Question about Konica Minolta magicolor 2400 Laser Printer
I do not know how to change the black ink on a monolta 2300 ?
Only the black ink cartridge is out of ink. The other colors are ok. I can see and I can take the blue ink cartridge out but I can not figure out how to get to the black ink cartridge.
Please help -- give me directions how to change the black ink cartridge.
Do I turn it or move it some how -- or what -- just can not figure out how to change the black ink cartridge.
Robert
  • rlm1822 Jun 23, 2009
    the link that was given said "web page can not be found" so it was not helpful at all.
    Can you tell me how to get the correct link?
  • 909 Answers
Http://crm01.konicaminoltaeurope.com/openmind/technic/engineer/qmspubkb.nsf/0/70744652a954e650c1256f820078e0a2/$FILE/MC24x0-Replace%20Toner%20Cartridge.pdf
Goto the above link and it shows the PDF doc. for changing the cartrides.
Posted on Jun 23, 2009
  • Paul Hutchinson Jun 23, 2009
    http://www2.konicaminolta.co.uk/more-inf...
    Try this one, I was trying to save the hastle of clicking all the links etc.
    Didn't realize that you had to go in from scratch.
Filling ink
The cartridge have chips if they are not replaced then the copier /printer still thinks the cartridges are old
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 05, 2014 | Konica Minolta Office Equipment & Supplies
I am having problem on how to change the ink cartrdges. I can't get it to go to the center to be able to change the ink. Pls. help
hi,
following images and steps may guide you.
first know the parts.
Tear open the black ink cartridge bag at the notch and remove the ink cartridge.
IMPORTANT: Insert the ink cartridge immediately to prevent any drying of the ink.
Remove and discard the orange cap.
IMPORTANT: Handle ink cartridge carefully to avoid ink transfer.
Insert the black ink cartridge into the printhead. User's
Press down on the ink cartridge until you hear it snap into position
Tear open the color ink cartridge bag at the notch and remove the ink cartridge.
Insert the color ink cartridge into the printhead
Press down firmly on the cartridge until you hear it snap into position
Close the printer access door.
regards,
cseian
Feb 16, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
I've just changed the black ink cartridge on a canon mp140 without changing the colour one but it still won't work. Do i have to change the colour one too because i only want black?
Hi both of the ink cartridges need to have ink in if one is empty then it just wont work, a lot of people think they can just replace the black but find out they need to replace both to be able to use the printer, their is no way around this and their are no settings you can change to turn the color ink off,
sorry their is no easy solution but without replacing the color as well it just keeps giving you warning and wont allow you to print anything
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 01, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
Won't print black
chack your balck cartridges may be it's finish just tak out seak that will fome to know is the ink of finish
relpace that it will work fine
May 10, 2010 | Brother MFC 490cw Color Inkjet...
The printer will print ok in color, but will not print black ink. No copy or printing.
My best guess without knowing more is that your printer has both a color print cartridge and a black ink print cartirdge. Replace the black ink cartridge and you should be fine. You might also find that replacing the entire printer is less expensive....All the best!
Nov 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Ok I have a cx8400 all-in-one Epson printer. I was out of black ink so I started using composite black. Also ran out of color ink so I bought the black cartridge and installed it. Now the printer says i...
If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until a cartridge needs replacement. You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expendedI have come across this issue many times and unforunately you have to replace the colour carts in order to continue to use the printer.
Sep 12, 2009 | Epson CX8400 All-In-One InkJet Printer
"Remove and check color cartidge."
ok the problem is very common.initially remove both the cartridges.then unplug the printer from main outlet and plug back in.this will reset the printer circuit.then after u on the printer bring back the cartridge carriage to cartridge installation position.then first clean the circuit in the carriage that touches and sense your cartridge circuit with a damp cloth.both colour and black carriage circuit.then clean the cartridge circuit too even if its new.then install both the cartridges and close the door and off the printer again and on it after 30 seconds atleast.then check it should work normally.
Mar 25, 2009 | HP PSC 1610 All-In-One InkJet Printer
IP90 stopped printing black
if ink is ok than have to change print head for black cartridge
Dec 16, 2008 | Canon PIXMA iP90 InkJet Printer
Color Ink Cartridge Problem
Unplug the printer, and leave it unplugged for 5-10 minutes. Then if the printer is still complaining about the color cartridge when you turn it back on, then replace the print cartridge.
David
Dec 04, 2008 | HP Photosmart 2575 All-In-One InkJet...
Cartridge problem
Basically, you placed a black ink cartridge [30] into the compartment for the color one [31]?
Make sure you have a black ink cartridge in the left compartment, and a color one in the right one. I don't even think it would properly fit if they were in the wrong slots. They should "click" into place, confirming that they're installed properly.
Sep 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Konica Minolta magicolor 2400 Laser Printer Logo
232 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
