Question about Tritton Technology (TRI-UA201) Computer Speakers
Connected Tritton Speaker to my pc but only get system sounds. How do I get music, etc.?
UBX Home Theater System
It sounds like a problem with your centre channel or speaker. The sound of Voices and on-screen, actions in the middle of the screen are played through the centre speaker. General sounds such as music in the background, off-screen events, etc. will be played through other speakers on a home theatre system. Check your connectors coming from your DVD player to your sound system. Are you using a single-cabled digital connector or one for every channel? Check your sound settings as well, i.e., Surround, AC3, Music, etc.
Jan 30, 2014 | Audio Players & Recorders
Tip
How to connect an iPod to a Tritton AX720 Touch
<p>While the Tritton AX720 headset is designed to communicate with other users play games on Xbox 360 and PlayStation 3 game consoles, can also be used to play music from your iPod to surround improving the sound. The kit comes with AX720 Controller in a row to adjust the volume of the headset to adjust, and in combination with an audio cable to connect the controller online for the iPod Touch. Unfortunately, since the iPod Touch is connected to the controller in-line, you cannot communicate with other users if you play a game simultaneously. <br /> <p><br /> <p>1. Connect one end of the stereo audio cable to the door on the right side of the controller online. <br /> <p><br /> <p>2. Connect the other end of the audio cable stereo headphone port at the bottom of the iPod Touch. <br /> <p><br /> <p>3. Connect the headset cable into the headset jack is located on the back of Tritton AX720 amplifier. <br /> <p><br /> <p>4. Connect the power cord from the power amplifier of the port, and plug the adapter into an outlet. Press the power amplifier, which is found on the front of the unit. <br /> <p><br /> <p>5. Press the "Play" button on the iPod Touch to play the music to start. Slide the wheel on the right side of the in-line volume controller to adapt the music to hear. <br />
on Aug 05, 2011 | Computers & Internet
No sound out of Behringer BXL3000 speaker
Suspected Faulty PC board Dead Capacitor Or Mod Pot I would suggest returning it for an exchange the problem is your speaker will work on a regular stereo because a stereo powers the sound internally causing the magnets in the speaker to vibrate Headphone jacks are designed to pick up off a seperate circuit board with a different connection to the main board hence the no sound from the speaker.
May 04, 2012 | Behringer Ultrabass Bxl3000
MY PC SEEMS TO BE PLAYING MUSIC BUT NO SOUND IS COMING OUT
make sure you have a speaker amplifier connected to your pc.audio output...
instal the sound driver for your sound card..
Sep 11, 2011 | Microsoft Windows XP Professional for PC
Hi I have bought a new sony DAV-DZ310 model home theatre.I have connected all the speakers and a woofer.All are working fine except the center speaker.It is not at all working.I have made the connections...
This may not be Dependant on the Music or DVD, but with the setting on the Home Theater system. Try out all the modes - such as 2 Speaker, Multi etc. within the Home Theatre system. In one of the mode only the center speaker works.
Hope this helps. Good Luck.
~SmokinJoe~
May 24, 2011 | Audio Players & Recorders
When playing online on my xbox 360, my tritton 180 universal headset works, but ppl can't hear me talk. Help.
Do you have the chat cable connected?
Is the mic turned off on the inline volume controller?
Is the Chat volume turned up on the inline volume controller?
Test the microphone on a PC by plugging in the USB into a PC and test if it works.
If it doesn't then you can ask for a spare microphone from TRITTON / Madcatz.
If the mic works on the PC then the problem might be with the chat cable which you can also ask from TRITTON or Madcatz.
Hope it helps...
Feb 14, 2011 | Mad Catz Tritton AXPRO Gaming Headset -...
No sounds
Was the sound working beforehand?
First off try to find a continual source for sound like a music file or movie etc...something that can play while you tweak settings.
As the sound is playing(Make sure the program that is playing the sound file has the volume up, check your Advanced Volume settings by double-clicking your sound icon in the bottom right corner of your screen by your clock. Make sure the sound is set and none of the channels are muted. Next check the volume knob on your speaker and make sure that is turned up. Lastly make sure the speakers are securely connected to the PC in back (follow the cord). The cords are usually color coded, make sure it's plugged into the correct hole.
Jul 15, 2009 | E-Machines eMachines Desktop PC
No sounds
yes it is the reason . you need to install an audio driver like AV RACK
Jul 03, 2009 | Computers & Internet
Samsung HT-X50 DVD Audio Problem
I had this same problem and checked all of my cables and wires. Come to find out one of the wires that connected to the central audio speaker (the one that the audio track comes from) was unplugged. I plugged it in and that fixed it! My audio track is back! So make sure that all of the speaker cables are properly connected! That might be the source of your troubles!
Apr 19, 2009 | Samsung HT-X50 System
Tritton Technology (TRI-UA201) Computer Speakers Logo
48 people viewed this question
Top Tritton Technology Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Tritton Technology Audio Player and Recorder Expert? Answer questions, earn points and help others
