Question about Fargo Pro L ID Thermal Printer
Why Fargo Pro L is not feeding card and always saying a card jam
SOURCE: Fargo Pro-L error message Mag Jam.
iT MEANS MAGAZINE JAM AS IN "MAGAZINE FOR CARDS"
Posted on Aug 12, 2008
SOURCE: Card Flip Jam Error message
Open the left hand top cover, In between the ribbon rollers you will see a small flipper, ( small piece of metal with a wheel stuck on one end. ) Maually turn this so the grey wheel is on top and white smaller wheel on the bottom.
This ocassional gets jammed and need righting manually.
Posted on Aug 14, 2008
  • 526 Answers
SOURCE: Fargo 4250 card printer runs, but doesn't print.
take the ribbon out, and rewind it a little bit and see if you see print on it. if you dont, chances are your printhead is either bad or has loose cables going into it.
if you do see print, either your card is not aligning properly or the head lift motor might not be working (when the unit on, open the door, and press both buttons at the same time and see if the printhead does an up and down motion), platen roller is bad
Posted on May 31, 2009
  • 5 Answers
SOURCE: Fargo Pro-L Not Printing Edge-To-Edge
These direct-to-card printers do not print right to the edge because of the way the print head comes down on the card. There will always be a white boarder on the card especially if your graphics are dense. The only solution to this issue is to re-design your artwork so that the image fades at the edges of the card so the white boarder is not obvious, or purchase a re-transfer printer which will give you true over the edge printing.
Posted on Jul 20, 2009
benwabnick
  • 2404 Answers
SOURCE: I need fargo pro L printer driver for windows 7
According to the Fargo Website:
http://fargosupport.com/archive_results.asp?archPrinter=5&archSubmit.x=42&archSubmit.y=5
The drivers only go as high as windows xp for now. Hopefully since Windows 7 is coming out soon that they will have a driver available for it shortly.
Posted on Aug 15, 2009
My fargo Pro L is not laminating and always says lam adjusting
Try Updating the firmware on the printer and the lamination module.
Go to HIDglobal.com. Under the support tab, click drivers & downloads. Populate the drop down menus with make and model.
The most recent software is shown here. Go to the section "Misc." and download Fargo Workbench. This utility enables you to update the printer by automatically pulling the most recent version off the Manufacturers website. Very Useful.
Oct 07, 2014 | Fargo Pro L ID Thermal Printer
ALWAYS SAYING CARD JAM
blank cards not inserted properly - tray out of alignment
Oct 19, 2013 | Fargo Pro L ID Thermal Printer
May 12, 2009 | Fargo 4250 Thermal Printer
My DTC 400 bladge printer jams a lot.
The DTC400 has an o ring that drives the card feed rollers. Fargo has had a problem on older DTC400 printers with the o ring stretched or broke. This causes irregular feed roller issues, ribbon breakage or misalignment of print registration.
It is recommended to do a ribbon sensor calibration. This can be done through your print driver using the directions in this link.
Your DTC400 came with a two year manufacturer warranty. Contact Fargo Technical Support at 800-459-5636.
For more information about id card printer systems, visit our website at www.safecardid.com
Nov 13, 2008 | Fargo Office Equipment & Supplies
Card hopper jamming
Could be that your cleaning unit is not installed or is old. Or, it could be too few cards in the card hopper. You could apply a little weight to the cards in the hopper to see if that helps. And/or try changing out the cleaning cartridge.
Oct 04, 2008 | Fargo DTC520 Thermal Label Printer
CARD JAM: MAG
SOLUTION = WRONG DRIVER.
I had the Pro-lx drivers installed for a Pro-L and once I found the Pro-L drivers, I deleted the other drivers completely and uninstalled the printer and redid it with the right drivers and it works perfectly.
Aug 12, 2008 | Fargo Pro L ID Thermal Printer
Aug 04, 2008 | Fargo Pro L ID Thermal Printer
May 29, 2008 | Fargo Pro L ID Thermal Printer
Dec 14, 2007 | Fargo Pro L ID Thermal Printer
Fargo Pro L ID Thermal Printer Logo
27 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Level 1 Expert
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
