Question about Sharp LC70LE640U 70-inch LED/ LCD TV
Sharp Aquos 70" LED TV
Looks like a dark shadow on lower right corner
SOURCE: My Sharp Aquos
Why does my sharp Aquos TV go out of resolution everytime I turn off the Wii game that is hooked up to it? Then I can reload Optimum cablevision- all I get is the program guide. Help
Posted on Nov 21, 2008
  • 441 Answers
SOURCE: I need to change resolution on my Sharp Aquos
it is most likley the setting on the cablr/sat box
Posted on Jul 24, 2009
SOURCE: Sharp 52" Aquos LCD Will Not Turn ON-Blinking LEDs
I had a similar problem. Fleeting video, then audio only for few seconds and then nothing except the green power LED blinking on and off.
I changed the power inverter board, backlight inverter boards and power supply board but still the problem is not gone.
Just 18 month old TV and out of warranty.
Posted on Sep 20, 2009
SOURCE: Auto Tuning Channels on LC20B2MA Aquos TV
 Automatically tunes in and preset
receivable TV stations.
Make sure the antenna cable is
properly connected.
1 Press MENU (PRESET-1) on the
upper part of the LCD TV set for
more than two seconds. The
AUTO mode screen appears.
2 Press VOL (–)/(+) (PRESET-2)
on the upper part of the LCD TV
set.
All the TV stations in your area
that can be received by the LCD
TV set are automatically preset.
3 The screen shows whatever is on
channel 1 when full auto channel
preset is finished.
Posted on Oct 09, 2009
  • 4 Answers
SOURCE: tv remote controle codes for starchoice 5-in-1 remote (sharp aquos tv)
you might try unplugging the TV and then plugging in again. It worked for me
Posted on Nov 27, 2010
Somehow getting access to the actual internet on my aquos sharp TVLC
The TV will connect to your wireless router but not other devices in your network. You can connect to a HDMI port with a cable to your PC and select that port on the TV.
Jul 27, 2016 | Sharp " AQUOS - 70"" Class - LED - 1080p -...
Hi i have a sharp 70" lED aquos tv. But recently there is a big dark foggy spot on the center of the screen. Can you please tell me what you think the problem is? Thank you
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 11, 2014 | Sharp Aquos Televison & Video
MY SHARP AQUOS 70" TV HAS STARTED TO HAVE A DARK SHADOW ACROSS 1/2 OF THE SCREEN WHILE THE OTHER 1/2 IS PERFECT. DO I HAVE A HDMI INPUT ISSUE OR IS THE TV BROKEN?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Nov 16, 2014 | Sharp Aquos Televison & Video
MY SHARP AQUOS 70" tv STARTED HAVING DARK SHADOWS ACROS 1/2 OF THE SCREEN, THE OTHER HALF OF THE SCREEN IS FINE. DO I HAVE A hdmi INPUT PROBLEM OR IS THERE A TV DEFECT?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Nov 15, 2014 | Sharp Aquos Televison & Video
I have Sharp Aquos LC-70c8470U when i start to watch the TV , after 10 min, the left side stop working, what the problem?
Sounds like back-light problem. It will be best to contact the authorized service center for Sharp in this case. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
May 23, 2014 | Sharp AQUOS LC-70C8470U 70" 3D LED TV...
How to get scratches off flat scfreen tv
Not usually possible without making it look worse....
Dec 07, 2012 | Sharp AQUOS LC70LE734U 70 inch 1080p...
Sharp LC70LE640U 70-inch LED/ LCD TV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
