Question about Car Audio & Video
How do i turn valor nvg 670w on - Car Audio & Video
3 Suggested Answers
SOURCE: I am installing a back-up camera in my 2005
What wire can connect to a back up camera.. linclon ls2002
Posted on Oct 20, 2011
radioproblem
  • 127 Answers
SOURCE: I have a valor 670w everytime we get in the car
this is a problem that there is only two things that you can do to fix this.
1. reset the radio if there is a reset button on your radio see what happens. if I fix the problem great. if it doesn't move to step 2
2. call valor tell them what it is doing find out the nearest service center is in to relation to where you live and send it to them for repair hopefully its still under warranty
have any more questions email me at radiorepair@windowtintingin239.com
Posted on Oct 30, 2013
2005 Silverado 1500 crew cab stuck in 4wd high?
How many buttons on 4X4 switch ? Or doesn't have any . What transfer case does your have ?
Transfer Case - NVG 149-NP3
Transfer Case - NVG 246-NP8
Transfer Case - NVG 261-NP2
Transfer Case - NVG 263-NP1
4X4 light saying lit ? Flashes ?
The NVG 246 EAU transfer case features a 4 button shift control switch located on the instrument panel.
The NVG 263 transfer case features a three button shift control switch located on the instrument panel.
Need more info . Could have DTC'S - diagnostic troube codes
DTC B0790
DTC B2725
DTC C0300
DTC C0305
DTC C0306
DTC C0321
DTC C0327
DTC C0359
DTC C0374
DTC C0379
DTC C0550
Aug 26, 2017 | Cars & Trucks
99 gmc all the lights on 4 wheel drive control are lit up
GMC What ?
Which one of these does your vehicle have ?
Transfer Case - BW 4401 (Two Speed Manual)
Transfer Case - BW 4470 (Two Speed Manual)
Transfer Case - NVG 241-NP2 (Two Speed Manual)
Transfer Case - NVG 243-NP1 (Two Speed Selectable)
Transfer Case - NVG 246-NP8 (Two Speed Automatic)
Dec 14, 2016 | GMC Cars & Trucks
Replaced 4wd switch on dashboard, did not solve problem. 4wd doesn't connect.
Which of these transfer case's does your truck have ?
Transfer Case - NVG 149-NP3 Transfer Case - NVG 246-NP8 Transfer Case - NVG 261-NP2 Transfer Case - NVG 263-NP1
DTC B0790 DTC B2725 DTC C0306 DTC C0327 DTC C0359 DTC C0379 DTC C0550
DTC B0790 DTC B2725 DTC C0300 DTC C0305 DTC C0306 DTC C0321 DTC C0327 DTC C0359 DTC C0374 DTC C0379 DTC C0550
Regardless both of these switch's are input's to a control module . There are probably DTC'S - diagnostic trouble codes stored . You should have the vehicle checked for DTC , That means taking you vehicle to the repair shop .
Mar 26, 2016 | 2004 Chevrolet Silverado 1500 Crew Cab
Error message repair 4wd
I guess you probably don't know what transfer case you have ?
SERVICE 4WD
Refer to
Transfer Case Description and Operation in Transfer Case - NVG 149-NP3
Transfer Case Description and Operation in Transfer Case - NVG 246-NP8
Transfer Case Description and Operation in Transfer Case - NVG 261-NP2
Transfer Case Description and Operation in Transfer Case - NVG 263-NP1
The NVG 246 EAU provides 5 modes, Auto 4WD, 4HI, 4LO, 2HI and Neutral.
The four manual mode, or range gear positions, of the NVG 261 transfer case are:
2HI - 2 wheel drive high range
4HI - 4 wheel drive high range, part-time
4LO - 4 wheel drive low range, 2.72:1 gear ratio reduction
N - Neutral, 4 wheel
The NVG 263 transfer case provides the driver with 4 manual mode/gear positions:
2HI - 2 Wheel Drive high range
4HI - 4 Wheel Drive high range
4LO - 4 Wheel Drive low range
Neutral
With the info I've given you ,you should be able too now !
There is probably a code stored somewhere !
DTC B0790 DTC B2725 DTC C0300 DTC C0305 DTC C0306 DTC C0321 DTC C0327 DTC C0359 DTC C0374 DTC C0379 DTC C0550.
Jan 31, 2015 | 2004 Chevrolet Silverado 2500
Valor nvg 606w screen goes black and then comes back on
Verify the power and data cables are both firmly seated on both ends. If that does not solve this, borrow a monitor from a friend. If
that works, your monitor needs replaced.
May 11, 2014 | Computers & Internet
I have a valor 670w everytime we get in the car and start the car the volume on the radio is all the way up what can be causing this?
Oct 30, 2013 | Car Audio & Video
2002 yukon front end wont engage
2002 GMC Yukon
2002 GMC Yukon
2004 TRANSMISSION Transfer Case - NVG 149-NP (One Speed Automatic) - SUV
TRANSFER CASE NO FRONT DRIVE
Transfer Case No Front Drive
Cause
Correction
DEFINITION: The transfer case is not delivering engine torque to the front propeller shaft.
Review the Symptoms - Transfer Case and perform the necessary inspections.
Viscous coupling faulty 1. Inspect the transfer case fluid for being black. If the fluid is
black, it is most likely caused by a viscous coupling failure.
2. Test for a faulty viscous coupling. Refer to Transfer Case
Description and Operation.
3. Disassemble the transfer case. Refer to Transfer Case
Disassemble in Transfer Case - NVG 149-NP3 Unit Repair.
4. Inspect the viscous coupling for a bulged cover. Refer to
Cleaning and Inspection in Transfer Case - NVG 149-NP3 Unit
Repair.
5. Replace the viscous coupling if it is faulty. Refer to Transfer
Case Assemble in Transfer Case - NVG 149-NP3 Unit Repair.
Planetary carrier faulty 1. Disassemble the transfer case. Refer to Transfer Case
2. Inspect for faulty planetary carrier components. Refer to
Repair.
3. Replace any faulty planetary carrier components. Refer to
Transfer Case Assemble in Transfer Case - NVG 149-NP3 Unit
Repair.
Oct 19, 2010 | GMC Yukon Cars & Trucks
Its a 120v 670w motor for the ccp-510 I need the
Call them at this number and see if they can provide you with a source for the "replacement" motor.
The Helman Group, Ltd. 1621 Beacon Pl. Oxnard, CA 93033-2452. Phone: (805)487-7772. Fax: (805)487-9975. Tollfree: (800)217-1958.
Jan 15, 2010 | Nostalgia Electrics Helman Group CCP-510...
Car Audio & Video Logo
24 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
