Question about Mk Diamond MK - 170 Wet Cutting Tile Saw
How to replace blade on Powerbase Excel tree saw
Reg no 4500739186
I need a PBX 17HD - 18 v - POWER BASE EXCEL DRILL charger . Please help to locate the charger from some store ?
www.ebay.co.uk/bhp/powerbase-battery
www.newandused.co.uk/products/view/powerbase-excel...drill/.../nu726
Nov 26, 2014 | Drills
Powerbase spares
Google saw blades or go to Lowes or Home Depot
Aug 18, 2014 | Saws
My poulan 18 inch chain saws blade turns but only cuts in about an inch and won't go any farther. It's two days old and worked fine cutting the first 2 trees down.
It sounds like the chain does want sharpening, it depends on what you are cutting ( type of timber, dirty timber,burnt timber etc ) as to how long before it needs sharpening, if the chain comes into contact with the ground below the tree it will lose its edge instantly.
Dec 29, 2012 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Need a powerbase excel router manual
Hi
I'm pierre from malta. Does anyone has a manual for the powerbase excel router 1250w?
Nov 20, 2012 | Computers & Internet
New blades for powerbase planer
'Guest' is looking for help with a Powerbase planer - giving him instructions for Makita and DeWalt is hardly likely to help!
I too have a Powerbase and need to find the manual - anyone?
Aug 05, 2012 | Tools & Hardware - Others
I am going through my husbands tools. We have a Ryobi Saw-all and I notice it has different blades. I can not find the manual. I simply want to change the blade for cutting iron that is currently inserted...
To change blades, a hex-wrench is required and you simply tighten or loosen the allen screw that holds the blade, but unfortunately the saw's design is a bit flawed. It takes a bit of "feeling around" to locate the proper position for the blade changing wrench because the fitting is not visible through the rubberized boot. You can certainly trim and prune trees with the saw, but make sure that the branch is at least 10% thinner than the length of the blade. I do not know your Manzanita tree, but if the wood is wet it should present no problem. Any power saw is extremely dangerous if used at an elevated height like on a ladder. If the ladder slips, there seems to be an almost unnatural tendency to grab for the saw and very often the moving blade. Take the utmost care at all times with power tools. (I have a friend who point blank refuses to use a chain saw unless both his feet are firmly planted on the ground, and he is over 6 foot).
Apr 21, 2011 | Garden
The saw blade does not engage when trying to cut
Probably shot. You could buy parts, but now worth the time. Probably stripped the gears.
Jul 02, 2010 | Dewalt DC385B 18v. Cordless Bare...
When i try to do a horizontal cut my saw seems to bite in for a start, but then just runs free in the tree not taking a bite or drawing the saw in, this has also happened with 45% cuts, is this my own...
Sawing with a chainsaw is mostly 2 part, a sharp chain and good technique.
If your bar is straight, your chain is razor sharp and the oil reservoir full then it boils down to technique.
You cannot run a chainsaw through horizontally on a big tree, what will happen is half the time the tree's weight will begin to collapse upon the bar and pinch it in the tree and you will not be able to saw any further.
You will notice that when felling a tree the vertical cuts are always problem free because gravity pulls the off-cut away from the saw. With horizontal cuts fire your blade in at an angle, and in cut in the direction the tree (or whatever) is likly to fall. As you cut rock your blade to help it bite into the wood and resist jamming. If your chain jams do not keep on the gas for you will burn out the clutch.
For an awkard cut instead of feeding it right through cut towards the middle to create a notch, then cut from the other side, the weight of the tree will fall on the cut portion leaving your blade free to slice through.
Just think logically and make sure that the blade can feed through without getting pinched, this is well represented if you get a log and support both sides then cut vertically in the centre; it will get pinched imeediatly. Now cut from the underside and it will fly right through.
This is difficult to describe but plan your cuts and test it out.
Cheers,
Kevin
Feb 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Cannot see how to fit blade on Powerbase jigsaw with screws at front - recess does not seem big enough to contain blade provided.
Plate can be lifted up with end of blade to reveal nevessary size of opening. Blade can then be inserted and tightened satisfactorally.
Dec 15, 2009 | Saws
Mk Diamond MK - 170 Wet Cutting Tile Saw Logo
41 people viewed this question
Top Mk Diamond Saws Experts
JonSnell Electronic
JonSnell Electronic
Regalo Tiles
Are you a Mk Diamond Saw Expert? Answer questions, earn points and help others
