Question about Amana NTW4750YQ HE Top Load Washer
The rinse and spin cycle on my washer will not work!
Spin and drain cycle works. washer makes humming sound when filled with water and wont drain
  • Amana Master
  • 5,323 Answers
U said drain works then u said it doesnt drain?
Posted on Apr 11, 2015
  • 183 Answers
SOURCE: Amana Speed Queen (LWS34AW)
Probable gear box fault Regards Engineer
Posted on Jul 30, 2007
dididsaythat
  • 291 Answers
SOURCE: everything works but machine won't agitate
The pull at the bottom of transmission should turn both ways.. one way for spin the other way for agitate... if transmission turns both ways means not locked up and probley bad motor..
Posted on Sep 05, 2007
  • 156 Answers
SOURCE: washer wont drain or spin just hums and then blows fuse
bad motor
Posted on Feb 25, 2008
Illeagle
  • 525 Answers
SOURCE: Washer hums on rinse cycle
It sounds as if you are using WARM water for the wash cycle since your complaint begins with the rinse cycle. The rinse cycle generally uses COLD water, so I must deduce that your washer is not filling up for the rinse cycle. The humming sound is likely coming from the fill valve being starved for cold water.
Investigate your cold water supply to the washer and if you have good supply, you may want to replace the fill valve.
Let me know what you find...Thanks for contacting FIXYA.com
Posted on May 27, 2008
SOURCE: Washer wont work.
I FOUND BROKEN BELT . HOW DO I CHANGE IT ?
Posted on Sep 04, 2008
Why won't maytag MVWC6ESW go into rinse cycle?
The cold water valve screen in the washer water valve is clogged. You have grit in your water and it will continue to happen until you get a filter system installed on to it.
Mar 18, 2016 | Maytag MVWC6ESWW Washer
My 5 year old Roper washing machine fills up, washes/agitates the cloths, drains them when the washer get to the rinse line to start the rinse cycle it stops, and all I hear is a humming. The machine will...
I'm not familiar with roper washing machines so I'll ask the question does it have two fill hoses. Most European machines now only have one fill. If it has two then it sound like the machine takes the initial water from the one fill and the rinse cycle water from another. The humming sounds like the valve for the other fill needs replacing. These are quite inexpensive and easy to fit. Power off.. remove lid ....switch of water...take out valve when you establish which one is affected and replace
Oct 17, 2013 | Whirlpool WTW5700S
Maytag washer wont start after it fills
Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
Mar 14, 2009 | Maytag Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
May 27, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Lg washer 2277, spin cycle
The humming noise is probably the drain pump working to remove the water out of the tub.  It is normal.
Apr 26, 2008 | LG WM-2277HW Front Load Washer
GE Top Load washing machine not draining
  • to me it sound as if waterpump is not working
Apr 09, 2008 | GE WDSR2080D Top Load Washer
Rinse cycle doesnt work
the humming noise is probably the cold valve operating but no water. check tap not turned off. slowly loosen cold water feed and check if water present
May 02, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Amana NTW4750YQ HE Top Load Washer Logo
153 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
