Question about Samsung Refrigerators
How to check fan in samsung srs585hdis
How do i take cover off to check internal fan?
  • Samsung Master
  • 4,655 Answers
Not really a good way to explain how to get to the fans but looking at the=> SRS585HDIS Parts Diagram may help you see what is in the way. You also can contact Big Warehouse Spares. Parts for your model HERE=> SAMSUNG Refrigerator SRS585HDIS (RS21HDUPN1/XSA) Parts If this refrigerator is like most dual evaporator refrigerators made by Samsung the fan will not be the problem. The problem is a design flaw that causes ice buildup on the fridge side evaporator. You can clean the defrost drain and manually defrost the evaporator with a hair drier.. That fix should last a couple months unless there is a door seal problem causing excessive moisture buildup on the refrigerator side evaporator. I am here should you have any questions, Thanks John Tripp Appliance 911
Posted on May 16, 2014
Where is the thermostat located on samsung srs585hdis
this does not seem to be a good model motor
Jun 06, 2017 | Samsung Refrigerators
Samsung fridge model SRS585HDIS WONT STOP BEEPING ARGGGGGG
If you wish to get some details about refrigerator common fault and troubleshooting ; visit the site linked here. Pull up older posts. search with the word "Refrigerator".....
http://electro-medical.blogspot.com/
Jan 21, 2017 | Samsung Refrigerators
I have a Samsung srs585hdis side by side fridge and there is quite a lot of water leaking from a cover behind the bottom veg baskets. What would cause this?
The evaporator condensate collection pan drain inside the fresh food section is clogged or blocked with ice. You will need to take the cover off to clean out the drain. Here is a link that shows the breakdown of parts for the fresh food section=> HERE
Here is a link to=> Leaking Refrigerators
This video only applies only because it shows examples of what is happening to your refrigerator
APPLIANCE 911
Dec 21, 2015 | Samsung Refrigerators
I have a Samsung electric dryer model # DV218AEBXAA IT TURNS ON the display shows the cycle symbol and >> >> but it doesnt run. Whar can i do, it is out of warranty?
warranty depends your sales slip if you have one, and the owner's manual.
If Hair dryer, wild guess the fan inlet area is covered or blocked with hair so the internal parts are getting too hot. There is a thermal switch which makes it shuts down for safety reasons.
Otherwise the same problem may be hair wrapped around the fan and causing a similar problem.
Mar 07, 2015 | Samsung Dryers
TV DISPLAY SAYS CHECK FAN #1, WHICH FAN IS THIS HOW DO I DO IT
I believe the Fan #1 on Samsungs is usually either the Fan that directly cools the lamp or the exhaust fan right next to it. But as a tech I would recommend that you carefully check all fans by taking the back cover off and finding the trip switch (it needs to be held down, usually blue that indicated the cover is on). when the tv is powered on and the screen comes on the fans should begin to work, you can visually inspect and replace then =)
Hope this helps, let me know if you have any questions
Dec 24, 2013 | Samsung HL-R6167W 61" HDTV
Samsung srs585hdis side by side fridge freezer
The cold control inside the fridge may be defective. Hmmm...wonder why Samsung did not mention that as part of basic troubleshooting? If no adjustment of the cold control yields results, chances are it is defective.
Oct 22, 2013 | Refrigerators
My samsung mdl# hln437w says check fan 1 2 3
the internal fans has some maitenance, needs to be cleaned/replaced . need to open rear case to acess them.
Feb 09, 2010 | Samsung HLN437W 43" Rear Projection HDTV
My Haier 12 wine bottle cooler is dead. No fan or cooling .
Check the 2 fuses,one covered with black heat shrink, next see if internal fan is spinning, inside door, the 2 fans on the back should spin when first plugged in. also the 2 led's red and green should light up...if internal fan doesn't spin then check or replace, use batteries to get it to spin as a test...good luck,safety first...
Nov 15, 2008 | Haier HVT12ABS Compact Wine Cooler
Samsung side by side refrigerator compressor running but both frdge and freezer internal fans are not running can you help thanks
sounds like a problem with the circuit board.....you would have to check and see if the fan is getting voltage.....sometimes the fan in the freezer will build ice from the ice maker leaking, and the ice will get stuck in the fan blade causing it not to run....hard to get to the fan on those but if you disassemble the freezer you can check it out
Jul 28, 2008 | Samsung Refrigerators
I have a Samsung Washer/Dryer (WD-J1255) When trying to complete a dry cycle, "HE2" shows on the screen. There is no such error code in the manual. The machine has been reset and the same happens...
Samsung reports FE is "FAN ERROR".
Samsung replaces the internal die cast fan-heater unit.
If not under warranty, as DIY try unpluuging the unit and removing the top cover. Remove the aluminium die cast "Assy Duct Scroll" which is on the RHS and contains a fan and a heater. Dissasemble by removing screws and remove the clogging by detergent foam and lint. Use vinegar as this dissolves the sludge. Rinse and check that the fan can spin freely. Note that the fan motor or heater could have burned out. However it is likely that a heat sensor that reported FE can caused a shutdown due to over heating.
If cleaning and replacing does not help a new unit may have to be sourced.
Note if exensive corrosion is present the unit will have to be replaced.
Note that use of foaming detergents or too much detergent will cause this problem.
Jul 24, 2008 | Samsung Washing Machines
Refrigerators Logo
281 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
