Question about Makita 6019DWE 3/8 Cordless Drill Keyless Chuck Rev 7.2v 600 Rpm
How do I remove the keyless chuck?
Model6095D
    President:
  • 1,996 Answers
Open it up all the way, remove the screw in the center (reverse thread), and then unscrew it off the arbor. for instructions and diagram of a similar model see here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 23, 2009
Require a 10mm and a 13mm Male-fitting Keyless Chucks
I suggest that you do not proceed, Keyless chucks can be problematic especially if dust /debris from material being drilled gets into the chuck. I have had to remove the Keyless chuck from my B&D drill and replace it with a keyed chuck- no problems since.
Apr 04, 2017 | Drills
How can I replace the keyless chuck on my Dewalt DWD215G?
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it. Once you have the chuck off, verify the thread size of the drill motor shaft, then go to McMaster-Carr and choose the one you need.
Apr 16, 2011 | Dewalt DWD215G 12Inch 10AMP Heavy Duty Mid...
I can not change the drill bit. Do I need another tool?
that depends on whether or not you have a keyed or keyless chuck. if you have a keyless chuck then you do not need another tool you must turn the chuck counter clockwise to loosen the chuck and replace the bit. if you have a keyed chuck then you will see three holes around the chuck of the drill ie the part that holds the bit. just below the holes you will see teeth spaced evenly around the drill. a chuck key allows you to put the end of the key in one of the holes and using the teeth you turn the chuck key thereby loosening the chuck and allowing you to change the bit. if you have a keyed chuck just take it to your local hardware store and they can provide you with the correct key and show you how to remove the bit. if your chuck is keyless the hold the chuck put the drill in reverse and pull the trigger use a glove to protect your hand
Feb 24, 2011 | Drills
How do I remove the Chuck from my Mikida 9.6 volt keyless drill
Dont know about a Makita, but my Craftsman drill , if you open the chuck all the way and look inside the hole where the bit goes, there;s a screw there that you can use to remove the chuck. amybe yours is the same way.
Nov 23, 2010 | Makita Keyless Drill Chuck Set, HP1501...
Remove keyless chuck on a 12 volt makita drill
There should be a Screw in side the end of the chuck were u put the drill bit in u will have to undo it back wards its got a left hand thread
Oct 23, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Need to change a keyless chuck
open jaws for large size bit.look in bottom and there will be a screw slot or phillips head screw or possibly an allen head screw.remove this,by possibly turning clockwise. and then chuck up a large allen wrench. try removing the chuck by tapping wrench with hammer. this may be threaded on counterclockwise.have to try both ways.
Aug 28, 2009 | Craftsman 19.2v 3/8"drill/driver W/ Work...
Keyless Chuck releases bit when reversed
hi
open the chuck all the way and then look down in the centre of the chuck you should see a cross head screw
unscrew and the chuck should pull out as this is on a taper system ( note the screw is left hand thread )
Nov 21, 2017 | Dewalt 18 Volt Compact Drill Kit
Keyless chuck removal
Yes you can use any kind if chuck as long as the thread that attachs it is the same size, look on line lots of tool stores sell them cheap.
Sep 22, 2008 | Makita HP1621FK 5/8" Hammer Drill Kit with...
Makita 6019DWE 3/8 Cordless Drill Keyless Chuck Rev 7.2v 600 Rpm Logo
185 people viewed this question
Top Makita Drills Experts
John Trevino
epangan29
Mike
Are you a Makita Drill Expert? Answer questions, earn points and help others
