Question about Canon Imagerunner 1025IF Grayscale Copier
Unable to connect imagerunner to network - Canon Imagerunner 1025IF Grayscale Copier
HOW DO YOU NETWORK A canon imagerunner 1023
do You want to connect the machine on network or .... ?
First check if you on back side of copier have the network connector.
If yes, you need to connect the normal network cable if you have network switch or cross cable if you are connect directly on PC.
Then you must enter the IP adress in machine, under user mode (*) under system settings, under IP adress.Also enter subnet and gateway adress.
Free IP adress you can check on your pc under CMD and type ipconfig, to see your ip, subnet, and gateway.Then type : ping XXX.XXX.XXX.YYY The YYY marks number that you can change and must not be same as yours PC.After typing ping .......... and you have answer DATA LOST that means the ip is awailable and you can type it in copier.
Install drivers and select tcp/ip port.
If these isnt solution that you asked for, you can also contact me on emma.servis@gmail.com with more detailed description.
Hope that helps!
Sep 02, 2010 | Canon imageRUNNER 1023iF Black and White...
Wanting to connect pc to a Canon ImageRunner C3100. Anyone have any ideas on doing this?
hi first u have to vearfy that yours irc3100 have a network card if yes then you have to
1.download latest driver for irc3100 from canon ofical website.
2. you shud have a network cross cable to connect directly from your pc if you dont want conect directly you want to conect throug yours local network in that condation you can use normal network cable,
3. you have set IP address on yours irc3100.
4. just connect networ cable and install driver on pc.
thats it enjoy
thanks
May 13, 2010 | Canon imageRUNNER C3200 Copier
Hi when i connect my ir 3300 with computer the ir3300 is showing network problem. even i had change two no. of cross cables.
Wich kind of problems, you are unable to ping the copier or you cant print, or ...
If you connecting the PC directly use the croswired cable if you are connected over HUB, or other network device you must use normal UTP patch cable, from copier to the HUB, and from the HUB to PC.
Do you have right IP, subnet and gateway?
Check the network cards on copier and PC, if you crimp the cables by yourself check the cables,...
Do you have printer FLASH on your copier?
When did errors occured? Were you able to print before?
Dec 18, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Unable to print documents from computer. Computer
good day, sir try to uninstall your driver and re install again and re start your computer and see what happening. tnx....
Nov 09, 2009 | Canon imageRUNNER 1023iF Black and White...
Making a Canon Imagerunner 400S a network printer
connect network cable from the machine to the switch or router, and give ur machine ip address compitable with ur network, then load the driver on ur computer and u will be fine.
Jul 06, 2009 | Canon imageRUNNER 400S Copier
ScanGear Not Detecting Network ImageRunner
the scangear by network is not for this machine .only for usb.
May 20, 2009 | Canon imageRUNNER 1023iF Black and White...
I have no manual and I need to figure out how to scan on this machine. Canon Imagerunner 50001.
Download the network scangear from the canon web site.
Install the scangear on all the computers you want to scan to.
On the scangear tool there is a discover icon,click that icon and wait till the ir 5000 is picked up by the network.Select the machine in the scangear tool.Now you will be able to scan to mirosoft word and exel like you normally do with a scanner.
If the scangear tool was unable to discover the machine,the network settings of the IR must be checked.
Hope this help.
Mar 09, 2009 | Canon imageRUNNER 5000 Copier
Unable to print to canon IR 2020 when connected through router.
Try to conect directly with cross utp cable to an pc, if every thing works, its your network problem (maybe privilegies, banns,...) if not ... good luck :-)
Try to reconect the pcb s
Dec 10, 2008 | Canon imageRUNNER 2020 All-In-One Laser...
Unable to send scanned document
What error code are you getting? Try to scan again and let it fail. Press system monitor, scan, log. Look for jobs with Result of NG. Highlight one and press details. At the top, look for Result: NG (####). It will display an error number there. What is that error number?
751 cannot connect to server
7xx cannot connect ...
8xx could connect, but error...
801 bad user/pw or firewall
802 user/permissions
899 unknown if successful, may be normal
Check additional functions, system settings, network settings, email/ifax settings. Check SMTP server IP and authentication / encryption.
Ignore POP or recieve options as they are for IFAX.
Nov 18, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Canon ImageRunner 3030: connecting scanner to network
Do you hvae a ether net PCB installed on it ? It is normally a option. You need the right boot rom and ether net pcb first
Feb 08, 2008 | Office Equipment & Supplies
Canon Imagerunner 1025IF Grayscale Copier Logo
26 people viewed this question
old marine
old marine
