Question about Sony Bcg 34HRMF4 Super Quick Charger with Lcd Indicator And 4 Aa Batteries
What does 3 flashes mean - Sony Bcg 34HRMF4 Super Quick Charger with Lcd Indicator And 4 Aa Batteries
The red light on the water heater keeps flashing
Attached to the water heater is a troubleshooting chart for your sequence light. 1 flash means..., 2 flashes means...., and so forth. Find the chart, count the flashes and see what it means and we'll go from there. Douglas
Sep 18, 2010 | Reliance Natural Gas Water Heater Control
I have a 95 honda accord check engine light flash 1 long and 7 short. what does that code mean?
That means Code 17, one long flash means 1, seven short flashes means 7. The code is for the Vehicle Speed Sensor (VSS) Have it checked and replaced if necessary.
Jun 13, 2010 | 1995 Honda Accord
Engine code
12 and 55. The 55 means end of code session, the 12 means no distributor reference. Both of these codes are normal with the engine not running, so do not go out and purchase a dstributor. Is there another problem with the vehicle, or did you just want to know the codes? Comment back to continue,thanks.
May 26, 2010 | 1995 Jeep Grand Cherokee
Light kee flashing orange/green and says computer is busy when there is nothing in print queue
FLASHING ORANGE LIGHT ERROR MESSAGES
Try counting the number of orange flashes.
* two flashes means you’re out of paper or the paper is not feeding correctly.
* three flashes means there is a paper Jam or the output tray is closed.
* four flashes means the ink tank is empty
* five flashes means the print head is not installed correctly or not installed or is defective (before buying a new print head always try the cleaning instructions at the end of this post first.)
* six flashes means the inner cover is open or not closed properly.
* seven flashes means you counted wrong.....
* eight flashes means the waste ink absorber is almost full or full.
* nine flashes mean that a digital camera or video that is connected is not compatible with the printer. If a specific amount of time lapses without getting a response from the digital camera or video camcorder this will happen.
* ten flashes means it can not print to both sides of the page
* eleven flashes means the automatic print head alignment failed. (this can be caused by low ink levels, ink tanks not being installed correctly, the print heads being clogged. It can also be caused by the paper output slot being exposed to a strong light source (Press the resume /cancel button and move the printer to a darker location and try to align the print head again.
* check to make sure the lock lever is correctly positioned (down)
If the above does not work, align the print head manually by opening the printer properties dialog box and clicking the maintenance tab and then select the print heal alignment button on the left side, second row down.
Mar 29, 2010 | Canon BubbleJet i320 Printer
Printer stopped working. Getting "10" orange flashes for which there is no error answer in the book. Believe driver is up to date. Wondering if I should uninstall program and reinstall. Problem may have...
Mar 27, 2010 | Canon i860 InkJet Photo Printer
Set of 4 alternating orange and green flashes. No carriage movement when opening lid. All started with waste ink tank issue and then trying multiple 'fixes' from online
Mar 26, 2010 | Canon BJC S600 InkJet Printer
My is not working & shows an error code B200.
Mar 25, 2010 | Canon Office Equipment & Supplies
The orange light keeps flashing
Mar 22, 2010 | Canon I990 InkJet Photo Printer
Rench flashing
solid rench means you need a PM on the machine.
flashing rench means the fuser web needs to be replaced
May 15, 2008 | Panasonic DP-1810F Laser Printer
Flash bulb has gone and onboard flash wont catch the clip
First, some clarity:
What do you mean by "flash bulb has gone"? Is the internal flash not working any more?
What do you mean by "onboard flash won't catch"? Do you mean that the internal (pop-up) flash doesn't work?
Is it possible that you have the flash turned off completely?
Dec 18, 2007 | Nikon D70s Digital Camera
Sony Bcg 34HRMF4 Super Quick Charger with Lcd Indicator And 4 Aa Batteries Logo
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Computer Links
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
