Question about Panasonic KX-T7730 Corded Phone
How to cancel the auto answer/mute on the Panasonic KX-T7633
When I receive an internal call, the speaker phone function imemdiately comes on. I am unable to remove the Auto answer/Mute. Please assist.
SOURCE: I cannot change the time on my phone
from reception phone with phone on hook dial star star 1234
then dial ooo this brings you to the date and time menu
Posted on Feb 23, 2008
  • 14 Answers
SOURCE: can't turn off mute on panasonic phone
[Mute /Auto Answer] is a dual function button.
Mute flashes when it is on and Auto Answer lit solid. Both of these features toggle on and toggle off. Auto Answer will turn on and off during the on-hook condition. Mute is employed during call.
If these lights are not associated with the Mic working, you may have a bad set.
Posted on Jun 27, 2008
cnavarro
  • 2460 Answers
SOURCE: PANASONIC KX-TDA-50 PHONE SYSTEM WITH
From the main phone, press PROG **1234 and dial 004. Press ENTER 2 times (watch out, it moves on the display) and you will be looking at 101 : OPERATOR if it's still unprogrammed. Keep pressing NEXT until you get to the one you want to change and use a combination of the keypad and the AUTO ANS button to spell out the new name. The STORE button saves it, the right arrow and clear button step back and forth on the line you're entering.
You can pick up the handset and drop it back into the cradle when you're done to exit.
Carl
Posted on Jan 21, 2009
SOURCE: This is really silly, but
HOLD DOWN the "M" key which is the "*" key in the bottom left for 3 seconds until you hear a beep.  Repeat if you want mute again.
Jack
Posted on Feb 22, 2009
  • 547 Answers
SOURCE: KX-T7633 Voicemail rings
The Voice Mail feature is set by your phone company, not by the phone. Typically the phone company will set it for 20 seconds, or approximately 4 rings. This is called your voice mail "Ring Cycle"
Call them up (the customer service number should be on your phone bill) and they should be able to increase or decrease your ring cycle for you at no charge.
Posted on Dec 02, 2009
I have Panasonic KX T7633 and I cannot find the ringer switch - please can you tell me where it is
The smart answer is that it's under the 3rd soft key. That turns the ringer on and off. However, it's programmed in system programming via Incoming Call Distribution groups. That's an installer function.
Carl
Sep 14, 2011 | Panasonic KX-T7633 Corded Phone
With the Panasonic KX-T7633 - how do you change the time on the display?
Press Program button
Dial **1234
Dial 000
Press SP Phone Button Twice
Dial Hour (00-12)
Press FWD/DND button
Dial Minutes (00-59)
Press Auto Answer button to select AM or PM
Press Autodial/Store button
Press Hold button
Sep 28, 2010 | Panasonic KX-T7633 Corded Phone
Cancel auto-answer
Uh oh. Here we go. The first command is PROGRAM 21x, where x is 0 for Ring but the button controls, 1 for Voice, and 2 for Ring Only. It's programmed by PROG 21 STORE use the auto answer button to step between settings, then STORE again. The next one is 23. It can force Auto Answer and is normally set to OFF by default.
There are also soft keys and the Navigator button ENTER that make this easier. I have a 7735 phone on a TAW which has a similar instruction set so I don't have the soft keys you have. I guess one of them is SEL for select to replace the Auto ANS button in the above instructions.
Carl
Dec 18, 2009 | Panasonic KX-T7633 Corded Phone
How to change the time setting for the Panasonic KX-T7633 phone?
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook press Program * * or Program * # followed by the system password ( default is 1234). Now press 000 and then ENTER. Enter the last 2 digits of the year and then select the month with either SEL+ or AUTO ANS / MUTE. Now scroll right with the right arrow key and change the date. Now press the NEXT button on the screen and the time will appear. Set the time. Press AUTO DIAL / STORE to save your changes. Lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
Dec 15, 2009 | Panasonic KX-T7633 Corded Phone
Hello i need help with our panasonic kx-t7633. it dials and receives calls, i hear everyone else but they don't hear me. what can i do?
It is most probably one of the rj9 connectors on the handset that is faulty. Try swopping the the cord from the handset to the phone. Most cords should work.
Please rate / vote if this answer helped.
Thank you.
Nov 03, 2009 | Panasonic KX-T7633 Corded Phone
I have a Plantronic headset. I have moved to another location (and phone jack) in my office. The Plantronic headset plugged into the Panasonic KX-T7633 does not get a dial tone. When I go back to my...
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. With the handset on the cradle/hook press Program 61 and ENTER. Press SEL or AUTO ANS / MUTE to change the setting to On. Press AUTO DIAL / STORE to save your changes. Lift the handset and put it down to exit program mode.
THANK YOU
Oct 29, 2009 | Panasonic KX-T7633 Corded Phone
Answer machine
Panasonic KX7633 is a Key telephone set, it doesnot have answering machine function. whereas you may divert your calls toan analog extn.by call forwarding.
Jul 06, 2009 | Panasonic KX-T7633 Corded Phone
Panasonic kx-t7633
On the intercom dial *71x1 where x is 0 for all calls, 1 for outside calls and 2 for intercom calls. *71x0 cancels, or you can just press the FWD/DND button until it goes out.
Carl
May 07, 2009 | Panasonic KX-T7633 Corded Phone
Call forwarding on Panasonic Kx-T7633
I have a KX-T7633 and I want to be able to forward calls to my mobile after approx 3 to 4 rings when not answered
many thanks
Fintan
Nov 19, 2008 | Panasonic KX-T7633 Corded Phone
Can't turn off mute on panasonic phone
Jan 05, 2008 | Panasonic KX-T7453 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
