Question about Air Tools & Compressors
Why wont my steelcraft 13 gallon 5hp model ta25 build up no more then 20 pound of pressure and all i did was change the oil?
Dont want to build air pressure up past 20 lbs of pressure
    President:
  • 1,388 Answers
Check all connections for air leak including the water drain valve with soapy water. If no air leaking from connections, spray soapy water on head area where head attaches to the cylinder checking for gasket leaks. If no leaks are found, most likely problem is in the head /valves /internal gasket leak. If head gasket or valves are leaking, you will notice that air seems to blow out of the intake filter (normally there is good suction at the intake). Good luck
Posted on May 20, 2014
  • 140 Answers
SOURCE: husky comp on 1st start builds up 75 lbs and wont restart
Check the reset button on the motor to see if it tripped. The motor may be overheating. Some motors have an internal breaker and they have to cool off before they restart. Also check the pressure switch. Move the switch back and forth ( on and off ) and listen for a click. If it doesn't click with low to no air pressure then the switch is bad.
Posted on Dec 30, 2008
gaeb7
  • 25 Answers
SOURCE: 25 gallon air compressor wont shut off,changed air regulator
You have a valve plate problem . It could be a slipped "o" ring to a bad reed valve. There are rebuild kits for that purpose. The kits include a valve plate assembly. It covers all the bases. When you look at this area pay attention to the partitions of the head gasket/"o"ring. You may avoid the cost of the kit.
Posted on Feb 25, 2009
  • 89 Answers
SOURCE: tank will not build pressure beyond 25 lbs. Just runs
IS YOUR AIR FILTER CLOGGED. SOUNDS LIKE THE VALVES IN YOUR HEAD ARE NOT CLOSING ALL THE WAY. THEY ARE MOST LIKELY REED VALVES, THIN STRIPS OF METAL THAT OPEN AND CLOSE WHEN THE PISTON MOVES. MAKE SURE THEY ARE CLOSING ALL THE WAY (NOT CARBONED UP). DID YOU REMOVE THE HEAD AND DID YOU PUT BACK LIKE YOU FOUND IT - NOT TURNED OR FLIPPED OVER. SEE IF YOUR FINGER WILL GET SUCKED UP TO THE INTAKE HOLE.
Posted on Apr 12, 2009
SOURCE: craftsman 1 gallon direct drive oil filled wont build air pressure
It sounds like you may have a broken reed on the diaphragm plate. This is located at the block. Remove the cover, and look for a cast metal assembly with fins. It will be attached to the side.
Posted on Apr 23, 2009
  • 225 Answers
SOURCE: Pressure builds to 20 lbs- and wont go any higher and motor runs
sounds like the regulator is fualty.
Posted on Jul 30, 2009
Looking for manual for sanborn B51-A24-80V1 model
PDF]Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1
intrigante35hindu.strictlyyouth.org/rzsatzo_sanborn-black-max-5hp-air-...
Jul 16, 2015 - Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1 ... Black Max Portable Air Compressor - 5 gallon Item #: 81527 ' Model #: BS0880504 ...Compressor Manual: $4.95: Buy Now: B51-AT24-80V,B51-A24-80V1.
Aug 28, 2015 | Air Tools & Compressors
What grade of oil do air compessors use
iso 32 // 30wt. compressor oil, or no additive mineral oil, never use automotive oil in a air compressor
May 06, 2014 | Eagle C5160v1 - Single Stage - 5hp 60...
Steelcraft 13 gallon 5 hp aircompressor
Home Depot MIGHT have one in the tools section. Harbor Freight will have them too
May 26, 2013 | Air Tools & Compressors
DeVilbiss air compressor will not build pressure
Does it have an intake air filter? Has the compressor been properly maintained? Oil less? It may have worn out rings and or valves
Aug 24, 2017 | Air Tools & Compressors
Compressor will build up air pressure to shut off point then will release air pressure for about 30psi
Check Valve in the tank where the air
enters from the tubing leaving the compressor
Call Campbell & get a new one
They are good to talk to on the phone
& you can order parts without all the internet hassle
Sep 20, 2011 | Campbell Hausfeld 5HP 20 Gallon Single...
My ssl5l compressor builds pressure real slow now. Rings or Valves? it did get a little warm while sandblasting lately....
Very rare to have problems with rings. Blow-by would produce high pulsating pressure in the crankcase causing oil to blow out the oil filler plug/ dipstick. If normal crank pressure, suspect problem with valves or gaskets. Remove air filter cover and check for air blowing out of intake or very hot head or air discharge tube. Leaking valves or blown gasket will cause low volume/ low pressure and hot discharge air. Remove the in-tank checkvalve and look for carbon deposits /debris build-up. If the checkvalve and the interior or discharge hose are coated with oil deposits /carbon, most likely problem is valve plate/ gaskets /head. Good luck with your repair.
May 03, 2011 | Ingersoll Rand SS5L5 Ir Electric...
I ran my up-right 5hp compresser out of oil. will
YA YOU CAN DO YOU HAVE A OIL LEAK LD CK THAT IF YOU NEED PATR NUMBERS SEND ME THE MODEL NUBERS AND ILL GETEM FOR YOU AND TELL WERE TO GETEM
Oct 22, 2009 | Campbell Hausfeld 5 - HP 80 - Gallon Air...
Central Pneumatic 94667r 3 hp electric oiled compressor
sounds like your check or reed valve is bad. when the piston pressurizes and pushes air into tank the pressure should not be able to come back into cylinder and thsi is what its doing and then that pressure is now going past rings into oil. look for the valve before the tank. a check valve.
Apr 23, 2009 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
My pump has pressure in the crankcase.
this is normal operation to have pressure in the crankcase and it helps with lubrication so proper oil level should be checked regularly and if overfilled would result in oil being blown out of the crankcase vent.
Mar 22, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
190 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
