Question about Dishwashers
Manual bosch sgs 43
At the end of the wash leaves a white halo on the pots.
  • 3 Answers
SOURCE: BOSCH DISHWASHER SGS 6312GB/13 , FD 7810
I had a similar prob with my Bosch SGV53E23. Turned out the cold water feed pipe at the back had a v. slow leak which was caught by the plastic moulding and channelled into the machine base. Slowly filled with water and ended up continuously running the pump - even with the door open! Fixed leaking pipe = fixed problemo.
Posted on Mar 01, 2009
Macmarkus
  • 2605 Answers
SOURCE: My Bosch dishwasher(model # she44c02uc/43) extended wash/no drain
The issue with your Bosch dishwasher likely lye`s within`the electronic timer/control. A faulty flow switch, ntc or heater can also cause this, but not very probable.
If you feel capable there`s a way to visually inspect the control. It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s at "1" ( because it can`t heat to advance or until canceled ) trying to heat the water.
**Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.**
Hope this answer`s your question, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution and leave a testimony to it`s success or failure, but I`m 99.9% certain ;)
Good luck.
macmarkus :)
Posted on Feb 24, 2010
  • 120 Answers
SOURCE: Dishwasher takes too long on cycle
This sounds like a heating problem. The cycle will not advance if the water is not up to the proper temperature.
Next time you run a cycle, open up the door after a few minutes. A large ball of steam should roll out of the machine. No steam = no heat = no timer movement.
The most common suspect for repair is your heating element. The fix may be a simple as a loose or broken wire leading to the element.
The element itself may also be bad. This is easily checked with a multitester. Set the tester to ohms or resistance. The element should have an actual reading. A result of zero or infinity or overlimit is not acceptable for your heating element. It should then be replaced. Good luck
Posted on Apr 20, 2010
  • 3247 Answers
SOURCE: Bosche dishwasher serial no, SGS
Are you please able to provide the actual model no. of the bosch dishwasher. The serial no. is not much help.
The reason it may not be admitting water is because the flood switch may be triggered. This means it will not take any more water and the sound you hear is the pump running to empty the dishwasher. YOu will have to find why the flood switch is turning on. Are you using the AquaSafe circuit in the dishwasher inlet circuit? If water is leaking then this circuit will trigger and stop water from coming through inlet. But then you should also get some alarms on the display.
Please provide the model no.
Posted on Sep 30, 2010
BElectric
  • 1140 Answers
SOURCE: I need a user manual
Hi -
You can download the user manual and other documentation for the SGS5332 direct from Bosch by clicking on the following links:
Instruction Manual (PDF file in English)
https://portal.bsh-partner.com/TCcustomBSH/controller/download_file?PDFOBID=njipkrecdcso0mchdb---eq1&UMOBID=njsrrvbcdcso0mchdb---eZT
Installation Instructions (PDF file - multi-language)
https://portal.bsh-partner.com/TCcustomBSH/controller/download_file?PDFOBID=qfenhVacdcso0pdmdb---jEd&UMOBID=qfenhXbcdcso0pdmdb---jEd
To download the files, click on each link and choose "Save" from the File Download box. You will need to have Adobe Reader installed on your PC to open the files:
http://get.adobe.com/uk/reader/
Hope this helps. If you need further assistance, please let me know.
Regards,
BElectric
Posted on Mar 21, 2011
I put slightly soiled whites on super temp boost and power wash and they do not come out clean. This is my second Bosch washer. The first was fantastic, but this washer is the pits!
well Try this to get the whitest whites aside from Javex and detergent you can use an old method that also removes oil spots from white table cloth we all have some of those at one time or other , the way is to fill a pot of water and slice a couple lemons to be added to the pot put your whites in the pot and bring it to boiled ,turn the heat down and simmer for 15 minutes, turn the stove off and leave the whites soaking in the pot until the next day than wash them in the washer with just detergent , another solution would be to hang the whites outside the sun rays will bleach them , but at this time of the year unless you live in a warm climate they will freeze like cardboard it happened a few times in the past but I must admit that they smell very fresh and yes they are white and stiff. So I just bleach and boil the stubborn stains for now !Cascade?] and place water with dissolved cup of powder in a clean bucket, place white items ONLY in this bucket & allow to soak for a day or two...THEN wash the items white ONLY in your regular warm/hot cycle! Doing this will keep whites white! It works!
Oct 04, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Apr 20, 2010 | Bosch 24 in. SGS43E02 Exxcel Built-In...
My dishwasher uses a compartment of rinse aid each wash
The cheapest and easiest option is to stop using rinseaid and use an allinone tablet instead.
Jun 14, 2009 | Bosch Dishwashers
Brown, rust-like marks on washing
Hello I got a Bosch ClassXX5 and got the same problem, white clothes seemed Grey and some clothes seemed washed but not perfectly, until I discovered that the washing machine did not heat water anymore; after the end of the wash cycle the clothes were cold as the program was initially setup to 40C°.....
I used to think soaps were not up to the task and changed brand often, sadly a Bosch product letting me down was not on my mind, since that brand for me was above the rest, quality, strong, during in the time, having electric tools from Bosch without any problem for years!
Oct 11, 2008 | Bosch Classixx WFL 2066 Front Load Washer
You have a leak underneath and it is switching the anti flood switch on. Tip the dish washer back at a 45 deg angle, you will probably get water teak out the back, stand it back upright and try it. although it will probably work you will need to look underneath and find where the leak is coming from, my guess is its the wash pump and will cost around 100 pound for an engineer to repair.
Dec 02, 2007 | Dishwashers
Dishwashers Logo
26 people viewed this question
Top Dishwashers Experts
