Question about Rhino-Rack 2012-2013 KIA Rio 5dr Roof Rack Crossbars Bars with Locks
Engine light kia
Yellow engine light is on and (!) what does it mean?
Mean car light
Without knowing which year your car is, this is difficult to locate.
Check out http://www.kia.ca/kia-owners-manuals to pick your year and view your Owner's Manual. Note: The light should be mentioned in the "Instrument Cluster" section of the manual (see Table of Contents).
Oct 24, 2013 | Kia Cars & Trucks
Check engine light is on
When the check engine light is flashing it means that the computer has detected a misfire in the engine.It is not good to drive a vehicle that has a flashing check engine light; one or more sensor in your vehicle is advise about an code fault. I suggest scanning for know what code is in there and solve it.
In some vehicles, a red check-engine light means the car needs absolute immediate attention while a yellow check-engine light means you need to make an appointment soon. The light is used to indicate PCM (Powertrain Control Module) problems that are associated with your vehicle's emissions system.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 05, 2011 | 2003 Kia Rio
Check engine light come on after repairs
Hi Cindy:
When the Check Engine Light is flashing ON it means that the computer has detected a misfire in the engine.It is not good to drive a vehicle that has a flashing check engine light; one or more sensor in your vehicle is advise about an code fault. I suggest scanning for know what code is in there and solve it.
Oct 09, 2011 | 2000 Kia Sportage
I have a 2005 kia sorento and a light came on today next to the fuel it is yellow im not sure what the light means
There are many yellow lights on vehicles. They can be different on the same make and model of any particular vehicle depending on what option packages your vehicle is equipped with. Your best bet is to look it up in your owners manual. If you do not have an owners manual, I offer this advise: On all vehicles with the warning lamps in the instrument cluster, the yellow lamp are advisory lamps. ie. telling you that there is a malfunction with a system or letting you know that certain systems have been disabled. It is usually safe to operate the vehicle with the yellow warning lamps illuminated long enough to get the vehicle to a repair facility. (Check Engine Lights, Airbag Lights, Low washer Fluid Lights, etc.)The red lamps on the other hand, mean that the vehicle is not safe to drive before the cause of the lamp coming on has been resolved. (examples are the red Brake Warning Lamp, The Engine Teperature Warning Lamp, The Oil Pressure Warning Lamp.)
Since you stated the the lamp is yellow, I would say that it would be safe to drive the car to your local repair facility and ask them about it and get a professional opinion of what to do about it.
Jan 15, 2011 | Kia Sorento LX Cars & Trucks
A yellow light with the word "check is steadily on
yes thats the check engine light you just need to take it somewhere to get ti checked find out what the fault code is see whats goin on.
Nov 18, 2010 | 2003 Kia Spectra
When the check engine icon appears on, what does it mean?
The check engine light/service engine soon (yellow light) comes only when the computer control unit (called the PCM) senses a fault in the electronic controls of the engine and/or the emission system u will seldom feel the car engine run any different, there are about 200 possible faults that turn the light on, to know what has developed a problem you must have the system tested, this is called an OBD2 fault code test
Nov 04, 2010 | 2000 Kia Sportage
Kia sedona mini van check engine light came on
The check engine light/service engine soon (yellow light) comes only when the computer control unit (called the PCM) senses a fault in the electronic controls of the engine and/or the emission system u will seldom feel the car engine run any different, there are about 200 possible faults that turn the light on, to know what has developed a problem you must have the system tested, this is called an OBD2 fault code test, Kragen and Autozone parts stores do this testing for free.
Oct 28, 2010 | 2000 Kia Sportage
The break icon is on all the time
the red break icon on if your brake fluid level is low also so check the level in your brake fluid bottle in the engine bay.if you have a yellow brake light on it means your brake pads are low get them checked.
Oct 28, 2009 | 2003 Kia Rio
2001 Kia Optima
P1529 and P0720 does not seem to be understood.
P0715 means Input/Turbine Speed Sensor Circuit Malfunction.
P0118 means Engine Coolant Temperature Circuit High Input.
For more understanding visit:- http://www.troublecodes.net/Kia/
Cheers.
Aug 08, 2009 | 2001 Kia Optima
2005 kia sedona ex.
no it has nothing to do with regular oil changes as long as they are done right and frequent. is the yellow light say check engine or service engine soon? if it does take it to advance auto parts or a similiar parts store chain they usually will scan the pcm for free, but with only 24000 miles you should have warranty left on this vehicle if so take it to the dealer to fix at no cost to you.
Jan 21, 2009 | 2005 Kia Sedona
Rhino-Rack 2012-2013 KIA Rio 5dr Roof Rack Crossbars Bars with Locks Logo
372 people viewed this question
Top Rhino-Rack Water Sport Experts
Tom Chichester
Bill Boyd
Are you a Rhino-Rack Water Sport Expert? Answer questions, earn points and help others
