Question about Kenmore Elite Oasis ST 6807 Dryer
Kenmore elite 110.67032600 smells like smoke - Kenmore Elite Oasis ST 6807 Dryer
Kenmore elite front load dryer squeaking and burning smell
you have a bearing in the drum support that has frozen and now the rubber wheel is burning up. The bearing needs to be replaced ASAP. You could damage the dryer if you continue to use it.
Feb 16, 2014 | Dryers
Sour smell in kenmore elite top loader
Try putting a cup of amonia in with your detergent,when you wash.
Jul 23, 2012 | Kenmore Elite 20972
Kenmore Elite Oasis 6806 Electric dryer with burning smell
you must disassemble the unit and clean the lint out of the heating unit area, it is lint catching fire and could be dangerous to continue using your unit in this condition. a vacuum cleaner should do well to clean the lint and the drum must be removed to do a proper cleaning
Apr 15, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
This just happened to our Kenmore Elite -- just as I was about to go to bed I smelled fumes and went downstairs to our kitchen and saw thick smoke and smelled awful fumes. I will contact Sears/Whirlpool...
You WERE VERY LUCKY, indeed. Thank goodness.
With a problem that indeed causes fire and burning, I ,myself wouldn't get it repaired, if i was in a position to repair or replace, i would replace with a nice new one, with a warranty, and, also, it is less likely to have a repeat of what has happened due to the newer technology.
Nothing that "Smells" in the electrical world is cheap...
also if you do anything get a "Quote" first before you start any repair.
Aug 05, 2010 | Kenmore 24 in. 17483 Built-in Dishwasher
Dead fish smell from my Kenmore Elite Bottom Mount Refrigerator
dead fish smell ( under the frig there is a cond pan that collects water from the defrost . whirlpool has some tabs that you can put in pan/ it helps .. I would put a cup of bleach in pan every 3 months . and if you can find the drain inside the freezer add it thorugh the drain . algae builds up in drain and plugs it . mm
Dec 03, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 17483 Dishwasher Caught Fire!
Had the exact same problem (Control panel burning up, sparking, and smoking during wash cycle) last night with our Kenmore Elite DW model 665.16293400 purchased Nov. 2004. I have reported it to the CPSC and www.kitchenaidfire.com and will be contacting Sears first thing tomorrow. It is outrageous that this problem is apparently so widespread with nothing being done about it! I have no doubt my kitchen would have been in flames if I had not been sitting right here to shut off power to the D/W.
Feb 04, 2009 | Kenmore 24 in. 17483 Built-in Dishwasher
My 18 month old kenmore elite oasis quiet pak 2 gas dryer smells as if there were a fire in it!!!!  and ironically, when i noticed the smell i also saw water around the base of the kenmore elite oasis top...
Hello plz make sure the gas burner does not have any lint build up on burner assembly inside the machine / plz clean.That usually causes a burnt smell. If there is no error codes on the display and the machines is operating fine you are chasing a ghost. If there is a pump or motor over load an error code should come up on the display.
Dec 11, 2008 | Kenmore Elite HE4 Electric Dryer
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Oasis ST 6807 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
