Will the Pioneer PDP-r05xe, PDP-r05u or PDP-r06xe Plasma TV Media box work with the PDP-504 HD Plasma Screen
tvservice306
  • 458 Answers
SOURCE: Pioneer PDP-RX06XE has no picture
check PDP 436XPE UNIT may be Y board short...or need factory restore to the original state....
Posted on Nov 18, 2009
wildbear6
  • 192 Answers
SOURCE: where can I get a fee manual for Pioneer media
Here is the official manual: http://docs.pioneer.eu/Manuals/PDP_507XD_ARE1428_manual/
Posted on Jan 03, 2010
  • 4 Answers
SOURCE: Will the Pioneer PDP-R03E Plasma TV Media box work
Yes it will
Posted on Jan 14, 2010
BElectric
  • 1140 Answers
SOURCE: i have a Pioneer PRO
The first thing you need to do is establish whether there is an actual fault with the MR or whether it's a setup/connection issue. You haven't indicated anything you have already tried in order to rectify the problem so I'll have to start at the beginning with the basics:
Isolate the MR
1. Make sure the MR power is off using the "POWER" button on the front of the unit.
2. Disconnect ALL cables from the back of the MR. If you have several connections be sure to make a note of where they all reconnect
3. Unplug the MR from the power outlet and leave disconnected for at least 5 minutes.
The software/firmware in a MR can "crash" in the same way that your PC does. Unplugging it for a few minutes should re-boot the system - basically the same as starting up your PC.
4. Plug the MR into the power outlet again but do not connect any cables.
5. Switch the MR on using the "POWER" button on the front of the unit.
If the MR is still stuck in standby, you have a fault with the MR.
If the MR will power on:
6. Switch the power off again and re-connect the cables for one device at a time then test the MR. Make sure the cable are connected to the correct sockets.
I suggest you connect the TV first then test the MR will power on. Next connect the cable box and test the MR again. If everything is OK, continue to connect any other devices one at a time and test the MR after each connection.
If the MR fails to power on after connecting a specific device, this will give a good indication of where the fault is and what to do next.
If you can re-connect all of the devices and the MR functions correctly, then it was just a simple case of the MR having "crashed" and you can resume normal operation. Should the fault re-occur, simply unplug the box, leave for a few minutes and switch back on. You can avoid disconnecting everything unless the box fails to power up after the "hard reset" - i.e. unplugging it.
This is a very simple test to determine what/where the fault is. Please try all of the above and then post back with the results if you need further assistance.
Regards,
BElectric
Posted on Jan 09, 2011
caroldon
  • 17129 Answers
SOURCE: PDP 504 PG. TV Deed
If the power supply has failed then you must check the SMPS unit. The diodes from the secondary sides must be checked including the zener diodes. please check the link below for tips on SMPS service.
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Posted on Jul 09, 2011
Testimonial: "Flat Panel Televisions >Troubleshooting Flat Panel Televisions PDP 504 PG. TV Deed Problem with the Pioneer Flat Panel Televisions PDP 504 PG. TV Deed . smps out put Voltage 3.3V & 7.6 V . Pl z Guide Me. Pioneer Plasma Tv PDP 504 PG Thanks , Amen INDIA aminnooani@ymail.ccm "
I have a pioneer pdp-r05XE, on the plasma, the light flashes green and red alternately whilst on the receiver it flashes green 6 times. I can't get the tv to turn on...
Unplug if you have not done so BOTH units from power for several minutes (any cable or satellite box also connected.
wait several minutes and restore power to all units which may allow them to reboot.
Cannot hurt and may help.
Dec 06, 2012 | Televison & Video
I see 11 flashing groups of about 4 ununiformely-doted lines (black and white) on my screen. Ech group of 4 lines is separated from the next by about the same width of the group (i.e. the screen is divided...
there maybe some problem with the vertical circuits with your tv, if you are still satisfy and tv is viewable then patiencely watch it. however as times goes by using it, if the defect is not corrected it may worsening the vertical circuits problem. scanning vertical trace is the problem of your tv.
Feb 06, 2011 | Pioneer PDP-4271HD 42 in. Plasma...
Pioneer PDP-r06xe 50 in. Plasma Television Problem. During a Rain Storm - a lightening strike in my loft - the save system it has protect several electronics, but when I try to switch on - the TV it turn...
when switch ON it blinks 7time blue led - then switch OFF by SELF and blinks 8time blue led. Of-course when it switch off by self the TV swap the led from blue to red but the blinking Blue led is on the Receiver (The switcher on the TV is never blinking)
May 22, 2010 | Pioneer PDP-4350HD 43 in. Plasma...
What tv did an pioneer PDP-R05U go with?
Here's a list of Pioneer plasmas using the PDP-R05U media receiver:
PDP-4345HD, PDP-4350HD, PDP-4351HD, PDP-5045HD, PDP-5050HD, PDP-5051HD
Mar 10, 2010 | Pioneer PureVision PDP-5050HD 50 in....
Nov 18, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
The media receiver shuts off and the plasma screen
Pioneer plasma pdp R03U shuts off and tv shows E01 or action freezes while soun dgoes on and then stops E01
Aug 19, 2009 | Televison & Video
Pdp r05u receiver
You should return that box to the seller. There are half of dozens senarios which you should not have to go through.
When you are not able to turn of the power of the media box,that is a sure sign of trouble(assuming you have already replace it with the good battery.)
Instead of going into details,you should get your money back,and i DO NOT recommend you to buy a media box from ebay.To me,who would want to sell the media box that works with the plasma TV monitor?That is a video/audio connection board for the tv,without it,the tv is useless.
solutiondoct
Sep 19, 2008 | Pioneer PureVision PDP-4340HD 43 in....
Pioneer plasma media receiver problem
The Pioneer multi media reciever box is only serviceable from the manufacture. They should have authorized service reps that they equiped to do service for Pioneer devices. They normaly change boards to service it. The regular service man would only be able to fix a simple cold solder connecton or fix some other simple part of it.
Contact the place where you bought it to find out about servicing it. You may find it cheaper and easier to simply replace it completely. It is very possible that there is no service support for this box. Get an estimate before accepting to service it.
Most of the small electronics of today are throw-away anyways...
Jerry G.
Apr 13, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
