Question about Toshiba DVR620 DVD Recorder/VCR
VHS tape loads but right side is lower than the left, kicks back out. Could it be a spring or is it catching on something?
    Genius:
  • Toshiba Master
  • 1,342 Answers
Have your tried different tapes?
Posted on May 16, 2014
Vcr keeps kicking tape back out
Something is stopping the tape from fully loading.Do you have young children? Very often the kids will "post" something through the cassette flap. Remove the top cover & look inside the mechanism for any unusual object or its also possible something in the tape alignment path has broken which will also be lying inside.
Dec 25, 2012 | Orion VR213 VHS VCR
Magnavox vhs and dvd player vhs insertion issues
Someone is going to have to take the unit apart---mechanism issue with the tray or the gears that lower it etc---not too many shops left that work on VHS decks anymore so call around first.
Dec 03, 2012 | Televison & Video
1) 70% of the time, I put any VHS tape into my Sylvania DVC840E DVD/VCR Combo, the VCR immmediately kicks the Tape right back out again. Majority of the time, I have to push the tape in at least 4 or 5...
There is a mode switch operated mechanically after inserting the VHS tape. Locate it. First try using switch cleaning oil. If it does not work, then the mode switch has to be cleaned using very fine polish paper (specially used for cleaning electronic contacts) after dissembling.Warning:-Removing & fitting the mode switch is very tedious job. The sequence in which it operates is important. If the sequence goes wrong, it will damage the gears. If you are not sure do not carry out these repairs on your own. It is better as it is now. Try to get the service manual.
sonsunny
Jul 02, 2011 | Televison & Video
I've had a DR-MV5S DVD video recorder & video cassette recorder for years to transfer DVD over to VHS tapes. Something has recently happened where I can't record VHS tapes. Can't play VHS tapes on the...
Register and download the manual for free audio.manualsonline.com
http://portablemedia.manualsonline.com/manuals/mfg/jvc/jvc_dr_drmv5s.html
If it won't PLAY VHS tapes it must have a serious mechanical problem (if it even loads) or its heads are glommed up, so it obviously won't record them either. When's the last time you ran a cleaning tape through it?
Solve the load or playback problem and it will probably record.
Time and poor storage conditions are the mortal enemies of tapes. Store the in a 'played
Feb 26, 2011 | JVC DR-MV5S DVD Recorder/VCR
Plays for 5 sec, then auto stops, tape is coming out of tape on the inside, then catches the issue and stops
Sound like you have already removed the top to see the problem..
The most common problem is the easiest to fix. If you have small children they love to put toys and just about anything into vcrs money being the most common, I guess mimicking their parents. With tape out and top off look for foriegn objects where the tape load in. You can even turn it upside and shake it.
If you have no young kids or didnt find anything in there abnormal then I would check the idler arm.
Thats the gear that moves freely left and right. Its located between the supply and take up wheels which are what actually fit into the bottom of a VHS tape. Make sure it will move left and right. If thats ok then I dont know what else that you can check unless your experienced in repairing vcr's.
Cost to repair them usually costs more than purchasing a new one.
If your lucky it will just be something foriegn inside..
Nov 24, 2010 | Sony SLV-N51 VHS VCR
Emerson EWV601 eats TAPES...2 springs on right side when looking at machine. 1 is not attached to anything. Where does it go to pointed up toward wall
The spring probably goes to the pinch roller. Try cleaning the heads and demagnetize the heads. This happened to me with a sony, but it works now. hope this helps, !
May 21, 2010 | Emerson EWV601 S-VHS VCR
My Panasonic Omnivision VHS won't eject
take the top off and eject it manualy, there is nothing else u can do with replacing a part, (small white spring loaded, ) probabaly
May 09, 2009 | Zenith ZHX-313 System
Recording
If you face the VHS tape with the back towards you, you should see on the left side a square opening with a TAB or piece of plastic that you can break off. If you DON'T see or feel this piece of plastic covering the square hole, then you won't be able to record. Take any kind of tape {usually 'Scott' plastic tape} or [anything] that will cover the hold. When you place the VHS tape into the VCR to RECORD a smell metal "finger" tryes to go into that hold that you pluged up and will tell the machine that you will be able to record.
If you can't record after that, then something is wrong with the machine.
Get back to me if you need any other help!
Aug 07, 2008 | Sansui VHF6010 VHS VCR
Vhs eject will not release tape.
I had a suggestion that did work. Reach into the VHS compartment with left hand and press down toward the back of the tape. With the right hand press the eject button a few times and the tape did come out. I would not buy a Samsung product again. No help from their 800 tech support. No more playing the VHS side of the player. Lynn
Jul 12, 2008 | Samsung DVD-V8600 DVD Player/VCR
SERIES LXI TV & vhS
I'm guessing the "black thing in side" is referring to the actual tape itself- ribbon like which can be spooled out of the tape case. If so, then your VCR may have a mechanical problem of some sort, which results in a "no tape transport" or "no tape takeup" problem. If the latter, the right reel (takeup reel) is not being driven. Older VCRs often used a small rubber rimmed drive mechanism to drive this reel. Newer VCRs (10 years old or less) pretty much use a gear drive. Something may be broken here, or perhaps the gear is stuck. This gear assembly has to swivel back and forth, from left for rewind, to right for takeup or fast-forward. Unfortunately, you can't see the gear once the tape is in the machine, at least not from the topside. Suggestion: Take the top cover of VCR off, look for this gear, and see if it swivels freely, look for broken gear teeth.
Apr 14, 2007 | Rio Go Video DDV9475 Dual Deck VCR
Toshiba DVR620 DVD Recorder/VCR Logo
55 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
