Question about KitchenAid Kitchen Ranges
Kitchen aid induction cook top flashing f
Flashing f
Eddie Rentas
  • 59 Answers
SOURCE: KECD805HBL3
Hello
I have the folloing Manuals in PDF format, I will gladlu email them to you.
pdf_icon.gif Use & Care Guide pdf_icon.gif Dimension Guide pdf_icon.gif Installation Guide
Eddie Rentas
Tupper Lake NY
Posted on Jul 24, 2008
  • 833 Answers
SOURCE: Kitchen aid glass cook top
What I'd do is gently take a sharp razor scraper in a holder and scrape off as much as you can.  Then, I'd take a bit of WD 40 and work at it with a paper towel.  You can also try the low abrasive cleansers.  Thoroughly rinse before returning to service.
Posted on Nov 20, 2008
  • 338 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Posted on Nov 25, 2008
larryyb
  • 291 Answers
replace the top spray arm and it should work ok again
Posted on Nov 27, 2008
SOURCE: Kitchen Aid Stand Mixer won't release beater
I had this same problem as well.  The beater was stuck like glue to the rotating arm, and it would not budge with any amount of pressure.  I tried the cooking spray and it did nothing.  But today I put a rag in hot/boiling water and then carefully wrapped it around the top of the beater.  I let it sit for 10 minutes. Then I put the rag in hot water again and repeated the process for about another 5 minutes.  When this was done, I covered the beater in a towel (to protect it) and forcefully tapped (ok... I pounded) it with the flat side of my meat tenderizer (it was all I had...you could use a mallet or hammer).  It took a little bit of work because I had to hammer it from the bottom, then the side, then the top to get the little spoke guided through the shaft.  But it did finally come off.  After cleaning with hot water, I put the beater on again and noticed that it was still a little hard to get on/off.  So, I put a little bit of veg. oil on it, and it seems to be better.  Going forward, I will be sure to clean the top of the beater & arm after each use and then coat it with a little oil to keep from sticking.  Best of luck!
Posted on Feb 21, 2009
We have a Sterling 1100E induction hob and have random problems with the hob not working at all, and tonight it just sits there in darkness but peeping constantly. The 2 ceramic rings work but not the
Some times the pots that you may be using are not designed for use in induction cooking. If you are, It might be the size of pot. The peeping sound might be the cook top looking for the pot. But when all else fails. Turn the stove off at the Breaker count to 12. Turn back on. Reboot. Hope one of these work.
Apr 14, 2013 | Stoves Sterling 1100E Stainless Steel...
Error message on my electrolux INDUCTION STOVE TOP
Hello - Typically error code E on Electrolux induction cook top indicates an error with the user interface board/control board. Contact a professional to move forward accurately and properly diagnose/repair the unit.
Oct 30, 2012 | Electrolux ICON Designer Series E36IC80ISS...
E6 displaying in Induction cook top
my problem is E6 code & 1 or 2 minutes automate stopping
Jun 05, 2012 | Microwave Ovens
I have an prestige induction cook top model PIC 3.0 the problem is that it displays an E7 error whenever switched on after appx. 1 minute and the food is not boiled /cooked. please let me know what is the...
Dear Sir i have an prestige induction cook top model PIC 3.0 the problem is that it displays an E7 error whenever switched on after appx. 1 minute and the food is not boiled /cooked. please let me know what is the problem How Can Solved this Problem This prestige induction cook top model PIC 3.0 Only one week so please do need full
thx... Kundan singh Rana Baddi (H.P.) 09857455945 ranansd@gmail.com
Mar 23, 2011 | Microwave Ovens
Our emerson MW899SB just stopped working all of a sudden. The clock is ticking down, little cooking light still flashing, but there is no cooking power...any suggestions?
Yes, it's now junk unless it's still under warranty. The Magnetron has most likely gone out.
-Previous Kitchen Aid, Jenn Air kitchen appliances employee
Oct 15, 2010 | Vacuums
Can't turn on bosch induction hob. light flashes between lock icon and turn on icon. is it locked? how do i unlock. can't find manual
can't turn on bosch induction hob. light flashes between lock icon and turn on icon. is it locked? how do i unlock. can't find manual
Sep 02, 2009 | Bosch Kitchen Ranges
I cannot turn top oven off from bake. How do I make it work?
have the same problem with kitchen aid stove. Set the cook duration for one minute - then open and closed door. Oven turned off.
Jul 31, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Induction cook tops
good day,
hope this link below will solve your problem.
kitchen appliances
Sep 14, 2008 | Dacor Millennia ETT304 Electric Cooktop
Kitchen aid cook top gas. iginator consstantly firing with knoob off
strutz, you probabley got one of the valve switches wet when cleaning. It could of shorted out or it might be just wet. Pull the control knobs off the burners and take a hair dryer and go over the valves slowly. See if it stops the clicking. If not you will probabley have to change out one of the switches. Im not coming up with anything with the RGA365 model number. Try the above posted first...Catriver..post back.
Mar 12, 2007 | Sco RGA365 Gas Cook Top Kitchen Hood
Kitchen Ranges Logo
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
