Question about Amana NED7200TW Electric Dryer
On a NED7200TW Electric Dryer the dryer does tumble and heat. Exhaust path is clean and clear. The dryness selector is functioning but the led has gone out on it. So if you have "low dry" selected (not sure the exact words used) it leaves the laundry damp. Dryness of the laundry increases as you press the selector switch. Where can I get a led that can be soldered in place of the old one or would I have to buy a new board just to fix that light?
    Sergeant:
  • 479 Answers
It is part of the board the only way to get the light is to find an appliance bone yard and try to find one
Posted on Jun 29, 2014
dragonsthatk
  • 547 Answers
SOURCE: Amana dryer doesnt heat up
no heat. heat element
Posted on Feb 11, 2009
  • 70 Answers
SOURCE: no heat, dryer exhaust vent cleaned, still no heat, gas line is on
I think you have a gas dryer, and a bad ignitor.
Posted on Apr 23, 2009
  • 89 Answers
SOURCE: Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
Posted on Jul 10, 2009
EllaWatson25
  • 725 Answers
SOURCE: I have an Amana NED7200TW Electric Dryer that was
You probably busted the element during the move and this not a serious problem. These parts are fragile and easy to repair. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct part out to you asap.Call us from 7 AM until 9 PM CST. We hope to help you repair your dryer. Thanks, Ella
Posted on Nov 17, 2009
ftw1952
  • 10319 Answers
SOURCE: dryer is not heating up to dry clothes
The spark ignitor maybe at fault. Listen for the clicking noise upon starting it up the first 30 seconds it runs. If not heard it is in need of a replacement
Posted on May 01, 2010
Amana NED7200TW dryer. Has heat, tumbles, clothes don't dry. Vents have been gone through and cleaned. This happens in the sensor dry and time dry modes. Any thoughts? Thanks!
Just a question. Does your blower work. If your blower does not work it won't dry. Check blower belt. Mine broke and had no air blowing. Just a thought.
Oct 21, 2016 | Amana NED7200TW Electric Dryer
The drum stopped spinning when it was drying a load of towels and will not start again.
I had the exact same thing happen. I was drying a heavy load of towels and jeans and it just quit. No tumbling, no heat, no air.
I took my dryer apart and found that there's a thermo switch on the duct between the fan and exhaust. When open, this cuts power to the motor (which I think also cuts power to the heater).
This is the part: http://www.appliancepartspros.com/part_details.aspx?part_id=4045367
I made a temporary jumper past this and it started. So, I have a new switch on order.
Jan 04, 2011 | Amana NED7200TW Electric Dryer
Amana dryer NED7200TW quit heating, it appears everything else is working
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 10, 2010 | Amana NED7200TW Electric Dryer
Dryer runs about 20 minutes on its cycle and cuts out. It will not turn back on without a 20 or so minute rest. I have checked the lint filter as well as the exhaust and they are both clear. Anyone have...
Check the exhaust path, where the lint trap goes. If there is lint in the path, it will retain heat that will shut the unit off. You can't just look and see, you will have to dismantle the path from dryer to final exhaust port to make sure it is all clear.
Nov 12, 2009 | Whirlpool WED5100SQ Front-Load Electric...
SLOW TO DRY
HI, i recommend making sure that this dryer has a clear exhaust duct and hose. place your hand on the outside exhaust hose and check for a good flow. if the flow is low, you will have some sort of clog in the exhaust system and you will need to clear this blockage. if the exhaust duct and hose is clear of debris, you will the need to check the lint screen for debris as well. make sure you Clean this regularly after every cycle.
I also recommend checking the dryness sensor as well.
May 19, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Electric Dryer Model GEQ9800PW1 - No Heat
Well your high limit is blown. It mounts up top of the heat element chamber.
Jan 31, 2009 | Kenmore 62602 Electric Dryer
Dryer not heating up
Could be the heating element?
Jan 12, 2009 | Dryers
Amana NED7200TW Electric Dryer Logo
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
