What does error code SP mean? - Washing Machines
What does error 03 indicate?
Fatal Error Code 03: CR Horizontal Position Error
The SP motor brake signal did not switch on within 3 seconds after
turning the printer on.
Check, and if necessary replace, the following in the order below.
1. Check for disconnected SP motor-related connectors (ROM
BOARD: CNSPHS, CNSPM), See 4.2.3.3 SENSOR BOARD
UNIT (p.139).
2. Check the Interlock switch, and if necessary replace the
INLK SW ASY (p.146).
3. Check both the SP motor and driver. (Always check both.) Check for a broken fuse on the SP motor 42 V line. Replace the
SP MOTOR ASY (p.156), and/or ROM BOARD (p.137) as necessary.
Epson DFX 9000 Service Manual Troubleshooting Based On Error Codes
Mar 28, 2016 | Epson DFX-9000 Matrix Printer
What does the error message C8 mean?
press the helpful button
found this on fixya by J Mcallister
Heating roller warm-up error 2
?? The heating roller temperature does not reach the ready
temperature for 90 seconds after the heating lamp on.
?? The heating roller temperature does not reach 80°C for 13 seconds
after the IH inverter on.
?? Defective thermistor
?? Defective IH inverter
Related SC code: SC 542
1. Check if the heating roller thermistor.
Ricoh Aficio SP 100SU User Manual Error And Status Indicate On The Control...
Jan 27, 2016 | Ricoh SP 112SU 3in1 Laser Printer
How do I get error code SC2552 off for this printer?
Do you mean SC552? If that is it, then clean the thermistors in the fusing unit. Go into SP Mode, then while in SP Mode turn off the main power switch. It is ready to go.
Dec 08, 2014 | Ricoh Aficio Office Equipment & Supplies
Error code sc545
The Error Code SC542 or Sc546 could be a caused by a few reasons. There is a temperature problem with the fuser unit, the roller thermistor is bad, or the BCU Board is bad.
1 metode to reset Ricoh Error code sc542:
To clear the code:
Hit the yellow "Clear Modes" key
Press 107 on the number pad
Press and hold the "Clear Stop" for 10 seconds until you get a new screen ...
Press the "Copy SP" Button on the display
Open the front door
Turn front left power switch off and on
Shut the door
The error code is now cleared.
To Enter and Exit the SP Mode
1. Press yellow "Clear Modes" key .
2. On the operation panel keypad, press 107 number
3. Hold down red "Clear" key more than 10 seconds.
The Copy SP is displayed.
4. Press "Copy SP" and go to the code SP5810, press "Execute"
5. To exit the SP mode, just press Exit in the upper right corner of the SP mode
screen. Power switch off and on and the error code is now cleared.
Hope this his helps, thanks for using fixya.
Aug 28, 2014 | Office Equipment & Supplies
Ricoh Aficio SP C420dn showing error code sc670. What does this mean?
The code is engine start up error "replace engine board, sorry...
Feb 06, 2014 | Ricoh Aficio Office Equipment & Supplies
How to solution of FUSER TEMP.
my rocoh printer SP 100su show on lcd panal C8 error code . power on .
May 17, 2012 | Ricoh Aficio Sp 1000sf All-In-One Laser...
Hi I have Ricoh Alficio 2032 copier. There is error message C545. what does this mean and how can i solve the problem
Possible causes of your sc545
• Hot roller thermistor is out of position or most likley dirty
• Fusing lamp broken -- not likley
• Thermostat broken -- could be tripped check with a meter for 0 ohms
Once we are sure all fuser components are ok then reset the code by entering sp mode
execute sp 5810
if there is no 5810 then just turn off the machine while in sp modes
Apr 14, 2010 | Ricoh Office Equipment & Supplies
Ricoh 1232c Error SC571
SP 1-930-1 Forces the oil pump to supply silicone oil up from the oil
tank to the tank in the oil supply unit. If the oil end
sensor detects oil in the oil supply unit, this SP will not start the pump.
SP 1-970-1 is an oil removal process mode for the transfer belt.
SP 5-810-1 is a fusing reset but if the sensor isn't working properly, the code could pop up right away.
Nov 05, 2008 | Office Equipment & Supplies
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
