Question about Exabyte (270001983) (270001-983) 8mm Tape
I have a Dell Super DLT Tape drive, but the tape will not eject. We tried rebooting, and holding down the eject button for 10 seconds - nothing worked. We got the tape out, and purchased a new drive. The tape is now stuck in the new drive. All three lights blink. . .what does this mean?
    Scholar:
  • 74 Answers
It sounds like tyou have put in a damaged tape. This is a common problem and can be fixed without too much expense but is a job for the professionals as it is easy to damage the heads on this type of drive.
This is NOT a driver issue - the flashing lights are a dead give away that this is a hardware issue.
www.tape-drive-repair.com are good for this type of thing
Posted on Aug 24, 2009
  • 3 Answers
You make sure that you still have the drivers for drive, you can download a driver fro th dell website. If that doesn't work you may want o recheck that Tape drive, it may need to be replace.
Posted on Jun 23, 2009
Item: DLT tape drive ( DLT8000 SCSI LVD Loader For Scalar 100 )Problem: Eject spring not fully loaded, as the result pick up tape unable to reach to pick. Please advice.
Look at this document to see if the interposer mechanism is holding the tape from ejecting. The solenoid that energizes to tape insertion or ejection sometimes relaxes and you have to move it manually out of the way to recover the tape.
http://www.filibeto.org/sun/lib/hardware/storedge/tape/l280/pin-024.pdf
Jul 28, 2011 | HP DLT8000 HVD/SCSI Loader (c7200-69978)...
How do you manualy eject a stuck tape from a Quantum DLT VS80 external tape drive
Hello, if it has an eject button, press it quickly several times (can't remember the exact number; try 3 first, then 5, then 7)the reason being that on earlier DLT's the firmware would cause a drive reset which would, if there wasn't a detached leader or other physical problem, result in a tape unload.
p.s. do let me know how you get on!
Regards,
nicam49
Dec 08, 2010 | Quantum DLT VS80 DLT Tape Drive
DLT-S4 tape is stuck in Quantum drive all 3 LEDs flashing together. Eject tape button does not work, how to get the tape out?
Hello, on some of the older DLT drives, if you press the 'eject' button several times the drive firmware attempts an unload operation. I'm not sure of the number of times you have to press it though...try pressing it in and releasing it 3 times (in quick succession). If that doesn't do anything, try 7 times.
It's worth a try!
Regards
nicam49
Nov 01, 2010 | Quantum DLT-S4 DLT Tape Drive
I insert a new tape in tape drive but we are not able get outside tape
Try to press and hold the eject button for about 30 seconds.
If issue persists try to reflash the firmware revision.
After that is the problem didn't got resolved the drive needs to be replaced
Apr 04, 2010 | Compaq DLT8000 40/80GB (154874-002) DLT...
Dlt tape drive left lights blinking, internal fault
This is a hardware fault with the drive (Quite common) The drive needs to be properly repaired (Main PCB Fault)
Send it to www.tape-drive-repair.com as they are quite good at this sort of thing and are not expensive
Mar 02, 2009 | Quantum DLT 4000 DLT Tape Drive
Tape eject from drive
Hi. This is from Dells site regarding automatic ejection of tape once inserted:
The PowerVault 110T DLT VS160 Tape drive reads and writes DLTtape VS1 cartridges. The PowerVault 110T DLT VS160 Tape drive can read - but not write - DLTtape™ IV cartridges written using the DLT1/VS80 format. NOTE: The PowerVault 110T DLT VS160 Tape drive automatically ejects any other cartridge types and any cartridges whose format it cannot read. Make sure all cartridges that you want to use for writing are DLTtape VS1 cartridges.
Perhaps your cartridge is improperly formatted or is of the incorrect type?
May 23, 2008 | Dell PowerVault 110T DLT VS160 DLT Tape...
My Drive will not eject the tape
Turn off the tape drive. (Switch in the back of the unit. Wait 2 minutes and then turn unit back on. Tape drive should issue a write data command and then rewind the tape. After rewind completes the tape should eject. If it does not eject after rrewind completes than try holding the eject button for 5 seconds to attempt a "force eject"
Note: Do not repeatedly press the eject button as this can cause damage to the tape and the tape drive.
Dec 07, 2007 | Quantum SDLT 320 External LVD...
Stuck Tape Removal
usually a reboot gets it out...hit eject button BEFORE windows starts up...I've seen some get stuck forever... Good luck.
Aug 22, 2007 | Quantum ValueLoader SDLT 320 Super DLT...
Ultrium LTO 2 Tape Drive
Try holding the eject button down, for a long time, about 20 seconds (1 and 2 and ). This resets the tape drive, the lights on the front should go off, then come back on again. The tape will either eject automatically or will eject after the button is pressed normally.
The only time this dosen't work is if the tape is still out inside the drive.
Aug 14, 2007 | HP StorageWorks ESL712e Ultrium (AA934B)...
Exabyte (270001983) (270001-983) 8mm Tape Logo
295 people viewed this question
Top Exabyte Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Exabyte Computer and Internet Expert? Answer questions, earn points and help others
