Question about Brother 17 Stitch Sewing Machine, JX2517 26805131
What is this noise by handwheel? - Brother 17 Stitch Sewing Machine, JX2517 26805131
Why is my handwheel hard to turn and making a squeaky noise?
Sounds like possible thread in the gears, or the wrong oil might have been used to oil the machine. Sewing machine oil (clear oil) should be used for oiling the machine. I use an oil called Tri-Flow Lubricant which is available at your local bicycle repair shop.
May 28, 2014 | Husqvarna Huskylock Computerized 910
Handwheel freewheeling
it could be the gears of your handwheel try spraying it with wd-40.
is it making any noise?
Jun 25, 2008 | Janome D'cor Excel 5018
Motor stopped; locked handwheel
Remove the needles. See if the handwheel moves now. Since it's a new machine, consult with the seller.
Dec 23, 2013 | Juki MO-655 Mechanical Sewing Machine
My Designer 1 sewing machine runs great, but it sound terrible. It always sounds like rattling from the bobbin area. What can be done? I take it for cleans and mention this, but nothing changes.
When the needle moves down, is it striking the edge of the needle plate? If so, adjustment is needed. Take the various parts of the bobbin assembly out of the machine and use the handwheel to move the needle in the downward direction (turn the handwheel counterclockwise). Is the needle striking the "hook" in its downward most position? If so, this is most likely what's making the noise and it needs adjustment.
Mar 24, 2013 | Husqvarna Designer I
Tesco ej09 sewing machine - handwheel wont turn
I actually had the same problem, it turned out that after threading a bobbin I'd forgot to slide the bobbin holder back into place (just push it to the left) Hope this helps
Apr 14, 2012 | Sewing Machines
Bernina 140 which has a sqeak in its Handwheel How do I fix it
it's sounds like the machine needs to be serviced when they start sqeaking or making odd noises
Mar 06, 2012 | Bernina Activa 140
My Handwheel will not turn towards me only turn backwards and makes a clicking noise when it does. What is wrong and how do I fix it?
You should take it in for service because it may be your timing. If, it is new it probably will not cost you anything. Turning the handwheel away from you will definately mess up the timing.
Nov 06, 2010 | Singer 1507
When I press the foot control there is a buzzing noise from the handwheel area. The noise continues as I sew. I recently cleaned and oiled the machine parts under the needle-bobbin area. I have opened...
The buzzing you can hear is caused by the foot control, I suspect the suppressor is on the way out, not a major problem, undo the foot control and take out the little suppressor connected to the terminals and discard it, you don't need it, plug out first though.
Aug 11, 2010 | Kenmore Sewing Machines
Belts intact, press on pedal, motion in belts, but not on needle end
does the needle go up and down when you turn the handwheel by hand? if so, one of the belts may be slipping - tighten it enough to make it grab.
if the handwheel does not make the needle go up and down, is the handwheel lock for bobbin winding un-locked? if so tighten the handwheel lock inside the handwheel. if the handwheel lock is tightened and the handwheel spins when motor runs the handwheel lock is asembled incorrectly. if this is the case, undo screw in handwhhel lock nut and spin lock nut off machine, then remove pronged washer and turn 1/3 turn and re-install.
scott
Jul 23, 2009 | Brother LS-1217 Mechanical Sewing Machine
Brother CS100
Try to turn the handwheel by hand, with the machine switched "off".
If no success, then remove the bobin case from the shuttle hook, and try to turn the handwheel again.
If it persists not to turn, then remove the shuttle and clean the race, from lints and small threads.
Put everything back in the reverse order.
May 30, 2008 | Brother CS-100-T Computerized Sewing...
Brother 17 Stitch Sewing Machine, JX2517 26805131 Logo
22 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
