Nespresso FNA2 coffe/cappucino machine
First thing to try is a descale. Run the machine normally using it (as if making a cup of both types) a couple of times with a 50/50 mix of white vinegar and water. Leave the machine off but uncleaned overnight. run a couple of cycles with just water, and if there is still a slight vinegar taste then run a cycle with a teaspoon of baking soda in water, then flush with just water again. If this doesn't solve the problem, try again with 75% vinegar. If still not working, there is either a control board problem (may be solveable), or the valve/solenoid that stops/allows the water is sticking, almost certainly solveable by taking that apart and cleaning/lubricating. Definitely solveable by replacement. Let me know what you get after a descale if no luck. Hope this helps :)
Posted on Aug 20, 2007
  • 333 Answers
SOURCE: Brand New Nespresso Essenza just stopped working..
If you just bought it you should return it immediately and try another.
Posted on Dec 24, 2008
SOURCE: water not heating up enough, misplaced a manual.
Here is a place where you can get manuals
http://www.cerinicoffee.com/Saeco_User_manuals_free.aspere
I have had this problem before: Could be two things either the boiler or the sensors that measure the temperature of the boiler. Normally the red flashing light that you get on startup will never go away if the boiler doesn't get to temp. If your light goes to constant red, it means that it thinks the boiler is at temp ( but it isnt). That points a bit to the temp sensor.
There are two sensors, one that regulates the temp and one that is an emergency cut off device incase the boiler gets too hot. Both must be working. If you download the manuals, they will show the position of these (if its the more detailed manuals with parts.
Taking these machines apart and putting them back together is a bear of a task, I have done it several times. Might be worth taking it in as you have to pull the whole assembly out of the container to get to the boiler.
Hope that helps.
Posted on Jan 18, 2009
  • 4088 Answers
SOURCE: the tassimo coffee maker does not heat up the
Take the machine back for warranty replacement.
Posted on Feb 21, 2010
SOURCE: My Nespresso machine is the
Have same problem with my Citiz
Posted on Oct 18, 2010
The 2 buttons keep flashing & the water won't heat up
You must re press both buttons at once again sow you will remove mashein from descaleing mode
Oct 09, 2016 | Nespresso Coffee Makers & Espresso...
Can I use vinegar and water to descale the machine instead of the expensive kit? What proportion water to vinegar?
You can use vinegar freely, just wash your coffee maker when ready.
Vinegar only descales, won't damage metal and rubber parts.
Sep 29, 2015 | Nespresso Inissia
My Nespresso inissia is not working. the lights come on and when i press either of the buttons to run the coffee through the button flashes but the machine makes no noise and nothing happens. Please Help
I would imagine the main pump/heater unit has failed. Probably better to buy a new one, unless you can take it back to the outlet where it was purchased.
Feb 17, 2015 | Nespresso Inissia
Inissia keeps blinking
Thios could indicate the machine has returned to factory settings. Other than that it requires repair - check the user guide..
http://www-media.nespresso.com/ecom/websites/manuals/inissia/inissia_C_krups.pdf
Sep 23, 2014 | Nespresso Inissia
Why too little coffee
The machine is calibrated to produce a certain amount of water depending on which button is pressed (Lungo or expresso - larger or smaller cup). This can be altered by holding down the relevant button - check this manual..
Aug 23, 2014 | Nespresso Inissia
Brand new Nespresso Inissia M105 won't heat the water
Just a brief addition, I don't have the Magimix model, but I have a similar one. It loses it's programmed settings if it is unplugged or switched off at the wall, but if you leave it plugged in but turn it off with the switch at the back it keeps the settings you have put in. It draws virtually no power when it's switched off with the switch on the machine, (I checked it with a power meter).
Just thought I'd share that with you.
May 15, 2014 | Nespresso Coffee Makers & Espresso...
WHEN SWITCHED OFF, WATER LEAKS AT THE BASE OF NESPRESSO C100 MACHINE
I opened mine when this did this - it also happened to my second Magimix Nespresso Manual machine. A short pipe carrying pressurized water had burst. I called Nespresso . parts were not available and they offered me a new half-price machine. We are talking a 4 inch piece of plastic tubing here. Shame on you Nespresso for encouraging me to throw what is otherwise a fine machine....
Nov 14, 2010 | Nespresso Essenza C100 Espresso...
The steam wand keeps throwing out water and making my milk watery
Call the Nespresso Club, they will hepl to solve it in no time
0800 442 442
Good luck
Frog
Dec 28, 2008 | Nespresso D300 Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
