Question about Acer Aspire One Netbook 8.9" Notebook
Internal Mic did not work
After weeks trying to figure out what had gone wrong on my Aspire one with the internal mic,... just decided that the microphone died... Tried every single driver and such..... to revive it.
I sent the laptop to Acer and they repaired it (you have a year warranty). It was picked by UPS and delivered back by UPS in 2 days.
So, recommend that anyone with this problem just sends the Acer for repair. My system was running Windows XP and the microphone worked for several weeks before it died.
Peter
I'd suggest downloading new drivers...
Posted on Jul 15, 2009
  • 544 Answers
try to used diffent mic.
thanks,
Posted on Jun 23, 2009
Pro505xl mike does not work
Hi Davey,
You have a Radioshack PRO 505XL, and I take it that you have the mic connected to the set and not using the internal mic, is this correct?
If this is so, the problem might very well be the wrong mic for that radio brand & model, or if it's the correct mic, then it's a dead mic, but if you're referring to the radios internal mic, then it could be a wire has come lose or that mic needs replacement, which ever it is, it means replacement or re-soldering.
I hope this has been helpful.
Cheers,
Peter
Jan 08, 2013 | Uniden Radio Communications
Laptop internal microphone stopped working
your need go to device manager on the internal mic thing click on it and rollback driver to original or update it one of those should work or go to control panel under sounds then recording devices and clic to make you internal mic your default mic and make sure its not muted
Nov 12, 2012 | Medion Computers & Internet
I have an HP Pavillion dv2700 laptop with windows Vista. My mic was working fin until a few weeks ago, now no one can hear me on google voice or skype. I checked the mic settings and it is not muted and...
You can try going into device manager and find the device and remove it then reboot and let it reinstall the mic drivers. If that does not work try going to the HP site and see if a new driver is available and install it. The mic could have gone bad and you may have to buy an external mic.
Thanks for using FixYa
May 30, 2011 | HP Pavilion DV2910US Laptop
Does my computor have internal mike. how do i find it
most laptop now a days have an internal mic and webcam. if your laptop has a webcam, most likely, it has an internal mic as well. You can test it using the Windows audio recorder or other applications that uses a mic to confirm if you have it available.
Jan 31, 2011 | Acer Aspire 5500 5570-2609 Laptop
Internal Mic problems
it should work straight away on skpe. Have you checked to see that the microphone check box is not checked? To do this right click on the speaker symbol (bottom right of tool bar if you are using XP)
Apr 26, 2010 | Acer Aspire One PC Notebook
Acer Aspire internal mic won't work.
You need to check the record settings and make sure the mic is not muted or turned down to low. Click START, CONTROL PANEL, then SOUND icon. Click the AUDIO tab up top. Make sure that your sound card is selected in the drop down menu under Sound Recording. Now click VOLUME tab. A new window will open up. Click OPTIONS then PROPERTIES. Make sure you have a check by the MIC and click OK. In the Recording Control window, turn the level up for Microphone and make sure it is not muted. Let me know what happens.
May 02, 2009 | Acer Aspire One PC Notebook
Internal Microphone not working
This is not a problem with mic. Settings in System was changed so that mic has been muted. To enable goto contol pannel and Select Sound & Devices and Select Advanced in Device Volume there you will get Master Volume Settings Menu So that uncheck the Mic option and check for Mic Setting in that.
hope this will be helpful.
Thanks & Regards Nanda Kishore.
Apr 10, 2009 | Acer Aspire One Netbook 8.9" Notebook
Gateway Tablet m-285 Internal Mic not working
I've seen that happen once before. The mic might have disconnected from the mainboard or the mic cable might be broken. The connector is located just to the left of the screen hinge (visible after removing the power button cover by lifting the right corner of it and pulling up and out gently). It is the small connector. If it is connected, then is either the wire roken or the mic itself has gone bad. The wire is routed under the screen bezel, which has to be removed in order to gain access to the mic and mic wire. The wire breaks at the neck of the hinge, where it is subject to torsion from swiveling the screen. Hope that helps
Fred
Mar 01, 2009 | Gateway M285-E Notebook
My microphone on my acer aspire one isnt working
This solution works for the Windows XP version. Go to msconfig.exe, then the Startup tab. UNCHECK rthdcpl and restart. Realtek driver doesn't load, but who cares...the microphone works now.
Aug 09, 2008 | Computers & Internet
Acer Aspire One Netbook 8.9" Notebook Logo
346 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
