Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
Grass trimmer is making a grinding noise - Black & Decker 14" Grass Hog Xp Trimmer/Edger
2 Suggested Answers
rycgl
  • 1545 Answers
SOURCE: how to put together a black n decker grass
No, it is not heavy duty enough to drive a blade. It should have cuttting line in it and it only can use up to .065" string (factory recommended).
Posted on Oct 12, 2010
I used it yesterday and today it will not start. Battery is full charge. Button key is in place.
I would first take a meter and test that the battery actually charged. If that tests out fine ( should read at about 12.8 to 13.5 Vdc), I would then check all the wired connections to make sure they did not come loose.
Jul 19, 2015 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
The trimmer makes weired noise and a burning smelly
The obvious is that you have something around the head and it is burning or the bearing in the head is stuffed. Go and buy a new head it would be easier to this then replacing the bearing.
Jan 23, 2015 | Garden
Black decker problem
Be sure something is not obstructing the rotation of the trimmer head. If something like a small vine or twig is jammed inside the head it would make a noise and have very little rotation. If the motor brushes were worn you might get the same symptoms.
Aug 23, 2014 | Garden
There is a grinding noise when i make a sudden stop or go in reverse.its a hydrostatic transmission
ck and clean off the cooling fan on top of transaxle sometimes grass and leaves get up there and make funny noises also you can ck oil level in transaxle for proper fill level
Nov 11, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Tanaka tht 2100-very difficult to start. Pull cord is is either too loose when pulled or it is jumpy, meeting with a bit of resistance?
i think it sounds like the motor is going i had a chainsaw and it did the same thing after a while the motor went and the chainsaw was no good anymore so you mite want to take it to a dealer that deals with your grass trimmer
Sep 03, 2012 | Tanaka Commercial Grade "Inspire" Design...
Grinding Noise from Trimmer
with a strieght shaft trimmer there is a gear at the trimmer head that gear could be bad if it has a arched shaft then its driven by a cable if you spin the head by hand while without it running you might feel some roughness
Jul 28, 2012 | Garden
Just bought a brand new Husqvarna 224L Trimmer. Started it up and it runs fine. But the trimmer head will not turn. It just makes a grinding noise. The manual that came with the trimmer is useless. It says...
Hi, take it back to the dealer as the powered or gear box have not been fitted correctly. The noise you can hear is most likely the clutch drive grinding on the drive shaft. Hope this helps, regards Phil.
Jul 21, 2011 | Husqvarna 28cc Gas Line Trimmer
How to respool the line on grasshog electric grass trimmer
The empty spool can be refilled with 30' of size .065" nylon line. Make sure you run the line in the direction of the arrow embossed on the spool.
Sep 06, 2010 | Black & Decker 14" Grass Hog Xp...
My Grass Hog won't start properly.All it does is make a hissing sound and NOT trim like it should.What should i do to get it working properly?
Having sound usually means grass is bound inside, or a stripped plastic gear. No sound is thermal link expired.
Apr 11, 2010 | Black & Decker 14" Grass Hog Xp...
Head of trimmer/edger doesn't spin
i have the same problem, the plastic timing pulley on the motor assembly is probably melted, remove all the screws down the side of the housing, including the one hidden under the label, and you will find that the belt and the pulley are both chewed up.
Apr 18, 2009 | Black & Decker 14" Grass Hog Xp...
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
64 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
