Question about AquaVac Tigershark Plus Robotic Automatic In Ground Pool Cleaner
Why does the low voltage breaker kick off every time in turn the vacuum on?
The vacuum turns on but turns off after about 5 seconds. You can hear it click when it turns off.
    New Friend:
  • 45 Answers
Check to see if the ENTIRE suction system is free of debris. Empty your vacuum bag. Ensure that the brushes/wheels are moving and not jammed. Check for proper voltage to the system. If all of these items are ok, then it needs to be serviced.
Posted on May 16, 2014
I have a 5 hp compressor. It will turn on and run maybe 5 seconds and then kicks my breaker out.
you could have a weak breaker or the breaker is not rated for the draw of the compressor have a pro check it out
Mar 02, 2015 | Campbell Hausfeld WL6502 5-Hp 20-gallon...
I have a rockola 454. It kicks thw main circuit breaker after one minute. The turn table only was turning. i think i have it timed right now. still kicks circuit breaker after about one minute.
are you saying it kicks the main breaker to your panel. if that's the case, you need to check the wiring inside, make sure the wires have not melted together anywhere. make sure that no staple, nothing sharp, basically anything sharp pointy or rusty is nowhere near any wires. if that is not the problem, then I would look at whatever is running at the time. those old devices can have large capacitors, huge vacuum tubes. and the way those old things were designed if a tube blew it would still keep working. when that happens, the load becomes greater, meaning amps go up, with every ampere comes a unit of heat. i'll need more info, you can google the model and model number, the schematics are there I just found them, i'm just not paying for them. buy the stuff, send me a copy and I can walk you through troubleshooting it step by step. those devices are very simple to work on. it's all analog, so it's just going to boil down to whether you have voltage where your supposed to or not. hope I helpled, Hamilton.
Feb 17, 2014 | Electrical Supplies
No power
see this step: God bless you
check.gif Check the house circuit breaker to see if it tripped?
Click here if you own a Vacuflo Central Vacuum Unit continuously trips your circuit breaker
If it is tripped, then turn off your central vacuum unit and reset the circuit breaker. Then turn the central vacuum unit on. If the circuit breaker trips again, then refer to the following:
check.gifDetermine if the house circuit your vacuum unit is on has sufficient voltage required.
check.gifIf your unit has a reset button, press the button and try again.
check.gifCross the low voltage wire from the relay at the unit with a small screw driver. If you hear the relay click you need to replace your motor.
Click here to view Central Vacuum Motors
Click here to view How to replace a motor
If you do not hear a click, then you need to replace your relay.
Jul 24, 2012 | Bissell 21K3 CleanView Helix Bagless...
Own 2005 27.5' Wildwood Trailer with a Dometic a/c ducted unit. Last few times out it freezes up initially first few times (pocked circuit breaker once then I turned it off after few minutes second time)....
Don't block off any ceiling ducts and see what happens. If you've closed off any forced air ducts, the unit will freeze up, if too many are closed off. Also, if you shut unit off (compressor) give it 5 or 10 minutes before you turn it back on.
May 21, 2010 | Dometic Rooftop RV Air Conditioner
Carrier air unit kicking on and off within 2 seconds, continually
Hello friend, from your post I am assuming that when the unit is running it is cooling? Any electrical storms in the area lately? If you are home when you hear one approaching it is always a good ideal to turn off the unit until the storm has passed. One thing that you can check is the low voltage control wires where they make their connection to the unit. Shut the power off to the furnace and the condenser and then take the wire nuts off that are making those low voltage connections and make sure they are connected good. You also at the same time can take off the thermostat from the wall and check it's connections. If no problems there then I would call a service co. before it get's worse. Hope this helps 2rns4u <*{{{>(
Jul 24, 2009 | Heating & Cooling
Mitsubishi VS-50607 Won't Turn On
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Sep 25, 2007 | Mitsubishi VS-50607 50" Rear Projection...
AquaVac Tigershark Plus Robotic Automatic In Ground Pool Cleaner Logo
Top AquaVac Pool & Spa Experts
Thomas Perkins
Thomas Perkins
Steve Slater
lioneltrain5
Level 1 Expert
Are you an AquaVac Pool and Spa Expert? Answer questions, earn points and help others
