Question about Samsung PN50A450 50 in. Plasma HDTV
My Samsung PN50B650 plasma tv after 30min-hour turns darker or dims.Picture still looks good but darker.I replaced logic board and power supply board.Also have faint red and green band or vertical bars across the screen.What do I need to fix this.
  • Samsung Master
  • 933 Answers
I would suspect a problem with x main board or circuit. I would start with checking the connections on the x main board?
Posted on May 26, 2014
  • 118 Answers
SOURCE: Black Vertical Lines in screen
All I can tell you is that you maybe have left your T.V. on a channel that didn't move for so long, or maybe someone else did and it burnt the screen. Plasma's run off of plasma gas to create the great picture and they collect on the screen and stick. What you need to do is go to your menu and look for "screen burn protection" and put it on white and let it sit for 20 minutes. All of one color such as white doesn't harm your T.V. The only way anything burns is like a bright white line in front of a black background.
Posted on Jan 30, 2009
  • 6 Answers
SOURCE: nec plasma tv 42MP4
these plasma vertical black lines are notorious. there's a video of a fix on this plasma tv repair site. good luck!
Posted on Jan 23, 2009
SOURCE: Red Dots on My Plasma.
Did you get this problem resoslved? I had the same issue a few months ago. I tech came by and took my TV to the shop, a few days later he said it was fixed as they needed to make some adjustments.....The TV has been fine up until a week or so ago and now the red dots have appeared again. Was wondering what happened to yours.
Posted on Dec 28, 2006
  • 304 Answers
SOURCE: Samsung TV Power Supply Board
I doubt that moisture damaged the SMPS bd.
There are many circuit boards in your set and it will take a trained samsung tech to find the problem.
Posted on Jul 17, 2009
  • 304 Answers
SOURCE: samsung plasma HPR4272 that had a 4" black vertical line on
There are at least two issues here. First you have bad buffer boards. Second Very possibly a bad X-Main bd and P-Logic bds. Have a trained Samsung tech troubleshoot the set.
Samsung PN58C8000 Plasma. Picture changes from full color to a blue tinted picture. Logic board replaced 2yrs ago when TV would not turn on. Inspected all boards, no swollen capacitors.
Hi T Quinn.
Does the TV behaves the same way in all the inputs?
Does the color chances when the TV has been on for a while?
This failure could be in the main board, all the video info gets into the logic board from the main board itself.
I would suggest to check for proper voltages from the power supply to the main board, if all the voltages measure as expected. I would suggest to use a small cooling fan and place it near the main board.
Let me know if you require further assistance..
Feb 22, 2017 | Samsung Televison & Video
Right have of led tv is darker
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 13, 2016 | Samsung Televison & Video
Replaced the power supply board on my plasma tv. Now have a snowy picture on all inputs. Green light on the logic board blinks evenly. No puffy caps. Is there another board that needs to be replaced?
After the power supply board replacement, Va & Vs voltage adjustment is a must and necessary for the proper working of the plasma display panel. Do it. If you wish to get some details; check the site linked here. Pull up older posts.
Sep 20, 2016 | Samsung 43 PN43D450A2D Plasma TV
Samsung Plasma won't power on
this is not a capacitor problem. set is only 18 months old - has something to do with x y sustain boards not allowing smps to power on the high voltages.
May 27, 2013 | Samsung Televison & Video
Samsung PS42B430 42" Plasma tv. LED flashes and
The tv power supply board have more dead components parts,u just don't have the skills an the know how to trouble shoot find out more dead components parts that all.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 11, 2011 | Samsung PS42B430 42 in. Plasma TV
A couple of days ago I turned on my brand new (about 6 weeks old) Samsung 50'' plasma pn50b650 I noticed an imperfect picture at the top of the screen. Upon closer inspection, there were about 4-5...
U freeze video games 10-20 mins in video game alot of time.Never pause or freeze any kinds of video image in Plasma tv.It very easy cause to burn in Plasma tv problems alots.
Feb 25, 2010 | Samsung PN50B650 50 in. HDTV Plasma TV
Sanyo DP50747 Replaced Power Supply still not working
I have same problem. Walmart is selling Sanyo junk You are not alone lots of web chatter about these lasting 2 years or less, Mine lased 19 months, Trash it & buy a different brand. I originally was going to buy a Samsung & now I will.
Sep 22, 2009 | Sanyo DP50747 50 in. Plasma TV
TV HAS NO PICTURE...Need HELP!
your logic board is bad replace it and you should be fine unless your panel went bad i can walk u through to find out requirs volt meter
Feb 03, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Samsung plasma sp-r4232
Remove the power supply cable to Y Main board, check Vs on power supply board when you turn on tv.
1. If you have normal Vs, replace the Y Main board. If still not work, replace the Logic board.
2. If you don't have normal Vs when you try to turn on your tv, just replace the Power Supply board.
Jan 01, 2008 | Samsung SP-R4232 42 in. Plasma HDTV
Picture is not coming on samsung spn4235
Remove the Power Supply cable to Y Main board and check the Vs voltage in Power Supply board.
1. Vs voltage is OK, replace the Logic board or Y Main board.
2. Vs voltage is NG, replace the Power Supply board.
Dec 31, 2007 | Samsung SPN4235 42 in. Plasma HDTV
Samsung PN50A450 50 in. Plasma HDTV Logo
71 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
