Question about Honda Garden
Honda hrb 475
How to adjust air mixture
3 Suggested Answers
moretons
  • 155 Answers
SOURCE: mixture adjustment honda hru 173
Hi this most honda engines dont have a mixture adjustment screw they only have a air bleed adjusment on the front of the carby close to the head though you can only move it a bit either way on some others should be about 2 turns out from closed, the main problem that honda engines have is they will still run with water in the carby , I would try cleaning out the carby bowl first its only held on with a bolt in the centre.
Posted on Aug 01, 2009
SOURCE: Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
Posted on Aug 07, 2009
2000 Honda shadow vt750 running rich and can't get a smooth idiol
Hi, Ej the carburetor throttle shaft wheel has two cables the cable closest to the right side of the bike is the throttle cable and the one closest to the left side is the idle cable. Right about the middle between the two is the idle adjustment bolt it faces out towards the air filter end of the carb. The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the idle adjustment bolt clockwise to increases idle speed and counterclockwise to decrease idle speed. If you have access to your air fuel mixture bolt you may adjust it as well if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture bolt clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back it out 2 full turns to establish a starting point start the engine and check the idle rpm's and adjust the idle adjustment bolt accordingly for 950-1050 rpm if necessary, adjust the air fuel mixture bolt 1/4 turn at a time and let the engine settle for about 10 seconds, clockwise for a leaner mixture and counterclockwise for a richer mixture you are seeking the highest rpm your air fuel mixture bolt can acquire without going past 3 full turns from bottom then readjusting the idle adjustment bolt back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture bolt all the way in then your pilot/low-speed jet is too big. Final adjustment should be made with a clean air filter mounted to the carburetor. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Adjusting the Mixture Screws
Running Rich
http://www.vt750dc.com/HONDA_VT750DC.pdf
http://www.partsfish.com/page/oem-parts-for-honda
http://www.vt750dc.com/VT750DC_OwnersManual.pdf
Dec 25, 2016 | 2000 Honda VT 750 C2 Shadow
Honda hrb 476c hight adjustment
http://powerequipment.honda.com/support/owners-manuals
Jul 27, 2014 | Honda Garden
2005 Honda Activa air-fuel mixture adjustment
Hi, Anonymous it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
1. The mixture screw may be sealed at the factory with a Welch Plug please review the following video for removal.
https://www.youtube.com/watch?v=wAXcksgvDkM
2. The mixture screw manages a range of 3 complete 360-degree counterclockwise turns from the bottom/closed position.
3. The mixture screw should have a spring and o-ring for tension and sealing integrity.
4. Turn the mixture screw clockwise until it gently bottoms out, this makes the fuel charge very lean and the engine should not idle if it does then the pilot/idle jet is too big and needs to be replaced with the next size smaller.
5. Turn the mixture screw 1 and 1/2 turns counterclockwise to establish a baseline for starting the engine.
6. To fine-tune the idle circuit, adjust the mixture screw 1/4 turn in or out to achieve maximum idle RPM, wait 15 seconds between each adjustment for the idle to settle.
7. Never go past 3 full turns out this will make the fuel charge rich, foul plugs, and produce black smoke out of the exhaust, if the engine RPM keeps increasing past 3 turns the pilot/idle jet is too small and needs to be replaced with the next size larger.
8. After achieving maximum idle back out the mixture screw another 1/8 of a turn then adjust the throttle cable idle stop screw to 950-1050 RPM.
9. This procedure works great on 99% of all engines, for the 1% that demand a more robust throttle response on aftermarket monster fuel delivery systems additional tweaking outside the box may be necessary.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Adjusting air fuel mixture screw
Honda Activa Fuel Mixture screw Actual Adjustment and RPM Adjustment
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Honda activa 2009 Owner Manual
Feb 14, 2014 | 2005 Honda Activa
Adjust idle on honda shadow
Hi, Anonymous you need to make sure you have no intake leaks by spraying some Brake Kleen, Contact Cleaner, Starting Fluid etc. around the intake manifold and seals, if the RPM's go up or down significantly then you have a leak that needs to be fixed before you can continue with the carburetor adjustment.
The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the idle skrew clockwise to increase the idle speed and counterclockwise to decrease the idle speed. If you have access to your air fuel mixture skrew you may turn it as well, if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture skrew clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back the skrew out 1-1/2 full turns to establish a starting point start the engine and check the idle rpm's and turn the idle skrew accordingly for 950-1050 rpm if necessary, turn the air fuel mixture skrew 1/4 turn at a time and let the engine settle for about 10 seconds, turn the skrew clockwise for a leaner mixture and counterclockwise for a richer mixture, you are seeking the highest rpm your air fuel mixture skrew can acquire without going past 3 full turns from bottom then resetting the idle skrew back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture skrew all the way in then your pilot/low-speed jet is too big and needs to be replaced with the next size smaller. Final adjustment should be made with a clean air filter mounted to the carburetor.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Honda Shadow VT700C Running Lean Fix Pilot Jet Needle Shim
http://www.cycleterminal.com/Service-Manuals/Honda-VT500C-Shadow-Service-Manual-English.pdf
http://mybikemanuals.com/honda/honda-vt-owners-manuals
Oct 18, 2013 | 1986 Honda VT 500 C Shadow
How to replace drive cable on honda hrb 216 tda
Disconnect both ends, attach new cable. Google model number parts for illustration.
May 08, 2013 | Honda Garden
How do i lower the cutting height on my honda hrb 476c mower
You either have hand adjusters that allow you to put wheels at desired height ,or you would have to unbolt your wheels from the deck and place them at your desired height. The deck would have a number of holes in it for just this purpose. GOOD LUCK.
Sep 15, 2011 | Honda Garden
Dear Sir, Have you any idea where i can get a Manual for my Honda HRB 475 lawn mower. Thanks.
Well you could do a google search, failing that going to the honda site and doing some clicking could help.
Aug 30, 2011 | Garden
2005 Honda CRF 450 R idle adjustment
Hi, Haselhuj you need to make sure you have no intake leaks by spraying some Brake Kleen, Contact Cleaner, Starting Fluid etc. around the intake manifold and seals, if the RPM's go up or down significantly then you have a leak that needs to be fixed before you can continue with the carburetor adjustment.
Idle adjustment screw
How to Adjust Idle On Dirt Bike Tips and Tricks 1
Honda CRF450X 2005 Service Manual
Honda CRF450R Owner Manual
May 28, 2011 | 2005 Honda CRF 450 R
Garden Logo
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
