Question about Xerox FaxCentre 1008 Plain Paper Laser
Press * in xerox fax machine FC-335 - Xerox FaxCentre 1008 Plain Paper Laser
Xerox 1000 print engine fault codes 42-334 & 42-335
You can google this information or call customer service from xerox
Jan 11, 2014 | Office Equipment & Supplies
Phone line and fax machine
ou may have inadvertently changed it from "Auto Fax" to "Manul". From the Xerox knowledge base website at:
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=12,E=0000000000022752235,K=612,Sxi=13,Case=obj(18044)
Print the fax received in manual mode by:
When a fax is received, your machine sounds the ringer. Then you will hear a fax tone. Press On Hook Dial and then Start Copy/Fax. The machine prints the fax and returns to Standby Mode when the reception is completed.
To change back to "Auto Mode", follow the instructions at:
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=53,E=0000000000022752268,K=612,Sxi=14,Case=obj(18040)
Jan 07, 2014 | Xerox Office Equipment & Supplies
How to change the time on a phaser 3635
To Set Date & Time on a Xerox 3635
Press: Machine Status (hard button)
Press: Tools (on touch screen)
Press: Device Settings (on touch screen)
Press: Set Date & Time (on touch screen)
The machine will have tabs at the top
Press: Set Date
Press: Month
Enter the Month: (Using the hard buttons)
Do the same for Day and Year
Press: Save
Press: Time
Same procedure as above setting the Date
Press Save
Turn the machine off and back on for settings to take effect.
Dec 20, 2012 | Xerox Phaser 3635MFP/X Multifunction...
Ixerox DocuPrint 340A Please check the machine (006-335)
I have Fuji xerox docuprint 340a.
but It doesn't work with a error.
The error is 006-335(reboot the printer)
I did what printer said, It goes again.
What can I do for this printer?
Feb 27, 2012 | OKI B6300n Printer
I would like to block all incoming faxes on the faxcentre f110 so that it is an outgoing fax only, how do i do this?
You don't really need to block incoming faxes, but just set the machine not to automatically answer them. This figure is from the manual:
Press the MODE button until you see MANUAL displayed. In manual mode you need to answer and start receiving a fax yourself from the machine.
You can download a copy of the user manual from Xerox if you need it.
Dec 17, 2010 | Xerox FaxCentre F110 Plain Paper Laser
Xerox Work Center 657 Will Not Recieve, After Replacing Drum
Check to see if when he reset the fax reverted back to receive only as a default.
  1. Press [Menu] (the Up arrow key), and press [3], [1], [0], then press [1].
  2. Select the Answer Mode:
    • Press [1] to select Auto answer, then skip to step 3.
    • Press [2] to select Manual answer, the press [Stop] to return to the Standby mode.
  3. If you select the Auto answer feature, use the numeric keypad to enter the number of times (must be 2 digits, 01-10) the phone must ring before the machine answers, then press [Enter].
    NOTE: When the machine is set to Auto answer and the set number of rings occurs, the machine answers with a fax signal tone and enters the Auto Receive mode.
  4. Press [Stop] to return to the Standby mode.
Jun 30, 2009 | Xerox WorkCentre Pro 635 Laser Printer
Xerox Phaser 3200mfp Memory Issue
Do you have the receipt for the machine? You have a 1 year warranty from Xerox on that machine, Here is the copy and paste from the warranty information on the Xerox website.
Xerox warrants that the Phaser 3200MFP product and its Consumables, Routine Maintenance Items, and Options/Upgrades (related items) will be free from defects in materials and workmanship for the periods set out below:
Product: a period of one (1) year from the date of shipment.
Aug 21, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Fax machine
just place documents into feeder, using the keypad, dial the fax number and press the start or send key.
Thank You,
Mikey
Apr 04, 2008 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Xerox FaxCentre 1008 Plain Paper Laser Logo
29 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
