My tcl 32ins led tv color started to show white . What is the problem color ic or the screen.two tecnishon say so
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Sounds like T'Con board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Posted on May 16, 2014
5 Suggested Answers
SOURCE: Panasonic CT-36SL14J White screen
my Panasonic CT-36SL145J won't turn on
Posted on Jul 25, 2010
ekcnoel
  • 998 Answers
SOURCE: My Mitsubishi WS-65908 color TV
Try to check the PAL,NTSC setting set it to Auto. feel free to send feed back good day and best regards.
Posted on Jul 22, 2011
MOROO007
  • 180 Answers
SOURCE: Tcl tv line through screen
maybe vertical ic be came hot and make some lige unconnected in board have to go to tv tichnican
Posted on May 18, 2013
ercupa190
  • 12223 Answers
SOURCE: tcl lcd tv lcd screen trouble
TEST the CRT, color gun, demodulator, see the block diagram attached.
Posted on Jul 20, 2013
How do i connect my Acer Aspire one D270 with TCL LED TV 40. When i connect my laptop through HDMI port screen blinks but nothing shows on LED TV .LED TV just says not supported.My laptop Graphic is I
Have you checked the settings on your TV Malik? You usually need to go to settings on there and bring up HDMI. For example, if you have TV selected on the settings, you need to change to HDMI to view stuff on your TV screen from the laptop.
Dec 10, 2014 | Acer Aspire One D270-1865
My 39 inch tcl led TV power cord got abrubtly unplugged while watching TV. Plugged it back in and now the TCL logo on the start up screen stays there frozen. Many times already tried to unplug it, wai
Unplug the tv and hold the on/off switch on the tv (not remote) for 30 seconds. This should clear any power left in your electronic boards. Then plug it back in and try again.
Sep 14, 2014 | TCL LE39FHDF3300 39" LED TV 1920x1080, 60...
Why does my led screen have a white spot
may be the panel, in which case it should be under warranty. This unit has a 1 yr mfr warranty , if less than 1 yr old it would be covered. contact servicer for service immediately before warranty expires
Sep 09, 2014 | TCL 48FS4610 48 LED HDTV 1080p 120Hz Slim
TCL 21M62s TV showing standby led light on but not power on this tv
The red standby is on because the tV is not turned on. Once you turn the power ON the red led will go out and possibly another color will come on.
Oct 29, 2013 | Protron PLTV-32 Television
May 18, 2013 | Televison & Video
I have TCL TV set. When I on the power of TV set, tv shows message ASM after 3 second in Red and auto scanning running. I already plugged the cable so many times, but same problem continue. Please help.
Hello
The mamory IC inside the circuit of your tCL tv is faulty. Memory IC is one which transfers data to main system IC when we switch the set ON each time. Now it transfers the data to the system IC ofcourse, but not memorize the [LPM]; last position memory. This IC can be located very nearto the main system IC; will have 8 solder terminals. It can be easly unsodered out and resodered in. Its number is most important. Keep a keen look on its number and buy an exact replacemnt. It will be very cheap to buy, and can be had from most of the electronic spare part shops at your town. OK.
Jun 29, 2011 | Televison & Video
My tcl tv model tcl 2009 has no power but led is blinking. I replace already the control ic TDA16846 but still not working. what is the possible problem regarding the power supply
A nice little Control IC but when they fail ithey take out a lot of components around the power supply especially the output FET rather catastrophically for the power board.
I would look elsewhere for your fault because if there is a flashing light, the microprocessor has power and that comes from the power supply.
Look for open circuit fuseable links.
Hope that helps.
Dec 10, 2010 | Televison & Video
No color
CHECK THE SYSTEM IC
Sep 06, 2008 | Akai CTS2550 25" TV
53UWX10B
Good Day, Butchilee,
Sounds like you have patience, hope your TV has some trace left. Hit recommends that you replace the originals with
STK-392-150's and the resistors. Replace said items with care then back down on the screen/ focus controls and gradually bring the screens up until you have pic, adjust focus. Go into customer menu and adjust color down, set brightness to 50%, contrast to 100%. Then go back and adjust the screens for proper, black/white, tracking. AND It's best to double check the soldering connections.
Good Luck, Big Irish.
Jul 04, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
