Question about AquaVac Tigershark Plus Robotic Automatic In Ground Pool Cleaner
Why does my aquavac continue to kick the breaker on the low voltage box?
The vacuum will turn on but kicks off in about 3 seconds. You can hear the breaker click when it turns itself off.
    Problem Solver:
  • 29 Answers
There is a short somewhere in the motor or the cord.
Posted on May 24, 2014
Rear ac unit keeps kicking off says low power the fan will run on auto soon as u kick on ac or heat it kick of and says low power front unit runs good dometic unit
Check your breakers and make sure you are getting the required voltage. Sounds like you are not getting the correct voltage to the system.
Jul 13, 2014 | Heating & Cooling
Why does the low voltage breaker kick off every time in turn the vacuum on?
Check to see if the ENTIRE suction system is free of debris. Empty your vacuum bag. Ensure that the brushes/wheels are moving and not jammed. Check for proper voltage to the system. If all of these items are ok, then it needs to be serviced.
May 16, 2014 | AquaVac Tigershark Plus Robotic Automatic...
No power
see this step: God bless you
check.gif Check the house circuit breaker to see if it tripped?
Click here if you own a Vacuflo Central Vacuum Unit continuously trips your circuit breaker
If it is tripped, then turn off your central vacuum unit and reset the circuit breaker. Then turn the central vacuum unit on. If the circuit breaker trips again, then refer to the following:
check.gifDetermine if the house circuit your vacuum unit is on has sufficient voltage required.
check.gifIf your unit has a reset button, press the button and try again.
check.gifCross the low voltage wire from the relay at the unit with a small screw driver. If you hear the relay click you need to replace your motor.
Click here to view Central Vacuum Motors
Click here to view How to replace a motor
If you do not hear a click, then you need to replace your relay.
Jul 24, 2012 | Bissell 21K3 CleanView Helix Bagless...
I have an old unit approx.11yrs old.When turn on for heat,kicks my breakers off. It runs for about 1/2 hr. before shutting off. Tried running the emergency heat bu t, it continues to kick the breakers off...
Well, obviously your furnace is overloading the breaker it is on. Try this, turn off the breaker that the furnace is on and go through your house to make sure everything else still works. Furnaces are large power users and should preferably be on their own breaker/breakers. If everything still works then have someone you trust check the connections at your breaker box. I have had the same issue where after approximately a half hour or so my furnace would kick off.
Upon further inspection of the breaker noticed a loose connection that apparently was causing an arc and tripping the breaker. After it was tightened down I stopped having the problem period.
Jan 09, 2010 | Amana Heating & Cooling
Carrier air unit kicking on and off within 2 seconds, continually
Hello friend, from your post I am assuming that when the unit is running it is cooling? Any electrical storms in the area lately? If you are home when you hear one approaching it is always a good ideal to turn off the unit until the storm has passed. One thing that you can check is the low voltage control wires where they make their connection to the unit. Shut the power off to the furnace and the condenser and then take the wire nuts off that are making those low voltage connections and make sure they are connected good. You also at the same time can take off the thermostat from the wall and check it's connections. If no problems there then I would call a service co. before it get's worse. Hope this helps 2rns4u <*{{{>(
Jul 24, 2009 | Heating & Cooling
KICKING BREAKER AFTER 6 MINUTES ON HIGH TEMPERATURES ONLY
your breaker might be weak or not the right voltage
May 05, 2009 | Dryers
Heat on after replacing thermal fuse. By 5-10 minute heat off
First i would cheak your breaker panel to see if your double 30 house breaker kicked out on 1 side or if you have a voltage meter cheak for power you should have 220 volts.going across on you plug box.If those are good chek your thermal cut off located on your heater housing on the top and cheak for continuity across.If good you need a element.cheak that across on tester to find out good luck:) PS If that is good you may need timer or motor
Apr 30, 2009 | Whirlpool LER4634J Electric Dryer
GE chest freeze won't get cold
the noise your hearing indicates the possibility of a bad start relay on the comp or possibly it just came loose during the move. on the side of the compressor you will see 2-3 wires running into an electrical connection reseat this first. if still no operation replace teh relay. you can purchase thru any reputable appliance parts dealer. after replacing the relay if you have no operation then likely problem is seized comp.
domestic freezers do not have low pressure switches that indicate low freon charge.
Jan 28, 2009 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
AquaVac Tigershark Plus Robotic Automatic In Ground Pool Cleaner Logo
Top AquaVac Pool & Spa Experts
Thomas Perkins
Thomas Perkins
Steve Slater
lioneltrain5
Level 1 Expert
Are you an AquaVac Pool and Spa Expert? Answer questions, earn points and help others
