Question about AOC Computers & Internet
How do I get my monitor to turn on faster - AOC Computers & Internet
Emachine ET1850 model when turn on no display picture.
Check ALL monitor cables, reseat connections. Have you done any hardware or software updates? Graphics Updates? Do you get anything at boot? Just no signal? It sound like a hardware issue, Graphics. Support for your machine can be found here: http://support.gateway.com/us/en/emac/product/default.aspx?modelId=2064 You could buy a PCI e x16 Graphic Card . Better ,faster Graphics. First, check VGA connections, reseat, check for bent pins. Try another cable and monitor, to verify.
Jan 02, 2013 | E-Machines eMachines Desktop PC
Tip
How to start up faster, via enabling hibernation on your notebook.
Starting up much faster. When your computer hibernate, it stores whatever it has in the memory to the hard drive and then shut down. Once you power up again your computer come out of hibernation and return to it previous stated, and therefore booting up faster.
To enable hibernation on your computer do the following: On your desktop right click then go to properties, once in properties then go to Screen saver tab in there chose monitor power button. Once in the monitor power chose the tap for hibernation, then enable hibernation.
on Jan 21, 2010 | Computers & Internet
I turn on the actuall computer but it does not work i try the keyboard notheing it try the mouse notheing and the montitor does not turn on eithrer
Do any / all of the fans work??
If power supply fan doesn't work then most likely faulty power supply. (Try borrowing one to test)
If it still doesnt work then may be faulty mobo, CPU, ram stick.
If you have to purchase another power supply ensure its a higher wattage than the one fitted. Makes your PC a little faster!!
Dec 20, 2009 | HP Compaq FS7600 17" CRT Monitor
I do not understand why my computer monitor keeps turning off...
Possible overheating problem caused by:
1 Fan motor inoperative - replace
2 Components are caked with dust/dirty - Clean with compressed air and re-assemble.
3 Over clocking the CPU; running system faster than you're supposed to.
Hope any of this helps,
JZ...
Nov 25, 2009 | HP Computers & Internet
Viewsonic Va912b monitor
it seems that there is a problem in the lcd back light or may be in power supply section
Sep 12, 2009 | ViewSonic VA1912wb 19" LCD Monitor
ACER AL1716S 17"TFT Monitor
Hi, Mine was slow all so. I taken the side panel off and blow it out with a air hose. there was so much dust in it.It is running slow as well. It is very quite know and seems to be alot faster as well. your problem you are talking about i'am sure it was like my problem. needs a good cleaning in side.
May 11, 2009 | Acer AL1715 17" LCD Monitor
How to reset dell monitor d1028l
my monitor screen left said black pls ans me faster
Nov 28, 2008 | Dell D1028L 17" CRT Monitor
Samsung LCD 192N After 30 Min or so it starts flikering on & off.
The capicators on the internal power supply are overheating. You could get it repaired or find a way to cool the unit.
May 12, 2008 | Gateway FPD2275W LCD Monitor
I want the laptop monitor to turn off and use a new monitor on the desk
Look to see if the IBM has a FUNCTION key usually FN and F5 press and hold FN key and "Toggle" (press then release) F5 untill only the desktop monitor is displayed.
Mar 18, 2008 | IBM ThinkPad T30 2366 Notebook
Computers & Internet Logo
11 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
