Question about Sony Car Audio & Video
Car CD player plays but has no sound
The radio part of the CD player works fine. The CD player was just installed about a week ago and since then I have purchased another of the same brand and model (Sony CDX-GT33W) and installed it only to have the same problem. The car is a Chrysler Concord.
  • genudanthewe Jun 24, 2009
    Tried connecting the amp wire to the ground, but had no change. Then after more research discovered that the previous radio (Crystler Infiniti model) required the amp wire to be connected to the power antenna wire. After wiring it like that the cd player is now working. Thanks for the advice, it got me started in the right direction.
    Problem Solver:
  • 9 Answers
Does your car have a premium sound system? Assuming that your cd deck is fine, try connecting your remote turn on wire from the sony to the corresponding wire on the car(if you bought a wiring harness, just match colors). Also some chryslers used a ground to turn on the amps.. a black wire with a female connector as well as a heavy ground ribbon cable... connect those 2 AND the ground to your stereo to enable the amplifiers.
Posted on Jun 23, 2009
Installed aftermarket stereo and now car want start but everything else works
Switch the wiring harness for the cd player back. t probably disabeled the ignition systime in the car.
May 01, 2014 | Brembo 2007 Dodge Charger - SXT, RWD -...
CD will not play. The CDs goes in and out fine and looks like it is playing according to the display. I can change songs, fast forward and reverse through the songs according to the display but nothing...
Do you have the radio hooked up to an amplifier? If so, it sounds like you are using the blue wire (antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) to turn the amp on. The antenna remote wire turns off when leaving tuner mode.
Jun 22, 2011 | Alpine CDA-7863 CD Player
Jensen cd player no longer working(self-installed)
First check the wiring to the radio. You may measure the power being ok but you also need to make sure the ground connection is ok. If this is all ok it may be that you have dry solder joints on wiring socket inside the radio or a blown track or protection diode.
Sep 17, 2009 | Car Audio & Video
Clarion radio sound flickers
make sure your wirings are rated to handle the current needed by your radio. You might have a large voltage drop when it is at high volume level because it will draw lots of current. You might need to change the size of your wires to your Clarion. Check the voltage near the radio when it starts to flicker if it goes below the source voltage of 12V. hope this helps
Aug 17, 2009 | Clarion M475 CD Player
The radio/cd player on my 01 yukon loses the sound randomly. Some times it works fine then othertimes it does it a lot. This all started a month ago. Before then I'd had no problems. I talked to a guy at a...
sounds like the amp is over heating and needs to be replaced
and yes there is most likely an amp in the system and it is eithor over powered or over heating
Jul 29, 2009 | Car Audio & Video
Head unit radio works fine but static when i try to play cd's
i had quality auto sound install it for me, and they added a pulse switch. my dvd works while i drive the car.
Jun 30, 2009 | Jensen VM9510 Car DVD Player
I have a 1999 Chevrolet Suburban with the factory radio. The radio works fine but when I put in a cd and turn the volume up some, it just stops playing for about 20 sec. It will come back on at a very low...
sounds like your popping the breaker, after a while your speakers will go, theres just too much power for it to handle, take it to a car audio store and get them to test it, you may need new speakers
Jun 20, 2009 | Car Audio & Video
Peugeot 307 5 stack cd player
hello hi ... umm first of all the cd player of that car has issues and its not only you who has faced it.
secondly rather than spending $1500 get a new stereo..
its the era of usb, aux and bluetooth now
Apr 20, 2017 | Blaupunkt IDC-A09 5-Disc CD Changer
CDA 9885 No idea why it suddenly stopped working
It sounds like you have a bad ground connection. You need to take the radio out and check all the connections. I bet you have a loose one somewhere. That is what the problem was with my bronco
Sep 08, 2008 | Alpine CDA-9885 CD Player
JVC KD-NX5000 NOT WORKING PROPERLY
I had the same problem, where the Sat radio, the bluetooth and the ipod were all non-functional. Turns out, they all go through one central hook-up, so you have to make sure that connection is good.
When mine did not show up or function, I looked at the install under the foot board of the front passenger seat that the installer did, and nothing looked out of whack. Upon closer inspection, one of the cables was had been pressed out of it's proper place and loosened enough to cause a bad connection.
I don't care for the install, but there was no problem with the equipment, so check all of your connections. Even to the point of pulling them out and reconnecting them to see if that fixes the problem.
Robert
Jul 08, 2008 | JVC KD-NX5000 Car Video Player
Car Audio & Video Logo
583 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
