Question about Plantronics M25 Bluetooth Headset
How can I lower the volume for the person I'm calling? plantronics model 25
My m100 bluetooth always calls the wrong person.
Plantronics M100 always calls the wrong person:
Unfortunately this is a common occurrence. We say one name and it says, "did you say..." something totally different. I think that most of us has had that experience. The Bluetooth headsets that have a longer "boom" type mic will pick up your voice better and have a better chance at hearing your voice properly the first time. Models like the Plantronics Voyager Pro+ and the WG100/B have a boom type microphone. The WG100/B also includes a UBS Bluetooth adapter so it can be used on a pc.
http://www.headsetsdirect.com/plantronics-bluetooth-headsets/bluetooth-for-mobile-phones/voyager-pro-bluetooth-headset.html
http://www.headsetsdirect.com/plantronics-bluetooth-headsets/computer-mobile/wg100-b-savi-go-wireless-headset-mobile-computer.html
Good luck from Headsets Direct - 800-914-7996.
Aug 04, 2011 | Plantronics M100 Bluetooth Headset
We are using the Plantronics CS55 wireless headsets. The users are complaining that the '3-beep' incoming call alert tones are too loud. We have tried to adjust this tone level by manipulating...
Lowering the ring volume on the phone only decreases the sensitivity of the lifter, which generates the signal to the headset. The signal volume between the two is preset and cannot be adjusted.
Good luck from Headsets Direct!
Jul 20, 2011 | Plantronics CS55 Wireless Headset
I have a CS361 plantronics wireless headset and I get alot of echoing when I get calls in and out, and when I call my coworker
Reduce speaking volume by changing the speaking volume
major adjust switch setting. See page 15 in the User's Guide (link below).
• Point microphone towards your chin.
• Listening volume too high on phone. If your phone has a handset
volume control, lower this until the distortion disappears.
• If the distortion is still present, lower the listening volume adjust
button on the headset. If the distortion persists, select another
listening volume major adjust switch setting. See page 14 in User's Guide.
• Base is too close to computer or phone. See page 9 in User's Guide for
proper positioning.
For further help, this is the link for the Plantronics Wireless Headset User's Guide.
Apr 19, 2011 | Plantronics CS55 Wireless Headset
Just purchased the quantico phone trying to pair it with my plantronic 510 headset but need help
Press and hold both the Speak Volume Adjust Buttons on the base unit until
the indicator in the Call Control Button starts to flash.
Press and hold the headset Listen Volume Adjust + Button and headset Call
Control Button until the Status Indicator flashes red and blue.
Pairing completion is indicated when the Call Control Button indicator
illuminates solidly, and the Status Indicator flashes
Here is link to manual if you need it:
http://www.plantronics.com/us/media/media-resources/literature/user_guides/voyager510_ug_gb.pdf?WT.dl=20
Good luck
Apr 16, 2011 | Plantronics 510 Voyager Headset - PLN-510...
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
Can barely hear on full volume? Plantronics 232
1. Stay away from ambient noises 2. Press the up volume for 3 seconds. 3. Make sure it's in your ear all the way.
Jul 15, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics explorer 233 volume is too low at the
volume is too low and I can make calls the incoming calls are only thru phone
Dec 02, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics CS55. When using the wireless headset
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
Jul 10, 2009 | Plantronics CS55/HL10 Wireless Office...
Outside caller hears themselves in an echo
Jan 23, 2009 | Plantronics CS55 Wireless Headset
Motorola Razr sound too low to hear person on the line
when you call some one
try pressing up the button on the left
there are three buttons on the left and 1 on the right
press the up button it will say on the screen ring style volume 7 or 6 or what ever you have set it up to
but during the call when you press the same button it lowers or higher the volume of the speaker
thats the easy way to do it
Nov 05, 2008 | Motorola Mobility RAZR V3
Plantronics M25 Bluetooth Headset Logo
26 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
