Question about Photography
Gigaware digital photo frame..My digital frame does not continually play, when it gets to the end it stops and shuts down?
SOURCE: Matsui 7" digital photo frame
I got one for xmas and pics download easily every time. I connect my camera to the laptop then load the shots I want onto the SD card on the camera, disconnect and remove the SD card from the camera then insert in the frame. I have had no problems with photo size or downloading time. I do have a problem when I remove images from the SD card however. The frame still displays images that I deleted and are not showing when I connect to the laptop!  Can anyone help?
Posted on Jan 07, 2008
SOURCE: 7" Trutech digital photo frame Calendar
Use the Navigation Buttons to select "Calendar"; press Enter to confirm. To set the date, press the Stop Button and then use < and > Buttons to adjust the year and the arrow down and ^ buttons to adjust the month; press the Stop Button again to confirm. Then, use the Navigation Buttons to select the current date on the calendar display and press Enter to confirm. To exit press the Menu Button.
Posted on Nov 09, 2008
leepania
  • 1099 Answers
SOURCE: why does kodak digital photo frame shut it self
There is a safety feature so the frame won't overheat.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Oct 15, 2009
benj888
  • 47 Answers
SOURCE: Trying to put I-DVD movie on my digital photo frame
Re-edit the movies and pictures following the formats below: Video:
File Format: MOV
Video Compression: MPEG-4 ASP, MJPEG
Audio Compression: MP3, G.711, PCM, ADPCM, 8-bit linear
File Format: AVI
File Format: MPG / MPEG
Video Compression: MPEG-1
Audio Compression: MPEG audio Picture:
File Format: JPG / JPEG
Video Compression: Baseline JPEG
Music:
File Format: MP3
Video Compression: PCM, ADPCM, MPEG 1 layer 1,2,3
Posted on Jan 04, 2010
nicdoy77
SOURCE: PF-A700B Digital Picture Frame: Hi i have a Mustek PF-A702B digital photo frame an...
have you tried formating your SD card to FAT32 format?
Posted on Jun 19, 2010
How do i down load my photo&#39;s from my coumpter to the fram
Your photo frame must have come with a USB cable. Plug the larger end of that cable into a USB port on your computer and the other end into the photo frame. Turn on the photo frame (your computer should already be on). A dialogue box will pop up. Select to continue. Open up Windows Explorer. Your photo frame will show up as a "Removable Disk". Still in the Windows Explorer, go to the directory on your computer where you have the pictures you want to transfer. Select the pictures, right click on them and select 'Copy' from the menu that pops up. Go back to the photo frame (the Removable Disk), right click on it and select 'Paste' from the menu.
Dec 12, 2014 | Audio Players & Recorders
How do i troubleshoot gigaware 8' digital photo frame? it will only read one photo off the SDHC card 16gb that i put into it. i can read the card on my computor.
Some picture display frames will only handle files below a certain size and of certain types. Check your manual for the gigaware to see what those restrictions are. It may be that you will have to reduce the resolution or size of the photos or make sure they are all jpeg.
Oct 19, 2014 | Cameras
PANDIGITAL Digital Photo Frame works perfectly except the SCREEN Flickers Black after a few moments
Annemarie, I had a similar problem with an off-brand photo frame from Wal-Mart last year, although in my case the frame would shut down entirely after it had flickered a few times. In my case, I was able to remove the back of the frame's case by removing 4 screws (two were hidden underneath model number stickers) and inspecting the device's innards... what I found was that, as you surmised, there was a loose connection from the female end of the DC-in power supply. The ground connection to the device's circuit board had been poorly soldered, leaving the connection itself loose and a small piece of solder on top of the board and very near the positive connection.
While not being the best solderer in the world, with the aid of a magnifying glass, a solder removal tool, and a ColdHeat soldering wand, I was able to heat the offending piece of solder and remove it from the circuit board and then, as I was personally uncertain of my ability to re-solder the connection without melting the board, I simply held the connection in place and applied a dab of hot glue to keep it there. After the glue cooled, I reassembled the case and the frame worked for almost another year before something else finally burned out and it was left cold and dark.
Hope this helps, good luck!
Dec 03, 2013 | PANDIGITAL 7-Inch Digital Photo Frame with...
Cannot down load pictures to frame from computer
The following instructions should be able to help you transfer pictures/images and music from your computer to the frame.
Power ON the frame.
Connect the small end of the USB cable to the USB port on the side panel of the Digital Photo Frame.
Connect the larger end of the USB cable to the USB port on your computer.
You will see some extra "Removable Disc" drives in "My Computer" -- One for each of the memory card slots on the Digital Photo Frame. And the last one is for the Internal Memory of the frame. Double-click on the last "Removable Disc" icon to access the internal memory of the frame. From here you can copy images and music files to the frame. You need to transfer the images or music files into this folder (which is the internal memory of the frame). Copy the files from your computer and paste them in this folder.
The picture files should be in the "standard JPEG" format and the music files should be in the "mp3" format.
To disconnect the Digital Photo Frame from your computer:
In Windows, on the bottom taskbar, right click the icon which appears in a green color, (this icon has an arrow pointing towards the left) and select "Safely Remove Hardware".
The Safely Remove Hardware" dialog box will appear. Select "USB Mass Storage Device" and click "STOP"
On the next dialog box, click "OK" to remove the storage device.
On the next dialog box, select "CLOSE" and disconnect the USB cable from your computer.
Now you should be able to see the pictures on the digital photo frame.
Thanks.
Mar 13, 2011 | Coby DP-772 Digital Picture Frame
How do i download photos from pc to digital photo frame
1. Connect the digital photo frame to an available USB port on the PC. Turn on the PC and the digital photo frame. Connect one end of the USB cable to the USB port on the digital photo frame (this end is usually smaller) and connect the other end to the USB port on the PC itself.
2. Wait for the PC to automatically detect the USB-connected digital photo frame.
3. Move any photo files that you want to display on the digital photo frame. Do so by copying and pasting each file into the connected USB device that you can view in "my computer". Many photo frames have built-in memory for this feature.
Jan 07, 2011 | Microsoft Computers & Internet
My Kodak Easyshare 1011 has recently started to turn off
The firmware of your digital picture frame needs to be updated but since you can't do anything because after a few seconds the frame will shut down it needs to be send for repair. To process repair visit www,kodak.com/go/itg. Follow the troubleshooting guide page and at the end of the troubleshooting guide you will be able to fill up a form to send frame for repair.
Jun 06, 2009 | Kodak EasyShare EX1011 Digital Picture...
Download mp3 music
Power ON the frame.
Now you can play.
Good Luck.
Live, Love, Laugh.
May 12, 2008 | Audio Players & Recorders
Linx Digital photo frame can't get the frame to play pictures continuously.
Change the settings from the options !!
or edit the image be4 sending to frame !!
Mar 09, 2008 | Cameras
Photography Logo
59 people viewed this question
Top Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Photography Expert? Answer questions, earn points and help others
