Question about Intermatic 600 Watt Low Voltage Transformer - AL600TPWS with Timer & Photo
NEED A CROSS TO A CRISTAL GAS FIRE PLACE CONTROL
Jandy lg250n changed temp control still won't fire. any way to check millivolts
Yes, with a meter.
To check only the pilot generator, to see if producing enough Milivolts to operate heater, 'Clip' your meter leads to the ends of the pilot generator wires. Now push down on the gas valve knob in Pilot mode, and after a minute, the Milivolts can be read. Because the leads are NOT on the gas valve (most accurate way), you will need to hold down the knob, during the test.
To locate where an open circuit may be, why heater is not firing...
place one meter lead on one of the TH connections at the gas valve. The other lead will start at the next sensor in line away from the gas valve. Place on each side. If MV's present on 'in' side, and not on 'out' side that sensor is the reason. If no MV on 'in' side, but had it on 'out' side of previous sensor, then that wire is the reason for no fire.
Jun 08, 2015 | Jandy Pool & Spa
Pentair mastertemp 250 NA. heater will not fire, no error codes. starts fine, gas flows, igniter heating but still will not fire. It has a new valve, gas pressure entering valve from new regulator is 8.35...
All appearances - No fuel to ignite!
evrything else looks good, proper gas pressure, proper volts at igniter, etc - it should ignite! If fuel present, heater should Fire!
make sure all valves are open.
Gas valve is ON
AND purge any air from gas line.
IMPORTANT ****. If you bled gas line, don't try to ignite for a few minutes. Allow gas to dissipate first, use a fan to help.
Mar 05, 2015 | Pentair Mastertemp 250 Natural Gas Pool...
Broken gas fire control knob
Generic knobs can be had Lowes or ace hardware etc take your original with you
Dec 21, 2017 | Heating & Cooling
Owner manual for gas fire place
Hello
Get into this link and download the manual.
www.regency-fire.com/Files/Manuals/P36-918-521.aspx
Jan 24, 2012 | Office Equipment & Supplies
Gas fire place flame to low, do you have a schematic to increase the flame ?
Generally, whether it's a Vent-free or Vented fireplace, lower than normal flame height is caused by 3 things: Low Gas pressure; The air shutter control valve is clogged or needs adjusting; The burners need cleaning.
I haven't seen a unit in the past 10 years, that has a flame height adjustment, other the flame height control knob, that's part of the control assembly. Have you checked that, to see what height it's turned to low?
Perhaps, if I knew who the manufacturer was and the model number, I could be of more help to you.
Mar 15, 2011 | Honeywell Heating & Cooling
Panasonic Viera Remote Control is not working tried changing batteries but nothing happens there is no light coming from top when pressing to turn on television
hi,
you can check ur remote is it working, just point it to any digital camera and press any button. u can see a White light f it is working. if not check the battery terminal, clean it. if problem remains, then the internal oscillator cristal or ir led may have some problem. usually cristal may become faulty. for replacing the cristal oscillator u should open ur remote. also check for any dy soldering on cristal oscillators lead, and ir led's lead. for futhrer help u can contact through fixya.
ok
Dec 21, 2010 | Televison & Video
Need a new glass for my raymond weil gold watch
Nesecito el cristal para relos Rymond weil para dama modelo 161 enchapado en oro el cristal tiene una pelicula negra
Oct 22, 2009 | Raymond Weil Watches
When i put my 86 bronco in drive it sputters like its thirsty for gas, then i have to stomp the gas to get it going.
V-6 or V-8 don't really matter. cross wire it. Take number 1 cross it with number 8 or 6. crank it oh take the breather off . ---air filter pump the gas and make it back fire. do this about 2 or 3 mins. then put it back like it was See if it will run right now.
Ken
Sep 25, 2009 | Ford Bronco Cars & Trucks
Intermatic 600 Watt Low Voltage Transformer - AL600TPWS with Timer & Photo Logo
46 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Craig Butler
Craig Butler
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
