Question about Acer Aspire 5500 5570-2609 Laptop
Turn off key board sounds - Acer Aspire 5500 5570-2609 Laptop
  • 20 Answers
Go to the right side of the
computer at the bottom by the time you will see inverted v's.Click there and you will see a side view of a speaker.Click that and you can regulate the volume.This is the simplest ..
Posted on Mar 04, 2015
1999 lincoln navigator turns over won't start dash board lights stay on with key out.
sounds like antitheft system is acting up..needs reprogramed maybe..pull the negative cable with the key on....kills everything..then shut the key off..reconnect the negative.. turn the key to run position for a few seconds(resets all factory presets) see if it will start..
Feb 10, 2013 | 1999 Lincoln Navigator
My lenovo G560 model 0679 makes continous weird loud beep sound at startup of windows 7 o/s
if you still have your display with this beep sound it must be your key board is damaged. because when you turn on the laptop in your key board have a button is automatically holded. so just remove the key board and clean with a experienced person.thank you.
Sep 10, 2011 | Computers & Internet
I left my finger on shift key to long, I think, it seems to have switched off my keyboard. so all I can use is an on screen one. I tried restarting and it lets me use the keyboard for password then it...
PRESS THE KEY BOARD FOR SOMANY TIME YOU CAN HEAR A SOUND FROM YOU SYSTEM.SOME TIMES AFTER THE SOUND WILL DISAPPEAR NOW YOU CAN USE YOUUR KEY BOARD
Aug 20, 2011 | Acer Aspire 3000 Notebook
Audible alarm sounded--"F2 "appeared on
Your model is actually a 911. Roper (Whirlpool)
The F2 error code is
E0 - Shorted keypad (also called touch pad)
E1 - Keypad cable unplugged
E5 - Cancel key drive line open
E6 - Cancel key drive line open
Solutions:
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Jul 30, 2011 | Ovens
No audo device
Please follow the following steps to rectify this problem :
Step 1 .Reset the default BIOS settings:
You can try resetting the sound default in the BIOS. Here's how:
1. Turn the PC on. When the Windows logo first appears, press the F1 key or Dell key repeatedly until you see the BIOS setup screen appear.
2. Press the F5 key ( Setup defaults). In some other PCs depending on the manufacturer the BIOS at start-up will have one of the default options that have names such as - ‘Load Fail-Safe Defaults’ and ‘Load Optimised Defaults’.You will have to choose ‘Load Optimised Defaults’
3. Select Yes or OK, then press the Enter key on your keyboard.
4. Press the F10 key, then select Yes or OK to save the default settings. Press Enter.
5. Exit the BIOS and restart your system checking for sound.
( For most PC's entering the BIOS will be the same but if it differs for your system, consult the operating manual for instructions on entering the BIOS.)
If this doesn’t work go to step 2
Step 2 . Configuring on-board sound in the BIOS:
Some computers come with sound on the motherboard (on-board), and some computers use a sound card. The on-board sound setting in the BIOS has to be set according to your particular sound configuration. Perform the following steps to correctly configure the sound in the BIOS:
Look at the back of your computer and use one of the following three items to determine the proper sound configuration and sound setting:
If the plugs for the speakers and microphones are located next to the parallel, serial, or USB ports, then the computer has on-board sound. The on-board sound setting in the BIOS should be Enabled. If the plugs for the speakers and microphone are located away from the other ports and sit in an area by themselves, the computer has a soundcard. The on-board sound setting (if there is one) in the BIOS should be Disabled. If the computer has sound plugs in both locations, a
soundcard has been added to the computer that already contains on-board sound. The on-board sound setting should be Disabled. To enter the BIOS, turn on the computer and when the first screen appears, press the F1 key /Dell key repeatedly until the BIOS Setup screen opens. Use the LEFT and RIGHT ARROW keys to select the Advanced tab. Press the DOWN ARROW key to select Onboard Audio Options and press ENTER. If Onboard Audio Options is not available, select I/O Device Configuration and press ENTER. If Audio Codec is listed, select it and press ENTER. Select either Enabled or Disabled depending on your configuration and press ENTER. Press the F10 key and then press ENTER to save and exit Start Windows and check for sound. If there is still no sound, continue to the next Step.
Step 3 . Reload the current sound driver
To do this, follow these steps
1.Click Start, type Device Manager in the Start Search box, and then press ENTER.
2.In the Device Manager dialog box, expand Sound, video, and game controllers.
3.Locate the audio device that was included with the computer.
4.Right-click the device, and then click Properties.
5.Click the Driver tab.
6.Click Uninstall.
7.Make sure that the Delete the Driver Software for this device check box is cleared, and then click OK.
8.In the Device Manager dialog box, click the Action menu, and then click Scan for hardware changes.
You should see a message that a hardware device is being installed. Additionally, the uninstalled audio device is now present in Device Manager.
9.Close the Device Manager dialog box, and then determine whether you can hear sound.
If your computer came with a motherboard CD, the audio drivers should be on the disk.
If you don’t have the CD go to your computer manufactures web page to search for updated sound driver software. Read the instructions on the download pages carefully
before installing.
If there are no updated sound drivers available, use Microsoft's Windows Update feature. Connect to the Internet and try the following items until Windows Update opens:
1.Click Start, and then click Windows Update (if it is listed).
2.Click Start, click Settings, and then click Windows Update (if it is listed).
3.Click Start, click All Programs, and then click Windows Update (if it is listed).
4.Go to Microsoft's Web site and click Windows Update from the Downloads menu.
Check if the sound works now….if it still doesn’t work then most likely the sound card might be faulty.
Apr 22, 2010 | Computers & Internet
Hi when i install my audio drivers.. it says no media device found.. please help me.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Do the following steps to rectify this problem :
6.Click Uninstall.
before installing.
Mar 12, 2010 | Compaq Presario 700 Series: 1170B01...
I have installed win xp and when i m installing sound driver it tells that "no audio device found"
6.Click Uninstall.
before installing.
Mar 12, 2010 | Microsoft Computers & Internet
CASIO CTK-800 turns on but no keys work, and then the power key will not turn it off. I have tried all of the trouble shooting solutions, i have tried different dc adapters, and nothing works. None of the...
That doesn't sound good. It sounds as if the processor is locking up and that might only be fixed by replacing the main board. Sometimes this happens if a unit gets fried by static electricity.
But before giving up, I would open up the unit and check for loose cables and connectors internally. If there are chips (IC's) that are socketed on circuit boards, push them down firmly. Things may start working again.
Apr 16, 2009 | Music
Turn key many times before engine starts
sound like a dead starter but 1st check the battery therminal for dirt and bad contact pierre
Dec 13, 2008 | 2000 Chevrolet S-10
Voicemail
remove the battery. to turn it off sounds likd a bad key pad or mother board. i had 1 that did that i switched mother boards it turned off just fine.parts are available on ebay.
Dec 27, 2007 | Motorola Mobility RAZR V3
Acer Aspire 5500 5570-2609 Laptop Logo
171 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
