Question about Garden
Wolf manual where can i get a manual for a Wolf 3000psi pressure washer? Have purchased a unit but cannot get it to sustain running
  • 338 Answers
SOURCE: how to clean gas wolf oven
No. Because if you dont get all the cleaner off you dont know if it would be toxic or not.
Posted on Jan 16, 2009
SOURCE: Wolf Range r366 - How do I replace the igniter
I have a Wolf Gas Range and initially my igniter incessantly sparked. I noticed that the igniter is cracked. Do I need to replace it and if so how do I replace it? The electrical wire to the igniter became disconnected; should sticking it back into the igniter cause it to work?
Posted on Oct 16, 2009
SOURCE: Wolf cooktop 5HR light keeps turning on. Pressing
Turn off power to the cooktop (i.e., using circuit breaker if needed) for 15-20 minutes. Once turned power back on, problem disappeared for me. The semiconductor needed to be reset
Posted on Jan 03, 2010
  • 12 Answers
SOURCE: washer not working properly
the unloader is bad if not replaced it will damage the packings in the head of the pump go to the car wash an ask them were they buy there rebuild kits and parts they will now
Posted on Mar 16, 2010
  • 342 Answers
SOURCE: Wolf 800 generator. Engine will run but very electrical power is
is the engine running at the correct speed
3000 rpm to produce 50hz
3600 rpm to produce 60hz
Posted on Apr 04, 2010
Pump has no pressure
Pump might be bad. Does it have a pressure relief valve on the pump? New pumps 2100psi -3000psi run a bount $89 - $120.
May 12, 2016 | Garden
How can i adjust the pressure
Cannot. Ensure u have a 3000psi wand.
Jan 15, 2016 | Northstar Pressure Washer 3000 PSI
Will not pump above 3000psi?
probably has a relief valve in the pump head that prevents over pressure from damaging the pump
3000 psi is extreme for a pressure washer and will remove paint from a vehicle , blow out gaskets on engines , remove cement surface , peel timber surfaces
Sep 08, 2015 | Comet TW 5050 S - Pressure Washer...
What kind of oil does a husky 3000psi pressure washer use?
I don't believe that Husky (Home Depot) makes any 3000psi pressure washer that operates with a 2 Cycle motor. So.... gas only in the gas tank. Husky pumps can be from several differant manufacturers... some use no oil, some are sealed and don't recommend any attempt at oil changes, and some use Non-detergent 30w oil and some use 20-50 Full Synthetic oil. You can look up your specific model specifcations with a google search for Husky pressure washer.
Oct 21, 2012 | Garden
Karcher 2400 psi with honda motor started up big puff of white smoke from exaust it shut off noiw wont start whats going on
I have a john deere 3000psi pressure washer with similar problem. Running fine then a puff of smoke and it shut down. I checked the oil and found it full of water. Not only that but since I still had the water turned on, the water was flowing out of the dip stick tube. I'm trying to find a solution online and will pass any information on.
Nov 13, 2010 | Karcher 2500 PSI Pressure Washer
Washer not working properly
Mar 15, 2010 | Garden
What type of oil is best for the 3000psi Honda power washer?
a 30 weight nondetergent oil is recommended, available at any auto parts store.
Aug 05, 2009 | Honda Pressure Washer PSI 3000
I have a craftsman 3000psi and it keeps losing pressure
hi there,
this means no water pressure coming
to pressure tank it was consumed when use for cleaning, the water pump does not work,check water pump if function,if there over load reset,or had to jumper the connection of pressure switch.
jump the connection of pressure switch,by passing pressure switch if the motor run just jug for 3 seconds,if run you have defefctive pressure switch,replace pressure switch.have a nice day and rate me if your satisfied to my solution,thank's
Apr 30, 2009 | Karcher 1750 psi Electric Pressure Washer
Garden Logo
108 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
